    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 616.4k Views 667 Watching
    • mitcorbM Offline
      mitcorb
      Hi, there, hirschma:
      Is this like a junction box for low voltage lines? The model is nice and well done judging by the mesh lines.
      • TIGT Online
        @hirschma said:
        Long term lurker, coming out of the shadows.
        I've been using SketchUp for product design. Finally getting somewhere. Here's a sample of something I was working on recently..
        So, hi everyone!
        jh
        Hi, looks quite well worked out...
        What is it exactly ?
        A couple of tips.
        [I realize its a 'wip' 😉 ]
        You have some 'blue' [back] faces showing in the view - reverse them so all of the visible faces are the right way round - it can cause problems later with many 3rd party renderers...
        If the object is a proper manifold solid [without internal 'partitions' etc you can orient all faces quickly by selecting one and all others will flip to match it - however, non-solids will give unexpected results!
        The 'object' looks quite small - remember that if you try to make facets with side <~1mm or 0.01sq" with say FollowMe or some similar scripts it can fail and leave small 'holes' or even rare Bugsplats! - it's a known limitation of Sketchup/OpenGL - which is designed to model typical building-elements, through building themselves up to building-groups... but not microbes, wristwatches or at the other extreme cities or counties - BUT if you are making 'small objects' you can scale them up temporarily - say x10 - and then when the small facets etc are created you can scale back to their original size - say x0.1 - the new small geometry can exist but it's its creation that's problematic...
        • Z Offline
          zandro
          Hello! Im new here in this forum.
          I want to share my problem. My VRay does not respond every time I render such a big file. Any suggestions? My SU version is Pro 8 in Win7.
          • TIGT Online
            Welcome zandro,
            Can I suggest you post a message in the special VRay forum here as you're likely to get a better response there...
              Gultekinmg
              Hello,
              this is my early sample at SU.
              http://sketchup.google.com/3dwarehouse/details?mid=16c8b57688f3fd719489d80069630f38
              Has been long time i have quit sketchup due to could not utilize tools to design POPUP books.
              I am back here to search some bone connection scipts to animate pop-up books.
              All Sketchy Scripters makes me download are here, i like it. 😄
              I hope it helps me achive my goal.
                makizushi
                Greetings, all.
                My name is Ryan. I work at a church and used SketchUp to create a model of the property so that I could more efficiently plan a haunted house / maze for Hallowe'en last year. I haven't got a background in CAD and have no talent for reading blueprints, but I've worked with Adobe Illustrator some and ported the skills from there to SU as best I could. The result was a usable, if inelegant file. I'd hoped to have become a SketchUp pro by now, and to be wowing everyone with mad-skillz visual walkthroughs of how we're going to do this year's haunted house...but that hasn't happened (yet). So to remedy that I've come to sketchucation for guidance.
                My hopes for this forum?
                1. I need a basic vocabulary so I understand the terminology when folks use it.
                2. If someone could point me toward a 'best practices' guide for creating and ordering the components & models - such that I could have multiple POVs, cross-sections, etc.
                3. also, if I want to upload my working file and ask people to critique and/or improve on it, where do I go?
                Thanks in advance, and it's nice to be on such a friendly forum. 😎
                  Hi Ryan and welcome!
                  There will probably not be any direct guide for most of your questions as some are quite complex.
                  1. As for "terminology": there is a "Glossary" in the SU Help Center which explains all the terms used in the application.
                  2. As for organising your model and especially using components - whenever there is the smallest bit that is repeated at least twice in your model, you should use a component and its copies ("instances") for it - but of course, this advice is ultimately vague and we could demonstrate much better with an actual example (model).
                  3. Under the text area where you are posting, there is an "Upload attachment" tab. You can upload attachments up to 2Gb here (I think smaller for images but of course you need not use 2Gb images) but if your file is bigger, you can always use the 3D Warehouse to share your model and paste the URL here.
                    Thoryan
                    Hi Guys,
                    Just wanted to do a quick intro.
                    My names Tom, and I'm in the UK.
                    I'm following in the footsteps of other action figure fans and just trying to create my own mods for figures, and was recommended sketchup by many of the guys on some of the figure forums.
                      ConnorBC
                      Hello everyone. I'm new to SU. I've been playing with SU Pro 8 for a few weeks now and really enjoy the program. I have never played with this type of 3D program before and have been told that SU is a great way to eventually jump into SolidWorks.
