    Scale non-uniform along vector?
    22 Posts 4 Posters 3.2k Views 4 Watching
    • jolranJ
      jolran
      Hm no. Don't know what I was thinking... Back to square 1.. There are a lot of holes in my method needs filling in.
      Need at least to multiply with excisting transformation, as Chris has shown. Will have to take a better look at the second method he provided, or maybe Dan's suggestions if something better don't come up..
      Edited: I realize now, what I said about scaling along vector was a bit difficult to understand. I meant scaling along one of the local x,y,z axis IF any of them are perpendicular to the vector(edge).
      • jolranJ
        jolran
        Thanks Dan. Appreciate it.
        I have looked at the API. Can't get the comments working so I miss out a few "goodies" there I think..
        But as far as I have gotten, scaling Non-uniformly takes 4 arguments. Orgin, scale x, scale y, scale z.
        You second advice would have to be plan "B". I have thought of doing something like that, but I'll try to avoid it cause there is plenty of transformations done before the group is even on the face.
        I'm working on a method (Cris code gave me an idea)that might possibly work. Just need to retrieve the group local x,z,y axis? If I can.. This is what I have got so far. Could probably use a case method...
        You pass in the group, scaling, and vector. Where vector=(edge.start.vector_to(edge.end))
        def vec_scale(group, scaling, vector)
        			#vector need to be parallel or perpendicular or scaling wont work.
        			##TRANS- and Center####
        			gents=group.entities
        			bbox=group.bounds
        			bbox_c=bbox.center
        			group_x=group.transformation.xaxis
        			group_y=group.transformation.yaxis
        			group_z=group.transformation.zaxis
        			if group_x.perpendicular? vector
        				xscale = scaling
        			else
        				xscale = 1
        			if group_y.perpendicular? vector
        				yscale = scaling
        			else
        				xscale = 1
        			if group_z.perpendicular? vector
        				zscale = scaling
        			else
        				zscale = 1
        			t = Geom;;Transformation.scaling(bbox_c, xscale, yscale, zscale)
        			gents.transform_entities(t, gents.to_a)#Normaly you apply t to group. But I need to do it to entities.
        • Dan RathbunD
          Dan Rathbun
          You should know that IF the DynamicComponents extension is loaded, it adds some methods for ComponentInstance and Group instance objects.
          for Group and ComponentInstance:
          local_transformation() scaled_size() unscaled_size()
          for ComponentInstance ONLY:
          copy() # works like Group.copy()
          description()
          and for DC ComponentInstances ONLY:
          set_last_size(lenx,leny,lenz) last_scaling_factors()
          I'm not here much anymore.
          • jolranJ
            jolran
            Edit: Think the method works now 😍
            Not 100% tested in all angles yet. Changed my code in previous post.
            • jolranJ
              jolran
              Oops. Sorry Dan, must have typed while you post your message.
              Your info: Really? Did not have a clue about that. Thats is good news for further developpment. Thank you.
              • jolranJ
                jolran
                Ah typical 😞 . Too early to celebrate.. It doesent work of axis= face tilted.
                Get strange new error no implicit conversion to float from nil
                I guess group_x=group.transformation.xaxisis only gonna work if the group is aligned to global axis. Therefore when tilted it has nothing=nil??
                • Chris FullmerC
                  group.transformation.x_axis
                  is returning the vector of the component's local x axis. It should never return nil I don't think. I can't play with your code at the moment, but maybe later today I can test it out.
                  You should note that its possible/normal? for 2 vectors to perpendicular to the one you're testing against. So it will scale in 2 directions, not just one (I think).
                    gt=group.transformation og=gt.origin xa=gt.xaxis ya=gt.yaxis
                    [ za=face.normal
                    or za=xa.cross(ya)]
                    Use a rotation transformation about og and za by the angle_between xa and vector ?
                    Then do a scaling transformation along the xaxis only to match (vector.length / groupX.bounds.width) [where you have used add_instance on group.entities.parent [==definition] temporarily added to the face.parent.entities, at the origin with no further transformation as groupX ?]
