    Bulge flat face
    4 Posts 3 Posters 2.8k Views 3 Watching
    • O Offline
      oslocadiz
      I was wondering if someone had a tip how to bulge a face to make a bump/ rounded surface? It doesn't have to be a regular shape. (See jpg.)
      Many thanks for your help!
      fevik 3d.skp
      • Chris FullmerC Offline
        I like the Soap Skin Bubble plugin, though I always forget how to use it.
        Also, you could use the sandbox tools. They com standard with SketchUp since version 5. Draw a "from scratch" grid. Then intersect the grid onto your planter area. Then use the smoove tool to make a mound. you have to be careful though as the smoove tool will lift the edges off the ground surface, which is rarely desirable.
        • TIGT Online
          Capture.PNG here I drew some vertical arcs from end/mid-points to outline the 'bulge'...
          • O Offline
            oslocadiz
            Perfect! Thank you guys again for the help.
