    From SketchUp to Reality
    91 Posts 22 Posters 16.3k Views 22 Watching
    • daleD Offline
      dale
      So with the beam in place we are unloading the TJI floor joists in this photo. The LVL is a drop beam so that electrical and plumbing can run in the joist cavity. The TJI's are full span, as were the rim joists which the hang off of with joist hangers.
      Somehow Judy and I managed to manhandle these 34'(10.36 m)long beasts into place.Screen shot 2011-09-09 at 6.17.04 AM.png
      • daleD Offline
        dale
        Once again SketchUp to the rescue, as with a floor load that is that heavy, it is not easy to find a pre-made telepost that can stand that load.
        So I SketchUpped the post and emailed it to my structural engineer. He made a few changes to bolt hole locations, and we had a local fabricator build it.
          llaves
          Looks like this will be interesting to follow. Two comments, based on our experience:
          1. Gophers seem to love the styrofoam in the ICFs. Maybe the Resisto will keep them out, but I wish the product was available with a hardware cloth covering. If you haven't buried your footings, you could still cover the foam. On the other hand, you mention that you've used ICFs on 18 projects. Have gophers plagued the owners of these houses?
          2. If you're going to acid stain the floors, remember that everything that happens to the concrete between now and then will telegraph through the stain. Cover the floors, preferably with something like 1/8" masonite. If that's too expensive, a couple of layers of paper, and keep up with all the tears that will occur between now and staining.
          • daleD Offline
            dale
            This is interesting about gophers. There are no gophers to speak of in this area, so it is a problem I haven't had to deal with, but could be very important if you are in an area that does.
            And as for the floors, I couldn't agree more. We usually put down two layers of untreated building paper tuck taped at the seams,(tuck taped to each other, not the concrete as this will end up as stripes) and keep up with the tears.
            It doesn't matter how much you berate the tradesmen, caring for you floor just isn't a priority.
            • daleD Offline
              dale
              In the oddball things that happen on the jobsite department:
              We let the foundation reach a 7 day compressive strength, and did a bit of back filling to make it easier to get in to the building. The site is on an ancient creek bed, and has lots of very large rocks.
              The cat hit a large flat sloped rock, and side slipped down stopping with the blade about 1/2" from the styrofoam wall.Screen shot 2011-09-10 at 6.15.13 AM.png
              Our neighbour has a little excavator so we got him to come over and help extricate the cat avaoiding a "cat tastrophy"Screen shot 2011-09-10 at 6.15.29 AM.png
              Just before backfilling we discovered a nest of Juncos in the dirt bank of the excavation. We built the a little styrofoam nest, and a plywood condo, and hung it off the Quadlock wall just above where the nest had been in the bank. It took the adult birds a couple of hours, but they eventually found the nestlings, and stated feeding them until they fledged and flew.Screen shot 2011-09-10 at 6.17.33 AM.png
              • daleD Offline
                dale
                The floor is 11 7/8 TJI's, which as I mentioned we joist hung from the ledger LVLs spanning over top of the main beam. Then we put down a 3/4" (19mm) t&g subfloor and the second floor Quadlock walls up.Screen shot 2011-09-10 at 6.32.18 AM.pngScreen shot 2011-09-10 at 6.33.02 AM.png
                • daleD Offline
                  dale
                  But the nice thing about being able to model is that you can keep refining the design process as you do the grunt work. So, we were busy working out what the kitchen was going to be like.
                  and over to Thea for some visuals.Screen shot 2011-09-10 at 6.40.00 AM.pngScreen shot 2011-09-10 at 6.40.19 AM.png
                    bytor
                    Dale,
                    Following this great thread as it is very interesting and informative. My favorite part is the two pictures of the Juncos! Most would not bother, but you chose to be a steward of your environment and friend of nature. Great to see this! 👍
                    Dean
                    Find the Cost of Freedom.....
                      llaves
                      Dale:
                      In one of your early posts you mention that the ICFs are 4" of foam on one side, 2" on the other, which would give a reasonably insulated wall. (My pet peeve is the extremism of some folks in massively insulating walls/roofs, where they have long reached the point of diminishing returns compared to improving windows or some other system in the design.) Looking at the picture of the cat nearly hitting your wall, the inside and outside foam layers look the same thickness. Is this an illusion, or are both the inner and outer layers at this point 2" (or 4")?
                      Compared to your situation, we didn't hit a single rock excavating for our house. We're on a mesa (I'm in New Mexico) whose what I'm told is called Aeolian - it's very dense sand deposited over a long period of time by the wind. It's very stable - you can dig a five foot deep trench with straight walls and it requires no shoring. (That's a practical statement, not a matter of safety practice. ) In digging our foundations (42" deep, 3' wide), we didn't encounter a single rock!
                      • Mike LuceyM Offline
                        Mike Lucey
                        Dale, this is getting more interesting with each episode you post and turning into a Master Class. We are all following. BTW, did you model the bird house in SketchUp .... you will now have to keep us updated on the fledglings progress also.