                      I have always enjoyed traditional drafting since high school. I am currently designing and developing new compound bow components. I have been submitting all of my traditional drafts to a second party for modeling and would like to speed things up by building the models and generate the required PDF's and DXF files right from the start.
                      I am able to generate simple components to scale but feel I am still some time away from completing more complex models. I will endoubtedly have many questions while learning SU. 😄
                      Thanks everyone! I look forward to being an active forum member and hopefully can contribute to the forums very soon.
                      Connor
                      • mitcorbM Offline
                        mitcorb
                        Welcome to you, Connor:
                        I hope you enjoy the ride. Feel free to ask questions. There's always somebody who either has an answer or can point you to a solution.
                          ricabescobar
                          Hi my name is Richard, I'm from Guatemala, that is in Central America!!, and I'm an Architec student, but I'm already working as an Architect, and I love to work with Sketchup, my primary job is in Autocad, but everytime that I can, I work something in 3d on skethup for presentations to clients or my boss. I also work with 3d max.
                          This is my blog and some of my works:
                          http://visual3drcab.blogspot.com/
                          I'm very happy to find this web!
                          I hope to find somethings very useful here.
                            Supreme Line
                            Hi Guys
                            I Am Ryan From Scotland.
                            I Started Google Sketch Up in May 2011 and since Then I have Created about 15 Ships In Which Iv Made A Ship Line Supreme Line I have 6 Employees that Build Ships For My Virtual Ship Line.
                            This Is My Ship Line Wiki Page
                            http://www.peekarica.com/steampedia/index.php?title=Supreme_Line
                            This Is The Official Website of My Ships
                            http://supremeline.weebly.com/
                            My Old Ships are out of date as i am learning how to build better etc.
                            Hope You Like Them anyway if you have any question please Aks and ill get back to you soon as possible 😄
                            Waves
                            Supreme Line
                              There are a couple of ship-makers here as well.
                              http://forums.sketchucation.com/viewtopic.php?f=81&t=20385&p=170602
                              or
                              http://forums.sketchucation.com/viewtopic.php?f=333&t=33757&p=296873
                              Have fun!
                                Supreme Line
                                or
                                Have fun!
                                Thank You Gaieus
                                  You welcome. I hope you do not mind me linking to those two, superb models. As you can see, you still have some things to improve in your ships (not as if I had ever modelled anything close to those ships linked either).
                                    Supreme Line
                                    Yeah I know I am working on RMS Netherlandic this is my 3rd month on it now and its looking amazing lots more still to do though.
                                    Wiki Page of Netherlandic
                                    http://www.peekarica.com/steampedia/index.php?title=RMS_Netherlandic
                                    Waves
                                    Supreme line
                                      Plastic.Spaceman
                                      Hi All
                                      My name is George, and I am from Melbourne, Australia. I am new to Sketchup and 3D modelling. I have dabbled in the program a few times, but I am keen to learn more, and create some more 3D models. Mainly for my wargaming hobby. I want to build various items in the 28mm (1:56) scale area, which may or may not end up being printed.
                                      I look forward to learning a whole lot more about sketchup, as well as being active on these forums.
                                      See you around the forums.
                                      • mitcorbM Offline
                                        mitcorb
                                        Welcome, George:
                                        Enjoy your adventure.
                                        • X Offline
                                          xphatjunkie
                                          Hello there newbie here,
                                          Im an assistant Landscape Designer working in Hong Kong, nationality from Indonesia...
                                          please kindly advice from the SU master here, anyway is there any forum in here that provides for landscape architect forum related with SketchUp tools?
                                          regards
                                          rocks
                                          a Landscape Architect. Born in Indonesia. Live in Hong Kong
                                            Marcos989
                                            Hello!
                                            I am a greenhorn to SketchUp. I have re-trained recently at my advanced age of 55 and am now a underwater inspector, required to produce drawings of inspected components, so I need to get going with this software.
                                            I do have one question now....the plugin for engineers (3skeng) costs quite a bit and I see nothing else that is free. Most of my drawing is oil platforms, piping, valves ect....from the very little I have seen so far there is not much of this in the warehouse.
                                            Any recommendations?
                                            Likely, I need to just spend time, read, explore and be patient but thought I would ask now.
                                            I was introduced to this prgrm via an engineer on the last job and he made no bones about it that I need to learn this now and quickly. So I am just trying to watch the available video tutorials some what in order. So far they all deal with architectural items.....no engineering ....yet.
                                            Anyway, hello folks... 👍
                                            • 72
                                            • 73
                                            • 8 / 73
