    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      Pherim
      When I use this plugin in the newest version, it merges materials with the same color attributes, even though they use different images. I am pretty sure that did not happen before, as I just recently discovered this great plugin. How does it compare the materials and decide which ones can be merged?
      Also, I do not fully understand every function of it. What does "Remove Edge Materials" do? It has no tooltip which explains its function.
        You mean it differs since what version? I did not change anything to the code doing the cleaning between 3.1.4 and 3.1.6.
        Do you have a sample model?
        It removes the material from the edges.
          Pherim
          I believe I first used version 3.1.4, and it did not happen with this version, as far as I remember. I have attached a small model which contains four materials that merge into two when I use Cleanup.
          cleanup_test.skp
          Hm, I do not consider myself a sketchup beginner, but I was not aware that edges can have a material. What is this good for?
            Well there is absolutely no change in the last three versions that should affect that. But I'll have a look.
            I for one use it when I have imported Cad plans to colour code various layers etc. But you have to set the current Style to use the edge materials, as the default is to use black.
              I'm seeing the issue. And I found the bug.
              I'm also seeing a new bug where the settings is not remembered between sessions...
                Version 3.1.7
                • Fixed a bug where materials with different texture but identical colour merged.
                • Update to TT_Lib 2.5.8 required!
                  Pherim
                  That was fast! Thank you, now it works!
                  • I Offline
                    ideas_arte
                    Thank you very much!
                      Version 3.1.8
                      Fixed a bug that could occur for users with SketchUp older than version 8.
                      • dereiD Offline
                        derei
                        Feature suggestion: instead of those preset cleaning options (Erase hidden geometry, stray edges, geometry on layer 0, and so on), it would be nicer to have the possibility to save customized presets from Clean webdialog. Maybe a field for preset name, then save.
                        Thank you
                        DESIGNER AND ARTIST DEREI.UK
                          AcesHigh
                          why arent these coplanar faces (from two different GoogleEarth imported meshes) merged?
                          http://img6.imageshack.us/img6/8480/coplanarfaces.jpg
                          in this thread, I first tried to use the 2D Boolean plugin. To no use, as we can see here. There are still plenty of coplanar faces where the GoogleEarth imported meshes overlap.
                          http://img266.imageshack.us/img266/5064/coplanarfaces2.jpg
                            Can you post the model?
                            Also, what are your settings? Remember that CleanUp has options to take into account face normals, material and UV mapping when merging.
                            Also, that image seem to illustrate faces occupying the same plane...?
                              AcesHigh
                              no need to upload the model. It happens with any model, when importing several GoogleEarth meshes which overlap.
                                Well, I don't see the behaviour, so if I am to check this out I need something to work with.
                                And these meshes, do you merge them into one group?
                                  AcesHigh
                                  sorry ThomThom, it had happened in every experiment I did before, so I wrongly assumed it would happen in every one. But I did one try with two small pieces and nothing happened (although there were some lost textures in the process)
                                  So I will upload a SKP file. Thanks for the patience and hard work.
                                  yup. Merge them into one group, then explode the meshes inside the group. Then CleanUp them. In the file I am sending you, not only some faces were lost when using CleanUp, as some coplanar faces were not merged, so you can see some texture flickering when rotating around.
                                  experimento2.skp
                                      That model is after CleanUp is run? You got the original?
                                        AcesHigh
                                        what settings ThomThom? The ones from CleanUp³?
                                        everything selected except Geometry to Layer 0, Merge Identical Materials (its two different materials, a bitmap for each imported mesh), so I saw no reason to use it) and Erase Stray Edges.
                                        sorry, I didnt keep the original imported meshes. But I will try again with new imported meshes.
                                          Looking at the one you sent, I selected everything and intersected it with itself a few times. CleanUp doesn't clean up faces that partially overlaps. Only faces that fully cover the exact same space as another. After intersecting and then cleaning there was no overlapping.
                                            AcesHigh
                                            here... I copied the two meshes and joined them in a group, exploded them, and used Cleanup. No lost triangles this time, but there are plenty of overlapping triangles. (sometimes they dont appear when viewing in the textured mode, but when you used SHADED mode you will see the overlapping triangles...)
                                            of course, the problem gets worse when you have to import even more mesh pieces, as sometimes you have over 3 meshes overlapping.
                                            experimento3.skp
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 48
                                            • 49
                                            • 23 / 49
