    From SketchUp to Reality
    91 Posts 22 Posters 18.4k Views 22 Watching
    • StilTegS
      StilTeg
      I was about to do the same ... Unfortunately the property was no longer for sale ... 😢
      doing technical engineering on SketchUp ... without plugins
      • N
        notareal
        I wish all the best for you project! Been there, done that... (actually my project introduced SU and wonderful world of rendering for me). If you or your wife ever get exhausted, remember that you can always hire some labor and take some leisure time with your wife - it's better than hitting your head to the wall.
          Dale, very nice. I'm going to follow your project with great interest.
          How did you find the ICFs to set up? My wife and I have talked about using them but around here, most of the contractors prefer to pour conventional walls or set block. they don't seem to know about the ICF walls so they don't want to use them.
          • mitcorbM
            mitcorb
            Hi, Dale:
            I wish you good fortune in this bold undertaking.
            What is the recommended height interval for concrete placement for the ICF system? This looks like it would be a very effective basement wall construction.
            • troyhomeT
              troyhome
              This is a good example of SU as BIM for the rest of us 😄
              Thanks for sharing
              IOviz.com
              SU Pro 2024 PC
              • EarthMoverE
                EarthMover
                Fascinating process. Can't wait to see more Dale! What a fantastic accomplishment, to design and build your own home. I hope to one day do the same. 👍 👍
                Content Creator at Skapeup
                • daleD
                  dale
                  Thanks for the kind words and encouragement!
                  I have had a few PM's on the ICF system, so I'll chat about it for a bit.
                  I have experience with 2 systems, Quadlock, and Arxx. I am most fond of Quadlock, but that is for two reasons:
                  I've used it on 19 projects, so it is the one I am most familiar with.
                  It ships as 1'x 4' flat panels, and you put the panels together with nylon ties. Other systems like Arxx ship already put together, and components like corners are already assembled.
                  For me this may be a disadvantage as I tend to work in remote areas, so shipping is more efficient with flat panels, rather than blocks with 8" of space between them.
                  And secondly if one of the corner components is damaged in shipping, I am at a stand still until I get another shipped. With Quadlock, since I assemble the panels, this can't happen.
                  In the end all the ICF systems I have seen used do there job well, so it is mostly a matter of preference.Screen shot 2011-09-08 at 6.28.50 AM.png
                  In the photo above, you can see the yellow nylon ties on the top row of ICF, and the system I use for window rough bucks.
                  The bucks are 2x12, with a 1/2" plywood strip added to build the 11 1/4" 2x12 out to the actual 12" thickness of the ICF wall. Then you case these with 1x4's which are also screwed to the wall ties preventing blowout.
                  The sill of the bucks are 2-2x4's that have a space left open in the middle so that you can be sure you are getting the concrete to completely fill the forms under the windows.
                  The concrete wells up into this space, and you trowel it off. This also serves to embed the buck which remains in place to fasten windows to.
                  • daleD
                    dale
                    The ICF systems are really like playing with Leggo, on an adult scale.It took Judy and I about a week to form and brace the foundation level forms.
                    This time could be cut way down on a simple rectangular building, but we had several "T" walls for our entrance way, and fireplace foundation, so this slows you down.Screen shot 2011-09-08 at 6.39.28 AM.png
                    This is a shot of quadlock and ties. This particular panel setup has a 2" ICF panel on one side, and a 4" on the other for greater insulation value. The ties can be ordered to allow for a 6",8",10", or 12" concrete thickness.
                    To make the building more energy efficient, I cast in Simpson Strong Tie ICFVL hangers, so that I would be able to hang my floor inside the wall and have no exposed (air leaking) rim joist.
                    These are complete engineered systems that you slot in through the styrofoam and then pour in place. Then you bolt your rim joist to these.
                    • daleD
                      dale
                      But this is also all about SketchUp and so we didn't arrive at this design without going through others. Attached below is one of the early designs, as you can see a totally different building.
                      We both really liked this one, but it seemed a bit much for just the two of us, so we scaled down and went back to the modeling board.Picture 995.png
                      • daleD
                        dale
                        Concrete pump truck in action pouring the lower floor (foundation). We poured to about a foot (304 mm) over the cast in strong ties. This allowed us to frame the main floor, and have a platform to work from for the second floor.Screen shot 2011-09-09 at 5.54.11 AM.png
                        • daleD
                          dale
                          Placing the main LVL beam in the cast in beam pocket. It is a 3 ply 14" LVL.
                          We are really taking advantage of mass in this house, so there will be in floor hydronics on both floors, with a 2" acid stained concrete floor for most of the main floor, with some areas of stone. This will all be fed by a ground source Geo-exchange system.
                          The load on this beam is fairly significant, with the floor loads coming in at 50,070 lbs (22,711 Kg)Screen shot 2011-09-09 at 6.08.04 AM.png
                          The first photo also shows the Resisto peel and stick foundation coating in place, which laps down over the footing.
