    From SketchUp to Reality
    91 Posts 22 Posters 16.3k Views 22 Watching
    • mitcorbM Offline
      mitcorb
      Hi, Dale:
      I wish you good fortune in this bold undertaking.
      What is the recommended height interval for concrete placement for the ICF system? This looks like it would be a very effective basement wall construction.
      • troyhomeT Offline
        troyhome
        This is a good example of SU as BIM for the rest of us 😄
        Thanks for sharing
        IOviz.com
        SU Pro 2024 PC
        • EarthMoverE Offline
          EarthMover
          Fascinating process. Can't wait to see more Dale! What a fantastic accomplishment, to design and build your own home. I hope to one day do the same. 👍 👍
          Content Creator at Skapeup
          • daleD Offline
            dale
            Thanks for the kind words and encouragement!
            I have had a few PM's on the ICF system, so I'll chat about it for a bit.
            I have experience with 2 systems, Quadlock, and Arxx. I am most fond of Quadlock, but that is for two reasons:
            I've used it on 19 projects, so it is the one I am most familiar with.
            It ships as 1'x 4' flat panels, and you put the panels together with nylon ties. Other systems like Arxx ship already put together, and components like corners are already assembled.
            For me this may be a disadvantage as I tend to work in remote areas, so shipping is more efficient with flat panels, rather than blocks with 8" of space between them.
            And secondly if one of the corner components is damaged in shipping, I am at a stand still until I get another shipped. With Quadlock, since I assemble the panels, this can't happen.
            In the end all the ICF systems I have seen used do there job well, so it is mostly a matter of preference.Screen shot 2011-09-08 at 6.28.50 AM.png
            In the photo above, you can see the yellow nylon ties on the top row of ICF, and the system I use for window rough bucks.
            The bucks are 2x12, with a 1/2" plywood strip added to build the 11 1/4" 2x12 out to the actual 12" thickness of the ICF wall. Then you case these with 1x4's which are also screwed to the wall ties preventing blowout.
            The sill of the bucks are 2-2x4's that have a space left open in the middle so that you can be sure you are getting the concrete to completely fill the forms under the windows.
            The concrete wells up into this space, and you trowel it off. This also serves to embed the buck which remains in place to fasten windows to.
            • daleD Offline
              dale
              The ICF systems are really like playing with Leggo, on an adult scale.It took Judy and I about a week to form and brace the foundation level forms.
              This time could be cut way down on a simple rectangular building, but we had several "T" walls for our entrance way, and fireplace foundation, so this slows you down.Screen shot 2011-09-08 at 6.39.28 AM.png
              This is a shot of quadlock and ties. This particular panel setup has a 2" ICF panel on one side, and a 4" on the other for greater insulation value. The ties can be ordered to allow for a 6",8",10", or 12" concrete thickness.
              To make the building more energy efficient, I cast in Simpson Strong Tie ICFVL hangers, so that I would be able to hang my floor inside the wall and have no exposed (air leaking) rim joist.
              These are complete engineered systems that you slot in through the styrofoam and then pour in place. Then you bolt your rim joist to these.
              • daleD Offline
                dale
                But this is also all about SketchUp and so we didn't arrive at this design without going through others. Attached below is one of the early designs, as you can see a totally different building.
                We both really liked this one, but it seemed a bit much for just the two of us, so we scaled down and went back to the modeling board.Picture 995.png
                • daleD Offline
                  dale
                  Concrete pump truck in action pouring the lower floor (foundation). We poured to about a foot (304 mm) over the cast in strong ties. This allowed us to frame the main floor, and have a platform to work from for the second floor.Screen shot 2011-09-09 at 5.54.11 AM.png
                  • daleD Offline
                    dale
                    Placing the main LVL beam in the cast in beam pocket. It is a 3 ply 14" LVL.
                    We are really taking advantage of mass in this house, so there will be in floor hydronics on both floors, with a 2" acid stained concrete floor for most of the main floor, with some areas of stone. This will all be fed by a ground source Geo-exchange system.
                    The load on this beam is fairly significant, with the floor loads coming in at 50,070 lbs (22,711 Kg)Screen shot 2011-09-09 at 6.08.04 AM.png
                    The first photo also shows the Resisto peel and stick foundation coating in place, which laps down over the footing.
                    • daleD Offline
                      dale
                      So with the beam in place we are unloading the TJI floor joists in this photo. The LVL is a drop beam so that electrical and plumbing can run in the joist cavity. The TJI's are full span, as were the rim joists which the hang off of with joist hangers.
                      Somehow Judy and I managed to manhandle these 34'(10.36 m)long beasts into place.Screen shot 2011-09-09 at 6.17.04 AM.png
                      • daleD Offline
                        dale
                        Once again SketchUp to the rescue, as with a floor load that is that heavy, it is not easy to find a pre-made telepost that can stand that load.
                        So I SketchUpped the post and emailed it to my structural engineer. He made a few changes to bolt hole locations, and we had a local fabricator build it.
                          llaves
                          Looks like this will be interesting to follow. Two comments, based on our experience:
                          1. Gophers seem to love the styrofoam in the ICFs. Maybe the Resisto will keep them out, but I wish the product was available with a hardware cloth covering. If you haven't buried your footings, you could still cover the foam. On the other hand, you mention that you've used ICFs on 18 projects. Have gophers plagued the owners of these houses?
