    Scale non-uniform along vector?
    22 Posts 4 Posters 3.0k Views 4 Watching
    • jolranJ
      jolran
      Oops. Sorry Dan, must have typed while you post your message.
      Your info: Really? Did not have a clue about that. Thats is good news for further developpment. Thank you.
      • jolranJ
        jolran
        Ah typical 😞 . Too early to celebrate.. It doesent work of axis= face tilted.
        Get strange new error no implicit conversion to float from nil
        I guess group_x=group.transformation.xaxisis only gonna work if the group is aligned to global axis. Therefore when tilted it has nothing=nil??
        • Chris FullmerC
          group.transformation.x_axis
          is returning the vector of the component's local x axis. It should never return nil I don't think. I can't play with your code at the moment, but maybe later today I can test it out.
          You should note that its possible/normal? for 2 vectors to perpendicular to the one you're testing against. So it will scale in 2 directions, not just one (I think).
            gt=group.transformation og=gt.origin xa=gt.xaxis ya=gt.yaxis
            [ za=face.normal
            or za=xa.cross(ya)]
            Use a rotation transformation about og and za by the angle_between xa and vector ?
            Then do a scaling transformation along the xaxis only to match (vector.length / groupX.bounds.width) [where you have used add_instance on group.entities.parent [==definition] temporarily added to the face.parent.entities, at the origin with no further transformation as groupX ?]
            Then invert the rotation transformation...
            All done ?
            • jolranJ
              jolran
              So it IS the local axis we are dealing with here. Since the scaling is only working on Global axis I persumed it wasen't. Thats good then(hopefully).
              Uh oh 😲 That's NOT good! I will do some further testing to se if it fails.
              Thanks for all your help.
              • jolranJ
                jolran
                Hello TIG. I typed when your answer came in. Bad timing today πŸ˜„
                Will try your code and report back. Looks interesting.
                Thanks a million!!
                • jolranJ
                  jolran
                  I'm not sure I quite understand where to use you code, TIG. When Importing the component definition?
                  That could be difficult in this case...
                  This particular tiling is in it's own method. In the plugin there are other "tiling" methods. So cannot do any altering to the component def. before calling the method of choice. Unless I rewrite the definition loader-method. Could be done of course..
                  In your code: vector.length / groupX.bounds.width. Is that to determine the scale?
                  The way this feature will work in the plugin, is that the USER determin number of rows, some code like: edge.length/numbers of rows to determin groupX.bounds.width.
                  So I'll add that part to your code-snippet?
                  Edited. Changed some info to clarify things, it's not good to write topics saturday nights πŸ˜„:
                  I think Chris was right about conflicts i vectors(Edge can be perpendicular to 2 axes of course).
                  So I've scrapped that code..
                  See if I can incorporate TIG's code, and see if it works. I think I get the idea of it.
                  • jolranJ
                    jolran
                    og=gt.origin
                    xa=gt.xaxis
                    ya=gt.yaxis
                    [za=face.normal
                    or za=xa.cross(ya)]
                    All done ?
                    Is it that this code is to be used when comp.definition( or group) is at Origin=flat on "ground"?
                    Cause I get some funky results.. Havent tried "hard" yet. Will elaborate more after lunch....
                    I've tried something like this where vector is edge:
                    			og=gt.origin
                    			xa=gt.xaxis
                    			ya=gt.yaxis
                    			za=@face.normal #@face=reference to the face.selection
                    			za=xa.cross(ya) #??
                    			x_to_vec=xa.angle_between vector
                    			tr1=Geom;;Transformation.rotation(og, za, x_to_vec)#req. rotation angle
                    			group.transform!(tr1)
                    			ts = Geom;;Transformation.scaling(og, scaling, 1, 1)
                    			group.transform!(ts)
                    			tr=tr1.invert!
                    			group.transform!(tr)
                    • jolranJ
                      jolran
                      BTW:
                      This special kind of tiling method will not take any rotation(angle) other than 90.degrees as an argument. The group(hatches) will always have to be perpendicular to the edge.
                        the group is from its untransformed bounds [from a temporary instance of it added to the face.parent.entities].
                        You know how long the 'edge' is [edge.length] so you can work out the ratio of the two values...
                        Now you can use that to scale the group.entities with a scaling-transformation along the xaxis only... and thereby the original group is scaled as needed.
                        Erase the temporary instance of the group to tidy up...
                        • jolranJ
                          jolran
                          Yeah, thanks TIG. All what you say is true.
                          All these transformations got my head spinning. So I ditched the scaling in the tilingmethod. Went with scaling(y in this case) at ORIGIN, just after loading the component. Before placing it on the face. Not as flexible as in a method, but it will hopefully work. I think Dan suggested something similar, earlier on in this thread.
                          Maybe that's what you had in mind all along as well, TIG. I just coulden't see it then..
                          Edit: When I reread you thread, did you mean to scale entities and that would become a "local" scale? Cause i did some scaling in x or y and it was in fact a global scale. The group moved from the face and tilted, even when putting the origin at center of bbox. I can't recall 100% sure if it was the group OR the entities I scaled. Ah heck. I'll try tomorrow then.. Like I said, rather had this transformation separate in the tiling method..
                          • 2 / 2
