    Please, help! Need to made 3D from huge DWG Contour file...
    29 Posts 7 Posters 6.7k Views 7 Watching
    • charly2008C Offline
      charly2008
      Hi AcesHigh,
      I'm not a CAD specialist. Do you know the software which were created these drawings with? If yes, is there a digital terrain model stored? If you import these drawings into Autocad You have also only 2D drawings.
      Have a look here: http://diolkos3d.com/index.htm
      Charly
        You have lots and lots of redundant information in the CAD file.
        AND unfortunately it's all 2D !
        You do have contours but again these are all drawn 'flat'.
        Perhaps if you edited the CAD file and kept just the contours, long sections and road curbs etc... and gave 'elevation' [height] to the contours then maybe you could import that reduced set of info into a SKP and use the Sandbox tools to convert From Contours into a mesh... Then add faces to the 2D road plans and Sandbox Drape them over the land surface ?
          charly2008
          What is "TIG" says is true. You'd have every height measurement point from the graph, set with the contour lines and the road in relation to it and construct the terrain. But that would be a hard work.
            AcesHigh
            yes, I know 😞
            ok, in theory you can do that directly from Sketchup, cant you? But I guess selecting the lines and cleaning the file on Sketchup would be harder...
            yes, but how to pull up the curbs? And how to make the road flat??
            As far as I understand, if I drape the road plan over the mesh, it will only crate "cut lines" over the mesh. But it will still follow all the mesh contours.
              No, you won't drape but stamp (and do not forget JointPushPull either). Just get the mesh in (in 3D) somehow and the road lines and we can go on from there.
                AcesHigh
                hmmm, ok, but doesnt the stamp creates a TOTALLY flat surface on the mesh?
                I mean... if I stamp the flat road plan on the mesh, how to make the road go up and down later?
                http://img202.imageshack.us/img202/1534/sketchupdrape.jpg
                  With a little bit of manual work and the Follow me and keep plugin, you can easily create a road whose surface is horizontal sideways and even has a side walk with curb.
                  FollowMeAndKeep.skp
                    charly2008
                    Road design is a technique that had interested me for a long time. In SketchUp, it is very difficult to construct a natural-looking street in an uneven terrain. The best tool I've ever seen for Sketchup till now is the Valiarchitects instant road plugin.
                    I've experimented with many programs, including GeoControl 2 and Diolkos Road Design (Prof. 3D CAD software).
                    Have a look at this topics: http://forums.sketchucation.com/viewtopic.php?f=18&t=19578&hilit=Road+design
                    http://forums.sketchucation.com/viewtopic.php?f=15&t=20053&hilit=Road+design&start=15
                    http://forums.sketchucation.com/viewtopic.php?f=81&t=29988&p=264804&hilit=Road+design#p264804
                    For the development of a road in the terrain you need the actual height measurement points, and many other data. The program then calculates a DTM with the road. The results look like in your DXF file (without DTM). The area with the road can then be exported as 3D DXF file. But such programs are hard to master for us laymen.
                    Charly
                      Yes, I also remember Charly's experiments. And true that you will be unlikely to get a perfect solution but at least something. After all, this is probably not going to be the full construction drawing but "only" some 3D visualization of the idea.
                        charly2008
                        I've once again seen the Diolkos software. There is no way to export a DXF. You can export the project into three different ASCII formats (see screen shot below). Is there a way to convert them so they can be imported into SketchUp?
                        Charly
                          AcesHigh
                          oh god damn... I just finished making the 3D Terrain (without roads yet). I only used the main contours (each 5 meters). Even so it was already a lot of work.
                          But to my surprise, when I created the mesh, some areas of the terrain have some severe problems, with faces appearing and disappearing when I rotate the mesh, or get close.
                          I went back some steps to when there were only lines in the model, and noticed that SOME LINES, when I get closer, also display strange behavior. In fact, some lines, when I get close and rotate around, make the whole screen "shake". Its very weird, but I had already noticed the same thing on some 3D models I once imported from autocad DWG file...
                            The disappearing bits are 'clipping' caused by geometry being far away from the origin, if you import CAD data with the 'preserve origin' ticked the imported geometry can be hundreds of kms away from the SKP's origin and cause the issue described. If the option is unticked the geometry arrives near the origin. If you are doing several 'connected' imports you have to keep the CAD origin so they will arrive aligned - however later you should Move everything nearer to the origin. Ensure everything is visible and not locked, select all and then Move picking a point near the geometry an typing [0,0,0] - or perhaps [0;0;0] if your locale uses ',' as a decimal separator!.
                            Also sometimes imported CAD blocks become components with origins [axes] miles away from the component's geometry which also has this affect - you can reset a component's axes by right-click context menu over it and selecting 'Change Axes'...
                              sketchymick
                              Hi Gaieus,
                              I've got the plugin, read the associated thread and tried it out on the model you posted here, but I just can't seem to replicate your results (with the cut and fill batters). Any chance you could annotate your example with a few tips? I have a relatively simple road that I want to cut down through some terrain.
                              • Mick
                              "I love the sound that deadlines make as they rush past"
                                Can you post the terrain and the road cross section?
                                  sketchymick
                                  Hi Gaieus,
                                  The actual file is too big, but I snipped a bit off the surface I'm working on. Haven't actually got the real road section or path yet, so I just made one up. Hopefully the file is self explanatory. I just want to create a road along the path, drop it into the topography, adjust the height and add cut/fill batters along the side of the road.
                                  If this file is too much to work with, the actual file I was was referring to in my post was the one you posted earlier in this topic.
                                  thanks for looking at it
                                  • Mick
                                  road example.skp
                                  • brookefoxB Offline
                                    brookefox
                                    I'm hoping to learn something here as well. Once what's his name ☀ has the road as he does in the model all he has to do is stamp the terrain with it. Looks like he starts with the path on the terrain, could be even by tools on surface, then he copies it up and makes his flat road with a profile and follow me keep, then he stamps the terrain below with the desired offsets to make the cut and fills.
                                    I'm going to try this on the road I'm working on.
                                    ~ Brooke
                                      sketchymick
                                      I know this thread is old, but I also get this symptom if I have a dialog box open (e.g. Layers) on the same screen. If I close the box, then I don't get the shakes. I figured it was video card problem, as I wouldn't have this problem on a different computer with the same file. Cheers - Mick
                                        sketchymick
                                        OK, I figured it out. I guess this is why it's called the newbie forum! For some reason I thought the follow me and keep tool was doing the cutting into the surface. Now I realise that it is a combination of the sandbox tools "drape" (to find the vertical variation in the road path and "stamp" to cut into the surface (setting an appropriate offset for the batters), it was relatively straight forward. Cheers - Mick
                                          brookefox
                                          You can use drape, but I think if you draw a centerline on the surface itself, you do not need it as it follows the terrain already. And if you drape the road itself it will slope like you were trying to avoid.
                                          ~ Brooke
                                            sketchymick
                                            Very true... what I did was to draw a centreline on an XY plane, using the contour lines as reference, so that the road generally followed the contours, but also had the right curvature, etc. in plan view then I draped this onto the landform to pickup the elevations. Then picked up the line again, simplified this line to remove excess vertices, dips and bumps before finally doing the follow me and keep road which I then stamped onto the surface.
                                            I'd appreciate any feedback if there's a better way to do this.
                                            Cheers
                                            • Mick
                                            road example.skp