                        • daleD Offline
                          dale
                          @llaves said:
                          Dale:
                          llaves.
                          Ours is 2" and 2" styrofoam with 8" concrete. I probably should have found that particular visual, as I just quickly pulled this one off the Quadlock website.
                          Although we get some extreme temperatures here (-40 F ) they seldom last for long.
                          When we did the heat loss calculations I did as you said, and looked at a cost/performance comparison. I also had a long talk with my contact at Quadlock, who is kind of a roving teacher, technician, and he advised that he uses the 4" combinations only when the temperatures get down really low for extended periods.
                          I have used 4"/8"/4" combination on the community hall in town here. On that building we were originally going for a Leed Standard, and the heating system is employing waste heat from the Ice Arena next door to it so we wanted to have really high insulation standards.
                          They are just completing the Ice arena connection now, so it will be interesting to get to see how it performs.
                          As for windows, I totally agree.We have gone with Low E, argon filled with superspacer. Again we opted out of triple glaze, as the cost performance projection just didn't seem worth it.
                          I envy your rock situation. We have some the size of volkswagens.
                          When the fellow who owns the property next to ours saw our geo-exchange ground loops, he decided to go with it as well. When he dug he hit all clay, and in 1600 feet of trench hit 3 rocks.
                          • daleD Offline
                            dale
                            Mike
                            As I said I am a little behind on posting this as in reality we are just finishing framing, so I can tell you the Juncos were a real riot.
                            When they fledged, they moved in under a pallet of peel and stick roofing underlay, and since they are seed eater, kind of ground birds, they were constantly darting around the jobsite.
                            • daleD Offline
                              dale
                              In reality, I can't wait to get to the cabinetmaking part of the project, as this is my favourite thing in all the building process, but....
                              There is in fact the real "reality" .....Screen shot 2011-09-11 at 7.32.14 AM.png
                              So the underground servicing goes in so that we can insulate the slab for infloor hydronics.
                              This is code here to have a minimum of R-12 under a heated slab. We have 2" foam which gives us R-14 mostly because R-12 is hard to get.
                              We also used this as a vapour barrier, and Judy tuck taped all the joints with connection to the Quadlock.
                              Then we added the 6X6 (152.4 X 152.4 mm )welded wire mesh, and were ready to pour.Screen shot 2011-09-11 at 7.39.16 AM.png
                              • daleD Offline
                                dale
                                There is a community of Mennonites here, all of which are meticulous hard workers.
                                We subbed the concrete placement and finishing out to them.Screen shot 2011-09-11 at 7.48.38 AM.pngScreen shot 2011-09-11 at 7.50.31 AM.png
                                The last photo shows the hydronic pipes tied to the 6x6 mesh. The Geo-exchange system requires shorter loops, an maximum of 200'(61 m), and a 6" centre from pipe to pipe.
                                This is apparently because the system is more efficient if the water is returned at a slightly higher temperature.
                                We have done many water based Geo-exchange system, but this is my first ground based system, so I'm asking lots of questions, and generally being a pest.
                                • daleD Offline
                                  dale
                                  Then on to trusses.
                                  I was pretty specific about the style of trusses I wanted, as we had a few details we wanted to include, like extending overhangs of the lower chord so that it would act as a valance for potlights, and just internal ceiling shapes and heights.
                                  Again SketchUp is just so easy to get your communications across.
                                  I even convinced the tech to down load the free version so he could pull measurements, and walked him through the basics. Needless to say he was pretty impressed.Screen shot 2011-09-14 at 7.00.18 AM.png
                                    JuanV.Soler
                                    very tidy and clean all the process
                                    huge job
                                    • daleD Offline
                                      dale
                                      Juan
                                      Thank you a very appreciated comment from you.
                                      Dale
                                        Mike Lucey
                                        Great stuff Dale.
                                        Some complex trusses there especially the sloping one over the ??? room. I imagine the void will be useful for services.
                                        Is there any chance we could have a look at the plan layout so we can get a good overview?
                                        Mike
                                        • daleD Offline
                                          dale
                                          Hi Mike
                                          Here are the floor plans for the main and the lower floor and a section.
                                          Really crazy here right now so I will post some more shortly.
                                          Cheers
                                          DaleScreen shot 2011-09-15 at 7.28.20 AM.pngScreen shot 2011-09-15 at 7.28.42 AM.png
                                          • daleD Offline
                                            dale
                                            This is a hijack your own post notification:
                                            As an aside to my own house project, another project on the books just had a grand opening.
                                            This to was a from SketchUp to reality project, so I decided to include it as an aside.the SketchUp model:Screen shot 2011-09-15 at 8.21.56 PM.png
                                            The rendering:Screen shot 2011-09-15 at 8.22.50 PM.png
                                            Reality:Screen shot 2011-09-15 at 8.00.56 PM.png
                                            Opening ceremonies ribbon in place:Quinsam LQ.jpg
                                            • 2 / 5