                    Then invert the rotation transformation...
                    All done ?
                    • jolranJ
                      jolran
                      So it IS the local axis we are dealing with here. Since the scaling is only working on Global axis I persumed it wasen't. Thats good then(hopefully).
                      Uh oh 😲 That's NOT good! I will do some further testing to se if it fails.
                      Thanks for all your help.
                      • jolranJ
                        jolran
                        Hello TIG. I typed when your answer came in. Bad timing today πŸ˜„
                        Will try your code and report back. Looks interesting.
                        Thanks a million!!
                        • jolranJ
                          jolran
                          I'm not sure I quite understand where to use you code, TIG. When Importing the component definition?
                          That could be difficult in this case...
                          This particular tiling is in it's own method. In the plugin there are other "tiling" methods. So cannot do any altering to the component def. before calling the method of choice. Unless I rewrite the definition loader-method. Could be done of course..
                          In your code: vector.length / groupX.bounds.width. Is that to determine the scale?
                          The way this feature will work in the plugin, is that the USER determin number of rows, some code like: edge.length/numbers of rows to determin groupX.bounds.width.
                          So I'll add that part to your code-snippet?
                          Edited. Changed some info to clarify things, it's not good to write topics saturday nights πŸ˜„:
                          I think Chris was right about conflicts i vectors(Edge can be perpendicular to 2 axes of course).
                          So I've scrapped that code..
                          See if I can incorporate TIG's code, and see if it works. I think I get the idea of it.
                          • jolranJ
                            jolran
                            og=gt.origin
                            xa=gt.xaxis
                            ya=gt.yaxis
                            [za=face.normal
                            or za=xa.cross(ya)]
                            All done ?
                            Is it that this code is to be used when comp.definition( or group) is at Origin=flat on "ground"?
                            Cause I get some funky results.. Havent tried "hard" yet. Will elaborate more after lunch....
                            I've tried something like this where vector is edge:
                            			og=gt.origin
                            			xa=gt.xaxis
                            			ya=gt.yaxis
                            			za=@face.normal #@face=reference to the face.selection
                            			za=xa.cross(ya) #??
                            			x_to_vec=xa.angle_between vector
                            			tr1=Geom;;Transformation.rotation(og, za, x_to_vec)#req. rotation angle
                            			group.transform!(tr1)
                            			ts = Geom;;Transformation.scaling(og, scaling, 1, 1)
                            			group.transform!(ts)
                            			tr=tr1.invert!
                            			group.transform!(tr)
                            • jolranJ
                              jolran
                              BTW:
                              This special kind of tiling method will not take any rotation(angle) other than 90.degrees as an argument. The group(hatches) will always have to be perpendicular to the edge.
                                the group is from its untransformed bounds [from a temporary instance of it added to the face.parent.entities].
                                You know how long the 'edge' is [edge.length] so you can work out the ratio of the two values...
                                Now you can use that to scale the group.entities with a scaling-transformation along the xaxis only... and thereby the original group is scaled as needed.
                                Erase the temporary instance of the group to tidy up...
                                • jolranJ
                                  jolran
                                  Yeah, thanks TIG. All what you say is true.
                                  All these transformations got my head spinning. So I ditched the scaling in the tilingmethod. Went with scaling(y in this case) at ORIGIN, just after loading the component. Before placing it on the face. Not as flexible as in a method, but it will hopefully work. I think Dan suggested something similar, earlier on in this thread.
                                  Maybe that's what you had in mind all along as well, TIG. I just coulden't see it then..
                                  Edit: When I reread you thread, did you mean to scale entities and that would become a "local" scale? Cause i did some scaling in x or y and it was in fact a global scale. The group moved from the face and tilted, even when putting the origin at center of bbox. I can't recall 100% sure if it was the group OR the entities I scaled. Ah heck. I'll try tomorrow then.. Like I said, rather had this transformation separate in the tiling method..