                          2. If you're going to acid stain the floors, remember that everything that happens to the concrete between now and then will telegraph through the stain. Cover the floors, preferably with something like 1/8" masonite. If that's too expensive, a couple of layers of paper, and keep up with all the tears that will occur between now and staining.
                          • daleD Offline
                            dale
                            This is interesting about gophers. There are no gophers to speak of in this area, so it is a problem I haven't had to deal with, but could be very important if you are in an area that does.
                            And as for the floors, I couldn't agree more. We usually put down two layers of untreated building paper tuck taped at the seams,(tuck taped to each other, not the concrete as this will end up as stripes) and keep up with the tears.
                            It doesn't matter how much you berate the tradesmen, caring for you floor just isn't a priority.
                            • daleD Offline
                              dale
                              In the oddball things that happen on the jobsite department:
                              We let the foundation reach a 7 day compressive strength, and did a bit of back filling to make it easier to get in to the building. The site is on an ancient creek bed, and has lots of very large rocks.
                              The cat hit a large flat sloped rock, and side slipped down stopping with the blade about 1/2" from the styrofoam wall.Screen shot 2011-09-10 at 6.15.13 AM.png
                              Our neighbour has a little excavator so we got him to come over and help extricate the cat avaoiding a "cat tastrophy"Screen shot 2011-09-10 at 6.15.29 AM.png
                              Just before backfilling we discovered a nest of Juncos in the dirt bank of the excavation. We built the a little styrofoam nest, and a plywood condo, and hung it off the Quadlock wall just above where the nest had been in the bank. It took the adult birds a couple of hours, but they eventually found the nestlings, and stated feeding them until they fledged and flew.Screen shot 2011-09-10 at 6.17.33 AM.png
                              • daleD Offline
                                dale
                                The floor is 11 7/8 TJI's, which as I mentioned we joist hung from the ledger LVLs spanning over top of the main beam. Then we put down a 3/4" (19mm) t&g subfloor and the second floor Quadlock walls up.Screen shot 2011-09-10 at 6.32.18 AM.pngScreen shot 2011-09-10 at 6.33.02 AM.png
                                • daleD Offline
                                  dale
                                  But the nice thing about being able to model is that you can keep refining the design process as you do the grunt work. So, we were busy working out what the kitchen was going to be like.
                                  and over to Thea for some visuals.Screen shot 2011-09-10 at 6.40.00 AM.pngScreen shot 2011-09-10 at 6.40.19 AM.png
                                    bytor
                                    Dale,
                                    Following this great thread as it is very interesting and informative. My favorite part is the two pictures of the Juncos! Most would not bother, but you chose to be a steward of your environment and friend of nature. Great to see this! 👍
                                    Dean
                                    Find the Cost of Freedom.....
                                      llaves
                                      Dale:
                                      In one of your early posts you mention that the ICFs are 4" of foam on one side, 2" on the other, which would give a reasonably insulated wall. (My pet peeve is the extremism of some folks in massively insulating walls/roofs, where they have long reached the point of diminishing returns compared to improving windows or some other system in the design.) Looking at the picture of the cat nearly hitting your wall, the inside and outside foam layers look the same thickness. Is this an illusion, or are both the inner and outer layers at this point 2" (or 4")?
                                      Compared to your situation, we didn't hit a single rock excavating for our house. We're on a mesa (I'm in New Mexico) whose what I'm told is called Aeolian - it's very dense sand deposited over a long period of time by the wind. It's very stable - you can dig a five foot deep trench with straight walls and it requires no shoring. (That's a practical statement, not a matter of safety practice. ) In digging our foundations (42" deep, 3' wide), we didn't encounter a single rock!
                                      • Mike LuceyM Offline
                                        Mike Lucey
                                        Dale, this is getting more interesting with each episode you post and turning into a Master Class. We are all following. BTW, did you model the bird house in SketchUp .... you will now have to keep us updated on the fledglings progress also.
                                        • daleD Offline
                                          dale
                                          @llaves said:
                                          Dale:
                                          llaves.
                                          Ours is 2" and 2" styrofoam with 8" concrete. I probably should have found that particular visual, as I just quickly pulled this one off the Quadlock website.
                                          Although we get some extreme temperatures here (-40 F ) they seldom last for long.
                                          When we did the heat loss calculations I did as you said, and looked at a cost/performance comparison. I also had a long talk with my contact at Quadlock, who is kind of a roving teacher, technician, and he advised that he uses the 4" combinations only when the temperatures get down really low for extended periods.
                                          I have used 4"/8"/4" combination on the community hall in town here. On that building we were originally going for a Leed Standard, and the heating system is employing waste heat from the Ice Arena next door to it so we wanted to have really high insulation standards.
                                          They are just completing the Ice arena connection now, so it will be interesting to get to see how it performs.
                                          As for windows, I totally agree.We have gone with Low E, argon filled with superspacer. Again we opted out of triple glaze, as the cost performance projection just didn't seem worth it.
                                          I envy your rock situation. We have some the size of volkswagens.
                                          When the fellow who owns the property next to ours saw our geo-exchange ground loops, he decided to go with it as well. When he dug he hit all clay, and in 1600 feet of trench hit 3 rocks.
                                          • daleD Offline
                                            dale
                                            Mike
                                            As I said I am a little behind on posting this as in reality we are just finishing framing, so I can tell you the Juncos were a real riot.
                                            When they fledged, they moved in under a pallet of peel and stick roofing underlay, and since they are seed eater, kind of ground birds, they were constantly darting around the jobsite.
                                            • 2 / 5
