    1.3k Posts 300 Posters 3.2m Views 298 Watching
    • dereiD
      derei
      One question, this version doesn't use anymore ZLoader__Curviloft.rb file? I downloaded it and I found just the directory inside.
      Thank you.
      DESIGNER AND ARTIST DEREI.UK
      • fredo6F
        Thank you.
        With LibFredo6 v4.0 and above, the ZLoader__xxx files are no longer used.
        You can purge them by using the menu Windows > LibFredo6 Settings... > Purge Obsolete Files
        • dereiD
          derei
          thanks, I did it!
          • I
            ivreich
            Hi Fredo
            I'm not sure if this question has been answered before, but is there a way to ensure all segments in a loft have the same number of columns of quads and that all the junction curves meet up? I have played around with all the various lofting options with no success.
            For example, in this image below all three profile curves have 30 segments but the resulting mesh has disjointed junction curves, making it hard to use thomthom's loop/ring selection tools properly. Also, some of the quads seem to be merged into a single long surface?
            Cheers,
            Joel
            All 3 profiles curves have 30 segments but junction curves do not match up
            • fredo6F
              Joel,
              Sections are computed idependently for the vertex matching, so if contours are very different, you may end up with the situation you describe.
              So far, the only possibility is to use the Global F-spline options. It draws a mesh between the first and last contours trying to be as close as posible to the intermediate contours (but not matching their vertex).
              This method is the first one of the group of two icons at the right of the Junction methods section in the palette.
              Thanks to tell me if this option is useful (I included it just in case....)
              • I
                ivreich
                Hi Fredo
                Thanks for your reply. yes i did try the global F-spline options and these are the only options which work. They are definitely very useful; thanks for including them!
                What I don't understand however is that the 3 profile curves shown in my example are very similar: they are actually three copies of the same uniform b-spline with slight adjustments to each. They have exactly same number of segments and the segments are all aligned approximately above each other, So I'm not sure why curviloft creates extra intermediate junction curves in some places?
                Is it possible for Curviloft to gauge when all the profile curves have the same number of segments and do direct vertex matching without the extra junction curves? The reason being that the most logical way/neatest way of doing a loft is to use Bezierspline to give each of the profile curves the same number of segments before lofting.
                Also, any idea about the second issue? the one where the quads are all merged into a single long face? Sorry if I'm a bit long winded, but I'm just very excited about the integration between Curviloft and Quad face tools...
                Cheers,
                Joel
                • fredo6F
                  Could you post the model so that I have a closer look
                  • jgbJ
                    jgb
                    Joel
                    I too have noticed (and remarked about a long time ago) CL's penchant for adding multiple vertexes where none should be logical.
                    CL does a fantastic job of lofting, but often adds a lot of unnecessary lines that I spend a lot of time simplifying by simply deleting the redundant lines and triangulating the quad face. It is rarely a logical midpoint on a straight-line split, they seem to me to be almost random in generation, both position and number.
                    I haven't tried the new version yet, and I won't have time for a while, as I only get less than an hour on the PC a day due to a temp. 12 hour a day job.
                    jgb
                    • I
                      ivreich
                      Hi Fredo
                      I've attached a model showing the problems I described. I've showed the exact steps i took and colour coded/labelled the problematic areas.
                      Thanks so much for looking into this!
                      Cheers,
                      Joel
                      Model Screenshot
                      CL Test Model
                        Have you same result when you scale the B Splines *100 ?
                        • fredo6F
                          Joel,
                          I had a look and there is definitely a problem in the vertex matching. Actually, even if the number of vertices are the same, thereare some which are very close and unequally spaced. This create issues with the current matching algorithm which still needs to be improved in case there is no 'sharp' edges to be used as a reference start point.
                          In addition, the problem of vertex matching makes the Global F-Spline method not really work. But I knew I had problem on this one.
                          I am afraid that this cannot be fixed instantly. What I suggest is that you play with the vertex matchning by dragging the junction curves and eliminating the auto-pairs.
                          • I
                            ivreich
                            Thanks for looking into it anyway Fredo. I guess this issue of vertex matching becomes very important now that there is a lot of buzz going on around thomthom's quad face tools which require a regular set-out of quad faces in order to properly utilise features such as loop and ring select etc.
                            My dream is that one day this kind of quad-based system will lead to a free-form paneliser tool for SU. I posted a topic on it here:
                            404 Not Found
                            (forums.sketchucation.com)
                            It has huge architectural implications for architects like me who use SU heavily as a design tool. Not many people seem to be interested in it though...which is rather strange.
                            Cheers,
                            Joel
                            • K
                              konara
                              thanks freddo ...!!unbeleivable..
                                Mcgee2005
                                Hello everyone! I'm newbie to this community so I just wanted to thank you for sharing this wonderful information in this thread, it really helped me a lot!
                                • T
                                  taiyungokjoseph
                                  this is great
                                    I'm loving this tool Fredo! So quick to generate a nice clean mesh - and with the latest Quad option - working with it afterwards is such a joy!
                                    • fredo6F
                                      Glad to see that this is useful for real-world modelling.
                                      I have installed the Quadtools and start playing with it, trying to catch the essence of the tutorial videos. So far, I am still struggling to understand how to do a simple application of an image texture on a shape, but I will try again.
                                        I got on my todo list to make some more tutorials.
                                        I also need to update QuadFace Tools to give proper feedback to the user when the shape can't be mapped to a 2D grid. Please post back with the things you find troublesome - with sample models would be great.
                                        • L
                                          lauris.gouiran
                                          Bonjour
                                          est ce que Curviloft marche sous Sketchup8 (mac)?
                                          Merci
                                          Hello,
                                          does Curviloft work under Sketchup8 for mac?
                                          Thank you
                                          • fredo6F
                                            @lauris.gouiran said:
                                            Hello,
                                            Yes it does
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 65
                                            • 66
                                            • 28 / 66
