    How to use this type of data
    32 Posts 5 Posters 4.9k Views 5 Watching
      sepo
      Here is how it looks like.
        πŸ‘Š Imported points data using delauney methods will 'melt' vertical objects as it needs to triangulate facets... some of which won't be what you'll expect.
        If you can filter out the buildings in CAD and then export the 'site' mesh points that gives better results... πŸ˜•
          sepo
          Is there other method of triangulating which would be better for buildings.... as I am after buildings really?
            sepo
            I managed to do it but using SU8 on the Mac side. SU7 has no such problem on Vista. Kind of interesting.
            It took nearly 3 hours and SU did not go non-responsive in both instances. Coffee was good and cake very moist.
            The mesh turn out in not very usable state as buildings look like they are melting....maybe good for some Sci-Fi environment.....this Lidar data is kind of disappointing.
            The file had 40406 points ... It created 80000 triangles.
              Not that I know of - the problem is working out which points make a facet.
              IF the points are in a file and they are always arranged in sets so that they define a triangular face - like in many OBJ files - then it's much easier to replicate those facets in a SKP...
              Unfortunately, the DXF data gets muddled once it's imported.
              Are there any other file formats like csv/tsv/txt you can get the points data in?
              These could be read into a SKP much more readily that a DXF... πŸ˜•
                sepo
                I see....I need to check if there are any other file types available.
                  sepo
                  Hmmm... It does not appear to be available. I was wondering if maybe this is all driven for Autodesk Map
                  • N
                    notareal
                    You could try meshlab http://www.meshlab.org/ http://meshlabstuff.blogspot.com/
                      sepo
                      Thanks Notareal but as far as I know Meshlab does not import .dxf/dwg.
                      • Chris FullmerC
                        What does it export? If it will take any other sort of standard file type - csv, obj, anything?, maybe we can write an exporter for it.
                        • N
                          notareal
                          You don't get the LiDAR data in any other format? That unfortunate as meshlab is indeed a very good program to handle point clouds.
                          Meshlab
                          import:PLY, STL, OFF, OBJ, 3DS, COLLADA, PTX, V3D, PTS, APTS, XYZ, GTS, TRI, ASC, X3D, X3DV, VRML, ALN
                          export:PLY, STL, OFF, OBJ, 3DS, COLLADA, VRML, DXF, GTS, U3D, IDTF, X3D
                          Point Clouds support. Now 3D files that are composed only by points are well supported in PLY and OBJ format.
                          • Chris FullmerC
                            Collada is essentialy an xml file - just plain text. It would be relatively easy to export a collada file with the point could data, if it was known what collada elements they need. SketchUp might even be able to do it natively with their collada exporter.
                              sepo
                              I supose I could export .dxf to collada and try it that way....
                                sepo
                                This is website I wanted to get Lidar data from .... http://www.stanfords.co.uk/Business-Mapping/BM/Products/LiDAR_BM-LIDAR.htm
                                  Any text format file [even DXF] can be parsed and the points extracted in order.
                                  If we know that that say every three of them make a triangular facet we can use that to add geometry.
                                  It'd be a pain in the proverbial to parse a DXF file [it can be done! e.g. I extract 'text' in my dxf-text-importer tool] but other types like OBJ, CSV etc can be readily parsed and used... [DAE doesn't seem to support raw 'points', just facets]
                                  πŸ˜•
                                    Roger
                                    Sepo, I have not used it yet but I have installed the tgi3d plugin. I suspect it would handle the stereo pairs quite nicely. This is exactly what their PhotoScan product is supposed to do. Basically you take two or more photos of a surface or surfaces from widely separated areas. Then you mark corresponding points in the photo sets and the software uses these control points to reverse engineer the 3D shape of the surface.
                                    I have also figured out a LIDAR like system of establishing surface control points on small stationary object that does not have strong features to compare photographically. I will post my experiments as time allows. Will be heading to Thailand for a month so it might be a while before I can test the system.
                                    http://www.azcreative.com
                                      sepo
                                      That would be quite interesting. Have you actually tried PhotoScan with tgi3d? I was wondering which other software people would use to create models from 2 photos shot with time delay.
                                        sepo
                                        πŸ˜•
                                        OK so no joy there as well. 😞
                                          Roger
                                          Will jump on the learning curve today. And time delay is not strictly necessary if two or more synched cameras are used. I plan to try multiple linked cameras at 4,000th of a second to freeze an athlete in motion.
                                          • Chris FullmerC
                                            Seriously Roger, I'm going to down to AZ and follow you around for a few days. You always have some cool camera project cooking in the background.
                                            EDIT:
                                            ok, I imported the example dxf and see the point cloud. Very interesting. What are you expecting differently than you achieved previously? The triangulated TIN looks pretty good to me.
