    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      No! Progressbar.rb should be in the Plugins directory.
        gr8fzy1
        @tig said:
        OK!! now we have these errors it's clear that you haven't installed the tool properly when they were extracted from the zipped set.
        When you install it you need its main file clf_shape_bender_loader.rb file in the Plugins folder.
        You also need a subfolder within Plugins named 'clf_shape_bender', containing these files: [attachment=1:gu9q4ffr]<!-- ia1 -->Capture.PNG<!-- ia1 -->[/attachment:gu9q4ffr] You will also need progressbar.rb in Plugins - that is available from http://www.Smustard.com
        The first time I ran it, it SAID that I needed the progressbar.rb, so I already downloaded that and installed it.
        Well, after a little trial and error with the shape bender subfolder (I had put the loader.rb in there as well, so the shape bender wouldn't load. ^////^) I tried it out and it WORKED!
        [attachment=0:gu9q4ffr]<!-- ia0 -->Shape Bender 4.png<!-- ia0 -->[/attachment:gu9q4ffr]
        Thank you for the help everyone! And you too TIG, for the clues on PURGING. I had some files that were almost 6MB that purged down to only 900K.
        YAY!
          gr8fzy1
          I know, I already fixed that.
            jorge2011
            is possible for the next version add the feature to adapt to surfaces?
              silviac918
              Hey,
              It's a very powerful tool. However, I tried to do a vertical 3D text along a curve wall. It always stop at the message " 1% End @? (1 of 5) Searching for objects to explode. Do you know what the problem is? really hope this could work. Thanks.
              Silvia
                It's probably not 'stopped', but just taking ages to complete.
                Can you rotate the parts onto the red/X-axis ?
                It might speed things up...
                • Chris FullmerC Offline
                  Though that 1%END@? looks suspicious. Can you upload the model?
                  • X Offline
                    Xorthan
                    Hi there.
                    I started using SketchUp on my Mac.
                    I downloaded ShapeBender, as well as ProgressBar, and put both in my Plugins folder.
                    I restarted SketchUp, and don't find a ProgressBar like in your video... is that because I'm using a Mac? Is there someone here who has an idea what I'm doing wrong?
                      Progressbar is just a plugin which is use by other plugins (like ShapeBender for instance). You will have to activate SB (I think) under SketchUp > Preferences > Extensions then restart SU and find it toolbar button where they are on the Mac (on Windows, they are under the View menu but I know Mac is different here)
                      • X Offline
                        Xorthan
                        Thanks for the reply; I went to SketchUp > Preferences > Extensions, and didn't see anything about ShapeBender there, the only extension that wasn't checked was Ruby Script Examples, which I checked, but I still don't have a status bar or he bender button from the video...
                        Any other ideas?
                          Hm. It should be there - unless Chris programmed it differently for Mac (which I doubt)
                          Have you unpackedthe content of that zip file? Simply copying it to your Plugins folder will not install the plugin. See some instructions/guidelines below
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                            The Shape Bender extension swill show on Mac in Preferences>Extensions as it does on a windows machine. It sounds to me as if you didn't unpack the Shape Bender file or didn't unpack it correctly.
                            • X Offline
                              Xorthan
                              Okay, maybe I didn't see Shape Bender in the Extensions list before... I see it now. And it's checked. I also have the Progress Bar downloaded, and progressbar.rb is in my plugins folder. I still don't have a progress bar in SketchUp...
                              I tried moving progressbar.rb to the plugins > utilities, just to see what would happen, but when I opened up SketchUp is gave me a warning, so I moved to back to plugins, and got no warning, but also no icon that looks anything like the video. ??
                                You will only see a small progress bar running at the bottom of your window when ShapeBender is working - that1s all it's needed for so there is no menu item or button for it, it is just a background plugin in this case. Have you looked at your toolbars to see if the ShapeBender icon is there?
                                • X Offline
                                  Xorthan
                                  I have looked at my toolbars - I don't see it available there. On the video, it looked like a button was hit between selecting the straight line and selecting the guiding line. Maybe I was mistaken. So if there's no button, how do I get the thing to work then?
                                  Thanks for your help.
                                    http://farm7.static.flickr.com/6074/6133268684_fc6e66d8b5_z.jpg
                                    If you aren't seeing Shape Bender under View>Tool Palettes, I would guess you still haven't installed it correctly. Why don't you post a screen shot of Finder showing the plugins folder and its contents? Otherwise we're going to play this guessing game until you've got it installed correctly and working. And I can assure you, the plugin does work on Mac if it is installed correctly.
                                    By the way, there's no toolbar button press between selecting the straight line and the curve. You select the component/group you want to bend and then choose the tool.
                                      Hi Mark, there is no button or menu item for progressbar. Please stop looking for it.
                                      You might need to go to View > Toolbars > Shape Bender to turn on the shapebender toolbar. It is a small single icon, easy to not see if you have a big monitor. Or if you have toolbars that are "loose" (not docked into the window) then they can stack on top of each other, so maybe its under another toolbar.
                                        Have you activated 'Shape Bender' from Window > Preferences > Extensions.
                                        If not then try that... and then the menu/toolbar become available.
                                        If it's not listed as an Extension then it is NOT been installed properly โ—
                                        • X Offline
                                          Xorthan
                                          Okay, I am now seeing Shape Bender under View > Tool Palettes, and can see the Tool Bar. I can also select it from Plugins > Chris Fulmer Tools. I have it selected in my preferences extensions.
                                          So it looks like it should be working now, and I'm following the instructions from the video: I click on my group or component (I've tried both), then click on the Tool Bar. After that, I should be able to select my straight line, right? Left clicking doesn't do anything. Right clicking brings up a menu that does have anything to do with Shape Bender.
                                          Argh.
                                          How do I include screen shots? I clicked on Img - what do I stick between the brackets?
                                            First make sure that you align the whole thing (group, straight line and curve) in a way that the straight line is parallel to the red axis. This is an often overlooked condition (and Chris has been keeping this plugin in Beta version for ages now) ๐Ÿ˜’
                                            Anyway, you can attach any images or many other file types under the text area you are posting (there is an "Upload attachment" tab). the [img] tab is for including/embedding images hosted elsewhere.
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 63
                                            • 64
                                            • 43 / 64
