    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.3k Views 41 Watching
    • jolranJ
      jolran
      Good evening.
      Things are moving forward, but have been hooked on webdialogs and speed performance lately.
      All in all, all features I can think of is implemented. Loading from file and tiling with some options to it, is ok.(not from some dialog, in script)
      The "tech" part:
      Some sort of dialog has to be made. I'm thinking webdialog, but quite scared of diving into that part actually πŸ˜•
      But it will be difficult using dropdownlist with a long list. And I don't know if a list can be updated automatically if user add new components ❓ I guess UI.openpanel can only be used for images?
      Also performance is an issue.. Things can get quite slow sometimes, maybe to slow..
      The plugin tiles the group in 1 direction inside group1. Then it copies group1 in the cross direction.
      Copying groups are fast. Exploding and intersections is slow. I don't know if there is any way to speed up thoose things.
      Is there any way to copy and tile entities collection without using groups ❓
      Have also been experimenting with textures+lines combinations to "get away" with less geometry, but the result is less then satisfactory. Look pics:
      More artistic questions arise, what is needed from hatches anyway?
      Have been looking for ISO standards but can't find information regarding exact size of patterns. If you look at Doublecad for ex. When creating a hatch, the sizes of pattern often need to be adjusted. So what is the scaling standards? This could be of importance regarding speed. Cause, the bigger patter=less geometry >> speed increase.
      Any tips would be welcome. πŸ˜„
        If you go down the texture route then my 2dTools '2dHatching' already does much of this [without scaling etc]... with a fairly comprehensive list of tileable .PATT clone .jpg files...
        • jolranJ
          jolran
          Yeah, thanks. I have been looking at your plugin, TIG. There is no point in reinventing the wheel that's rolling well, so I will go the "line hatching" way. If it wasen't clear, I'm not convinced textures are good enough for CD's. Inconsistency in line widths..
          So far as I can see, 2dtools imports a jpg texture, while hatchfaces will be working with skp.files.
          And if I understand API docs right, you can only use images for UI:openpanel.
          The strategy I'm having is to have 1 color method for linehatching and another non-color method.
          Non color method will be standard-mode, and it's there where I aim to increase speed somehow.
          πŸ’­ Plan A is to find a solution to create all edges inside 1 group without the need for exploding, then use face-classify to remove unwanted edges.
          Plan B is create groups, intersect with face-clone(gents) and remove unwanted edges with face-classify points. That way there is no need to explode large amounts of groups. But intersection can be quite slow...
          Plan A need some thinking, and there is quite a lot of unnecessary geometry created as well. A big square, size of diagonal to compensate for rotations around center...
          It's difficult to do rotations prior to tiling. Unless doing zick-zack copying πŸ˜•
            UI.openpanel(title,folder,type) simply opens a file-browser, starting in the given folder and returns the selected file [if any] - so you could access whatever file-type[s] you want. The API example is simply showing one method..,
            My '2dHatching' happens to use jpg files that are kept in a special subfolder - it then uses the one of them that's been selected as the texture for a [new] material that's then applied to any picked face. It just so happens that I had all of the typical CAD PATTs as tileable jpg files! IF I had had them as tileable SKPs I would have simply changed my code to suit that file-type...
            Idea...
            You know the bb=face.bounds and from that cent=bb.center and diag=bb.diagonal
            Make your hatching group in the face.parent.entities, at the 'origin', laid flat.
            Its center at the origin.
            Draw you hatching from min to max based on the diag/2 used to offset points in x/y.
            Now you have a load of lines in a group that will always exceed the bounds of the face is overlaid on it.
            The group is not yet aligned with the face.plane.
            Transform the group axes
            group.transform!(Geom::Transformation.new(ORIGIN, face.normal))
            Now the group's plane parallel to the face.plane
            Move the group
            group.transform!(Geom::Transformation.new(cent)).
            Now the group is located with the same center as the face.
            You now need the quickest way to trim your hatching to the face's loops...
            Use intersect_with() on the group.entities and the face.edges+[face] this should then split all of the groups edges as the cross the face's perimeter edges.
            Now iterate through the edges in the group and inspect them.
            Use face.point_classify(mid) on the mid-point of every edge [we already have code for finding this from earlier exchanges].
            As all edges have already been split by the intersection with face's perimeter edges only those that are on the face are to be kept - all others are then collected and erased en mass after the inspection.
            So now we should have a group overlaying the face with its hatching lines all trimmed to the perimeter of the face, including any 'holes'.
