    [Tutorial] Tufted Ottoman
    Scheduled Pinned Locked Moved Organic Modelling
    19 Posts 12 Posters 16.6k Views 12 Watching
      stereofidelic
      Bookmarked this page, and I will try to follow it this weekend.
      • ely862meE
        ely862me
        Take those lines out because they give a square result when subsmoothing .
        See what i mean.
        Elisei (sketchupper)
        Come and See EliseiDesign
          john.warburton
          Excellent tutorial - really useful, thank you.
          Life's a reach, and then you gybe.
          • GaieusG
            True. I will add it.
            Something I was wondering. Now that we have the organic modeling sub-forum, how do we decide where the tutorials actually go? If it is an Organic tutorial should it go here or in the SketchUp tutorial section. Hmmm
            Csaba?
            I dunno guys. Think about it - we can move these any time. Or if we move it (and make more), we can keep a list with links here. Maybe tag like [Tutorial organic] (we used to gad tuts with special names, too). Then we can somehow generate a search result page like the Plugin Index.
            Ah and before I forget; great tut! 👍
            • V
              Vicspa
              (Bookmarked) Thanks guys, I hope there are more tuts like this once SDS2 comes out.
              • boofredlayB
                boofredlay
                @ely862me said:
                Take those lines out because they give a square result when subsmoothing.
                Thanks for improving my knowledge. 👍
                • Bryan KB
                  Excellent tutorial(s).
                  I've also learned something new.
                    danielschultz
                    I've followed your tutorial, starting with a square. My result after subdivide and smooth "facets" the corners of the square as shown in the attached photo. Help please.example_small.jpg
                    • GaieusG
                      You need to use the crease tool on those edges before subdividing so that they remain intact after subdivision.
                      • boofredlayB
                        boofredlay
                        Well yes and no. In the original example I had that piece connected to many others to make the full ottoman cushion. Therefore you do not need to use the crease tool as it is all together. But if you are only doing one segment as you have shown Daniel then you need to crease the corners, not the edges.
                        • GaieusG
                          well, corners then, thanks Eric. point is that it keeps the thing.
                          • gudio83G
                            gudio83
                            i'm following the tutorial , but after 2 iterations my square is always in 2D. there is no a hole. What i get wrong?
                            • ely862meE
                              ely862me
                              Probably you don't have any "hole" in it .First you must create the "hole" then subdivide.
                              See what I mean .
                              2 by EliseiDesign.skp
                                mwm5053
                                Been having a HELL of a time with that crease tool till I saw this.
                                Thanks Eric
                                So what does creasing edges or quads do for it I don't see much difference when doing it that way.
                                2011 iMac
                                SU 2015 Pro, 2017 Make
                                V2 Twilight
                                macOS Sierra 10.12.5
                                • panixiaP
                                  panixia
                                  i did a slight variation to the proxy to obtain a quad-mesh most confortable for texture mapping, faster selections and further editing and it works fine for me.. hope it can help someone else for mapping leather, fabrics, etc. on it.
                                  quadface tools rocks!
                                  http://img337.imageshack.us/img337/8876/proxyquadrettoimbottito.jpg
                                  [xxl-img:2cc3ed4y]http://img705.imageshack.us/img705/4575/02cubettiimbottititest.jpg[/xxl-img:2cc3ed4y]
