    Material Testing Model
    renderpluginsextensions
    21 Posts 9 Posters 3.6k Views 9 Watching
    • V Offline
      valerostudio
      Does anyone have a SKP file of a material testing model, like the one you see on the vray forums all the time?
      • numbthumbN Offline
        numbthumb
        Does it need to look the same? Keyshot material ball can be found here: http://grabcad.com/library/keyshot-material-ball
        Now as for importing SolidWorks file into SU, you could try MoI: http://forums.sketchucation.com/viewtopic.php?f=80&t=12384
        Don't know if it's worth the hassle, but if youΒ΄re not going to model it yourself ... πŸ˜„
        Comfortably numb...
        • V Offline
          valerostudio
          Doesnt need to look the same but I am shocked no one has made one in SU.
          • dereiD Offline
            derei
            What for? πŸ˜„ SU provides thumbnails for materials, it doesn't render... and uv mapping in SU almost doesn't exist. Why should one need it?
            But, if you need one, is not hard at all to make. In fact, I could make it for you, just tell me how do you want it to look like πŸ˜‰
              rspierenburg
              Personally I think the Test balls are almost useless for Architectural materials. None of the balls I've seen incorporate any flat faces (all seem to be nice and ball shaped πŸ˜‰ ) and most architectural materials end up of flat faces (brick, metal panel, wood, etc) and so doesn't represent well on a round object. Just my 2cents.
              Rob
              • soloS Offline
                I agree.
                That's why in the licensed user materials forum they use different ways for different materials, like this way for flooring:
                • V Offline
                  valerostudio
                  The test ball is a standard to get a sense of how a material will render. I agree that they aren't great for arch materials, but the test ball has been a standard because it lets you see the material in a variety of situations. Maybe we create our own? I will mock one up and you guys give a try if you want also. Our goal here is to make a material testing object that is best suited for architectural materials.
                  • broomstickB Offline
                    broomstick
                    It could be interesting.. Also lets try and see what happens on the top of curved walls
                    Like so:
                    http://www.cavegontero.com/public/images/catalogo/18_9_2010_21_16_43_cordoli6th.jpg
                    • V Offline
                      valerostudio
                      Sorry for the delay on this, but here is my first shot at it.
                        rspierenburg
                        I really like that test model. Any chance you can post the .skp for it?
                        • V Offline
                          valerostudio
                          Looks like Alan modeled one in the traditional format for those of you with a FormFonts sub. http://www.formfonts.com/viewModel.php?view=1&id=16039&config=1
                          • V Offline
                            valerostudio
                            In case anyone wants to play with the model I put together.
                            Material Test Studio.skp
                              alcohorse
                              Great Test model!
                              Right down to the impression of the logo πŸ‘ This is gonna make me sound very stupid, but how did you do that bit? Did you draw over an image of the logo in su?
                              • N Offline
                                nomeradona
                                thanks will be one of the guys who will play it now..
                                • V Offline
                                  valerostudio
                                  @alcohorse said:
                                  Great Test model!
                                  You can trace it or you if hate tracing (like me) you can import the image into Illustrator, convert to vector using Live Trace, export to DWG and it should make a face in SU (hopefully).
                                  • N Offline
                                    nomeradona
                                    I dont know if I push the playing for this model too much... http://sketchupvraymaterials.blogspot.com/
                                    • V Offline
                                      valerostudio
                                      Fantastic! This looks like the makings of a great vismat site!!!
                                      • N Offline
                                        nomeradona
                                        i dont know where this will go, but so many interest, lots are wanting to pitch in on which im happy. we would like to retain the valero studio πŸ˜„. I hope there will be a script that automates the process of applying the material to the model. and you dont do it manually.
                                        • V Offline
                                          valerostudio
                                          I appreciate the credit for the model. If it makes it cleaner, feel free to take it off the model. Kudos on the website is enough for me. Thanks.
                                          • chonC Offline
                                            chon
                                            Thanks a lot for that site Nomeradona ! πŸ‘ πŸ‘