            No exploding or cloning required...
            Next... IF you want the hatching to have a 'perimeter' you can replicate the face.edges within the group.entities, transforming each edges vertices to match the group.transformation.inverse ?
            IF you then want that perimeter to be split at every meeting with a hatching line then you can intersect_with() the group.entities with group.entities.to_a [you may find you need to do this more than once to ensure all are fully split?]. I can see little advantage in adding this??
            Optionally Exploding the group over the face will merge the edges with the then split face
            I can't see why you'd want faces for the hatching inside the group... BUT if you do then you can clone the face inside the group and intersect the group.entities with the cloned_face....
            For cross-hatching simply do the hatching twice and then group the two hatching groups into one ?
            • K
              kaas
              @jolran said:
              Things can get quite slow sometimes, maybe too slow..
              ... This could be of importance regarding speed. Cause, the bigger patter=less geometry >> speed increase.
              I can only speak for myself but I'm very interested in this plugin regardless of any speed issue. At the moment I draw the hatches in SU by hand. I can't imagine your plugin would be slower than doing this 'boring' process by hand.
              As long as people can edit the hatch-SU-files themselves as well they can choose to use hi-res hatches or low-res and by doing so control the speed and add a personal style.
              Going into the path of using textures as hatches would be a pity because people sometimes have to export LO files to dxf/dwg for use by other contractors who use Autocad etc. Hatched lines would convert into cad-lines. Textures would not.
              Greetings and πŸ‘ ,
              Max
              • jolranJ
                jolran
                Thats good to know when dealing with dialogs later on.
                Regarding your idea, I will have a look at that, TIG. I'm not sure I'm quite following what you mean. I am using skp.component patterns loaded from file and place them on the face and do the tiling on required up/down vectors. Based on face diagonal length.
                Anyway I will reread you idea to see more clearly what you mean. Thanks TIG.
                Max. Thanks for giving feedback πŸ˜„
                I'm not going the texture way, so don't worry about that. The oportunity to be able to export the line geometry is what I had in mind as well. But mostly, it gives better and more predictable results when printing.
                Also I won't experiment with performance(I hope)for to long. We are dealing with creating 2d-3d-geometry and not vectorgraphics, so that has to be taken in consideration for this plugin.
                • jolranJ
                  jolran
                  Hmm.. reading my post again I think I wasent clear about how the plugin works at the moment, so here is a more illustrated explanation.
                  It looks like you where giving advice about linehatches, before TIG? I think we have that one working already.
                  Now it's pattern-time.
                  Been looking at sin and cos 😲 for calculating rotations and how relations of borders behave when tiling rotated geometry. To be able to copy less geometry.
                  Not an easy task. Also can't figure out a way to get length and width of face anyway so I will know how many copies to be made.
                  Bounds.diagonal and center is good and consistent mesures. But NOT bounds.width or height, even if it's a face=2d bounds! It will still mesure from a 3d boundingbox compared to axes. So if the face is tilted youre scr@w@d..
                  Here's how it works at the moment anyway. Just the tiling. After tilings done. One can use proper method of intersecting and
                  remowing unwanted edges. Have tried different methods of those..
                    I was speaking about 'line-hatch' - I thought you were looking at speeding everything...
                    However, all you do differently for the 'component-hatch' is add component-instances to the [initially flat] group, set at the center and the with copies offset in x/y based on the 2d component's bounds.
                    The spacing of the instances is within the same limits as the 'line-hatch' version.
                    Then you explode the instances in the group and proceed with the intersect_with() etc as with line-hatch........
                    • jolranJ
                      jolran
                      Ahh, ok. I understand. 😳
                      Yeah, that's what I thought as well. Will try to get things rolling..
                      Thanks.
                      • jolranJ
                        jolran
                        Been trying more realistic sizes of patterns. Noticed I was testing on a face 30 meters long πŸ˜„
                        Times are a little better now, unless using circles with plenty of geometry..
                        This is on a pole 3m high. Remember time will be aprox the same if the pole would be 3 m wide...
                        Now, still haven't found ISO standards for patterns so I'm eyeballing size here.. If someone find info regarding that please mention it here.
                        Colors on edges added.
                          Look at the jpg PATTerns in my 2dHatching subfolder - these are most of the standard ACAD PATT files - note how they are all relatively simple line patterns - NO real circles!
