    [Plugin] CleanUp
    974 Posts 217 Posters 788.7k Views 217 Watching
      I'm seeing the issue. And I found the bug.
      I'm also seeing a new bug where the settings is not remembered between sessions...
        Version 3.1.7
        • Fixed a bug where materials with different texture but identical colour merged.
        • Update to TT_Lib 2.5.8 required!
          Pherim
          That was fast! Thank you, now it works!
          • I Offline
            ideas_arte
            Thank you very much!
              Version 3.1.8
              Fixed a bug that could occur for users with SketchUp older than version 8.
              • dereiD Offline
                derei
                Feature suggestion: instead of those preset cleaning options (Erase hidden geometry, stray edges, geometry on layer 0, and so on), it would be nicer to have the possibility to save customized presets from Clean webdialog. Maybe a field for preset name, then save.
                Thank you
                  AcesHigh
                  why arent these coplanar faces (from two different GoogleEarth imported meshes) merged?
                  http://img6.imageshack.us/img6/8480/coplanarfaces.jpg
                  in this thread, I first tried to use the 2D Boolean plugin. To no use, as we can see here. There are still plenty of coplanar faces where the GoogleEarth imported meshes overlap.
                  http://img266.imageshack.us/img266/5064/coplanarfaces2.jpg
                    Can you post the model?
                    Also, what are your settings? Remember that CleanUp has options to take into account face normals, material and UV mapping when merging.
                    Also, that image seem to illustrate faces occupying the same plane...?
                      AcesHigh
                      no need to upload the model. It happens with any model, when importing several GoogleEarth meshes which overlap.
                        Well, I don't see the behaviour, so if I am to check this out I need something to work with.
                        And these meshes, do you merge them into one group?
                          AcesHigh
                          sorry ThomThom, it had happened in every experiment I did before, so I wrongly assumed it would happen in every one. But I did one try with two small pieces and nothing happened (although there were some lost textures in the process)
                          So I will upload a SKP file. Thanks for the patience and hard work.
                          yup. Merge them into one group, then explode the meshes inside the group. Then CleanUp them. In the file I am sending you, not only some faces were lost when using CleanUp, as some coplanar faces were not merged, so you can see some texture flickering when rotating around.
                          experimento2.skp
                              That model is after CleanUp is run? You got the original?
                                AcesHigh
                                what settings ThomThom? The ones from CleanUp³?
                                everything selected except Geometry to Layer 0, Merge Identical Materials (its two different materials, a bitmap for each imported mesh), so I saw no reason to use it) and Erase Stray Edges.
                                sorry, I didnt keep the original imported meshes. But I will try again with new imported meshes.
                                  Looking at the one you sent, I selected everything and intersected it with itself a few times. CleanUp doesn't clean up faces that partially overlaps. Only faces that fully cover the exact same space as another. After intersecting and then cleaning there was no overlapping.
                                    AcesHigh
                                    here... I copied the two meshes and joined them in a group, exploded them, and used Cleanup. No lost triangles this time, but there are plenty of overlapping triangles. (sometimes they dont appear when viewing in the textured mode, but when you used SHADED mode you will see the overlapping triangles...)
                                    of course, the problem gets worse when you have to import even more mesh pieces, as sometimes you have over 3 meshes overlapping.
                                    experimento3.skp
                                      AcesHigh
                                      I will try that, thanks... however... how can I intersect if they are not solids?
                                      ps: I am trying to solve, with CleanUp, about the same problem that made me ask for the "GoogleEarth Meshes boolean subtract" plugin at the topic http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
                                        Not intersecting with Solid Tools, but the regular intersect that's been in SU since, ever..? From the context menu, there is Intersect Faces menu item.
                                          AcesHigh
                                          since ever, but I had never seen or used it before 😆
                                          anyway, however, intersected it with itself several times, and when I used cleanup³, several triangles were lost, and got some error messages 😢
                                            What where the error message?
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 48
                                            • 49
                                            • 36 / 49