                          • daleD
                            dale
                            So with the beam in place we are unloading the TJI floor joists in this photo. The LVL is a drop beam so that electrical and plumbing can run in the joist cavity. The TJI's are full span, as were the rim joists which the hang off of with joist hangers.
                            Somehow Judy and I managed to manhandle these 34'(10.36 m)long beasts into place.Screen shot 2011-09-09 at 6.17.04 AM.png
                            • daleD
                              dale
                              Once again SketchUp to the rescue, as with a floor load that is that heavy, it is not easy to find a pre-made telepost that can stand that load.
                              So I SketchUpped the post and emailed it to my structural engineer. He made a few changes to bolt hole locations, and we had a local fabricator build it.
                              • L
                                llaves
                                Looks like this will be interesting to follow. Two comments, based on our experience:
                                1. Gophers seem to love the styrofoam in the ICFs. Maybe the Resisto will keep them out, but I wish the product was available with a hardware cloth covering. If you haven't buried your footings, you could still cover the foam. On the other hand, you mention that you've used ICFs on 18 projects. Have gophers plagued the owners of these houses?
                                2. If you're going to acid stain the floors, remember that everything that happens to the concrete between now and then will telegraph through the stain. Cover the floors, preferably with something like 1/8" masonite. If that's too expensive, a couple of layers of paper, and keep up with all the tears that will occur between now and staining.
                                • daleD
                                  dale
                                  This is interesting about gophers. There are no gophers to speak of in this area, so it is a problem I haven't had to deal with, but could be very important if you are in an area that does.
                                  And as for the floors, I couldn't agree more. We usually put down two layers of untreated building paper tuck taped at the seams,(tuck taped to each other, not the concrete as this will end up as stripes) and keep up with the tears.
                                  It doesn't matter how much you berate the tradesmen, caring for you floor just isn't a priority.
                                  • daleD
                                    dale
                                    In the oddball things that happen on the jobsite department:
                                    We let the foundation reach a 7 day compressive strength, and did a bit of back filling to make it easier to get in to the building. The site is on an ancient creek bed, and has lots of very large rocks.
                                    The cat hit a large flat sloped rock, and side slipped down stopping with the blade about 1/2" from the styrofoam wall.Screen shot 2011-09-10 at 6.15.13 AM.png
                                    Our neighbour has a little excavator so we got him to come over and help extricate the cat avaoiding a "cat tastrophy"Screen shot 2011-09-10 at 6.15.29 AM.png
                                    Just before backfilling we discovered a nest of Juncos in the dirt bank of the excavation. We built the a little styrofoam nest, and a plywood condo, and hung it off the Quadlock wall just above where the nest had been in the bank. It took the adult birds a couple of hours, but they eventually found the nestlings, and stated feeding them until they fledged and flew.Screen shot 2011-09-10 at 6.17.33 AM.png
                                    • daleD
                                      dale
                                      The floor is 11 7/8 TJI's, which as I mentioned we joist hung from the ledger LVLs spanning over top of the main beam. Then we put down a 3/4" (19mm) t&g subfloor and the second floor Quadlock walls up.Screen shot 2011-09-10 at 6.32.18 AM.pngScreen shot 2011-09-10 at 6.33.02 AM.png
                                      • daleD
                                        dale
                                        But the nice thing about being able to model is that you can keep refining the design process as you do the grunt work. So, we were busy working out what the kitchen was going to be like.
                                        and over to Thea for some visuals.Screen shot 2011-09-10 at 6.40.00 AM.pngScreen shot 2011-09-10 at 6.40.19 AM.png
                                        • B
                                          bytor
                                          Dale,
                                          Following this great thread as it is very interesting and informative. My favorite part is the two pictures of the Juncos! Most would not bother, but you chose to be a steward of your environment and friend of nature. Great to see this! 👍
                                          Dean
                                          Find the Cost of Freedom.....
                                          • L
                                            llaves
                                            Dale:
                                            In one of your early posts you mention that the ICFs are 4" of foam on one side, 2" on the other, which would give a reasonably insulated wall. (My pet peeve is the extremism of some folks in massively insulating walls/roofs, where they have long reached the point of diminishing returns compared to improving windows or some other system in the design.) Looking at the picture of the cat nearly hitting your wall, the inside and outside foam layers look the same thickness. Is this an illusion, or are both the inner and outer layers at this point 2" (or 4")?
                                            Compared to your situation, we didn't hit a single rock excavating for our house. We're on a mesa (I'm in New Mexico) whose what I'm told is called Aeolian - it's very dense sand deposited over a long period of time by the wind. It's very stable - you can dig a five foot deep trench with straight walls and it requires no shoring. (That's a practical statement, not a matter of safety practice. ) In digging our foundations (42" deep, 3' wide), we didn't encounter a single rock!
                                            • 1 / 5