                          Simple hatch/cross-hatch are 'simple' - the concrete, grain etc are more complex - but still relatively simple tileable sets of a few edges... πŸ˜•
                          • jolranJ
                            jolran
                            Yeah, you are right. The standard patterns are not that dense. The ones in "Hatchingextra" folder is quite dense, but not extreme.
                            Think I'll drop the "performance hysteria" for a moment, and continue with the rest of the job πŸ˜‰
                              The main folder is based on most of the ACAD standard PATTs.
                              The '..extras' folder contains mostly 'non-standard' hatches.
                              • jolranJ
                                jolran
                                Ah, ok. That make sence.
                                Have been looking at the PAT format though.
                                http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS73099cc142f4875513fb5cd10c4aa30d6b-7e57.htm,topicNumber=d0e368209
                                Hmm, wonder if it would be possible with an importer of autcocad-patterns.. Major project perhaps. πŸ˜•
                                Got my hands busy with learning html, css, js and jquery anyway πŸ˜„
                                  If you get a .pat file you will see it's set up like this
                                  ;; Notes... *Masonry-Angle, Masonry in section/plan @50mm c/c & @45deg. 45, 0,0, 0,50
                                  Lines starting with a ';;' are user notes and are ignored in pattern making.
                                  Each line for a hatch type starts with a ' *' and starts with the pattern's 'name' and 'description' separated by ' ,'
                                  The lines following it describe the lines to draw in the pattern - in this example rotated by 45 degrees and one line spaced in X/Y starting from 0,0 - they draw 'infinitely' unless a second point is given, spaced in X/Y 0,50 ['units', mm in this example] - i.e. a line drawn offset every 50 at 45 degrees - it's as long as it needs to be to fill the 'loop'.
                                  More complicated patterns spread over several lines and include a 'fixed length' line thus...
                                  *Herringbone, 'Herringbone-pattern' 100x200mm brick/paving @45deg. 45, 0,0, 100,100, 300,-100 135, 70.710678,70.710678, 100,-100, 300,-100
                                  Note how the three pairs of X/Y specify the lines' start-point, their end-point and their repeat, with different angles for two types of line...
                                  The additional lines are used until a line of text starting with ' *' or a 'blank' is encountered.
                                  To mind-boggle you here's a complex wood-grain pattern...
                                  *Panel, Woodgrain or paneling, approx 10mm repeat. 0,0,0,0,100,20,-30,10,-40 0,70,2.5,0,100,20,-80 0,60,7.5,0,100,10,-90 0,5,10,0,100,5,-70,5,-20 0,40,15,0,100,20,-30,5,-45 0,15,17.5,0,100,15,-85 0,40,20,0,100,30,-70 0,10,22.5,0,100,20,-80 0,50,25,0,100,50,-50 0,20,30,0,100,10,-30,20,-40 0,90,32.5,0,100,20,-80 0,70,35,0,100,10,-90 0,50,37.5,0,100,10,-90 0,0,40,0,100,20,-80 0,50,42.5,0,100,20,-80 0,50,47.5,0,100,20,-20,20,-40 0,30,52.5,0,100,10,-50,20,-20 0,50,55,0,100,30,-70 0,50,60,0,100,20,-80,0,0 0,10,62.5,0,100,30,-40,10,-20 0,10,67.5,0,100,50,-50 0,70,70,0,100,10,-90 0,40,72.5,0,100,20,-80 0,20,75,0,100,10,-40,10,-40 0,10,77.5,0,100,10,-30,20,-40 0,30,80,0,100,10,-50,10,-30 0,50,82.5,0,100,30,-70 0,10,87.5,0,100,20,-80 0,60,90,0,100,10,-90 0,80,92.5,0,100,10,-90 14.03624347,70,7.5,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,80,30,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,70,90,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,40,52.5,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,60,67.5,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,70,60,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,20,77.5,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,60,72.5,97.01425001,-24.25356251,10.3,-402.0105526 14.03624347,80,35,97.01425001,-24.25356251,20.6,-391.7105526 14.03624347,70,42.5,97.01425001,-24.25356251,20.6,-391.7105526 14.03624347,70,47.5,97.01425001,-24.25356251,20.6,-391.7105526 165.9637565,40,15,97.01425001,24.25356251,10.3,-20.6,10.3,-371.1105526 165.9637565,20,30,97.01425001,24.25356251,10.3,-402.0105526 165.9637565,20,75,97.01425001,24.25356251,20.6,-391.7105526 194.0362435,70,2.5,97.01425001,-24.25356251,10.3,-402.0105526 345.9637565,90,2.5,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,60,37.5,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,80,55,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,40,62.5,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,30,75,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,40,80,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,40,62.5,97.01425001,24.25356251,10.3,-402.0105526 345.9637565,70,77.5,97.01425001,24.25356251,41.2,-371.1105526 345.9637565,10,10,97.01425001,24.25356251,41.2,-371.1105526 345.9637565,20,17.5,97.01425001,24.25356251,41.2,-371.1105526 345.9637565,30,22.5,97.01425001,24.25356251,10.3,-20.6,20.6,-360.8105526 345.9637565,30,30,97.01425001,24.25356251,20.6,-20.6,20.6,-350.5105526 345.9637565,20,40,97.01425001,24.25356251,41.2,-371.1105526 345.9637565,10,47.5,97.01425001,24.25356251,41.2,-371.1105526 345.9637565,10,52.5,97.01425001,24.25356251,41.2,-371.1105526 345.9637565,80,82.5,97.01425001,24.25356251,10.3,-402.0105526 345.9637675,90,92.5,97.01425001,24.25356251,20.6,-391.7105526 345.9637675,30,87.5,97.01425001,24.25356251,20.6,-391.7105526 345.9637575,20,0,97.01425001,24.25356251,41.2,-371.1105526 345.9637575,80,70,97.01425001,24.25356251,30.9,-381.4105526 345.9637575,90,62.5,97.01425001,24.25356251,61.8,-350.5105526
                                  So you can read a .pat file using lines=IO.readlines('path_to_file.pat') and then iterate through lines to find all pattern types and their specifications - replicating these as edges in your SKP...
                                  • jolranJ
                                    jolran
                                    This is what complicates things in Sketchup, I believe.
                                    That I did not know. Hmm, this may be possible after all. I'll have to be careful though not to start new projects and ideas that never get's finished. πŸ˜„
                                    Seeing the wood grain patter you provided code for makes me wonder if its viable as an additional feature πŸ˜• I reckon it would just slow the plugin down even more creating all that geomtry, compared to importing an already created Sketchup component? Or maybe creation of edges are swift.
                                    Other alternative is as a converter maybe? Import PAT >> convert to component and save in pattern directory. Batch would be nice..
                                    Anyway, good info you show there. It almost sounds like you already have tried/done this before πŸ˜‰
                                      I've never parsed a PAT file BUT it's easier than parsing an OBJ or MTL file!
                                      You don't want to be reading .pat files into Ruby every time.
                                      In fact a .pat file usually contains all of the patterns in one lump!
                                      The simple line patterns are easily replicated in code anyway... it's just the complex tileable line patterns like wood-grain that are complicated...
                                      BUT you could simply 'draw these too...
                                      You could perhaps make a converter and write a set individual '.spat' files that specify the geometry to draw, BUT probably a standard size SKP 1m x 1m or maybe 10" x 10" to mimic the texture default... that you place down in a repeating patterns and then explode all followed by the intersect_with and trimming is the best way... To test it make a simple line hatch that tiles and try it out...
                                      • jolranJ
                                        jolran
                                        Yeah, that's what I think to, and doing right now. Shoulden't overcomplicate things at this stage, perhaps.
                                        • jolranJ
                                          jolran
                                          Hmm, ok. Got some webdialog going, with HTML and some css. Ugly son of a gun. HUGE! 😲 Doesent do anything yet..
                                          Funny, it doesent look like that either in firefox or IExplorer. I've got Opera installed as well, but IE should is default browser. Does Sketchup load from default browser?
                                          Anyway.. Now the fun part starts, with javascript and callbacks.. Maybe Jquery? Suggestions, please..
                                          Should load files and select the in the list, and then there should pop up a GIF as preview.
                                          Will manually create gifs for each component cause the skp.jpg are so small and zaggy and don't always show up!
                                          For MAC people (in case pic won't show up), there should be text displaying what hatch is selected.
                                          They say, html and css should be the easy part, but heck! It's difficult to line up form elements horisontaly, thats why the dialog is so tall. Coulden't get it to work otherwise. Had to rearrange everything from scratch at least 3 times.
                                          It takes longer to make the dialog then the plugin πŸ˜„ Off course, I'm new to html so a more experienced user would probably be swifter.
                                            Sketchup uses PC's IE [older version] and Safari for the MAC - irrespective of your default browser...
                                            Some strange hatch-pattern names πŸ˜‰ πŸ˜„
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 13 / 18
