    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      @gobilman06 said:
      Hi there i already install lilfredo6 plugins but the thing is i cant see the icon in my tool bar. pls help... cheers!
      At least, do you see the menu Windows > LibFredo6 Settings....?
      If so, you just have to install the plugin (like FredoScale, RoundCorner, ...) and it should be OK.
        gobilman06
        No worries already sort it out. thanks a lot!
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v4.0a - 23 Aug 11
          LibFredo6 4.0 is a major technical release. The intention is to simplify the installation of my plugins and make their loading more robust, with error detection and protection.
          A main feature of LibFred06 4.0 is that the ZLoader__xxx.rb files are no longer used(it will work however even if you still have them in your plugin folder, but it is advised to delete them). This means that my plugin will now be published as a simple folder (like ROUNDCORNER_Dir_22) to be put in the same directory as LibFredo6. The plugins will only be loaded if you have LibFredo6 installed and load errors will be tracked and reported.
          LibFredo6 4.0 also includes a few plugin maintenance utilities available in the Windows > LibFredo6 Settings... menu:
          1) Purge Obsolete files
          This utility shows the files which are no longer useful and that you can safely delete. Indeed, you will see there all the ZLoader__xxx.rb files which are now ignored.
          2) Plugin load performances
          It displays the time for loading the plugins based on LibFredo6. I am interested in getting a feedback on these load times as it seems to be different on different machines and systems.
          3) Trace Log viewers
          LibFredo6 4.0 stores some traces (in a temporary folder). Currently this is mainly related to the load cycle of the scripts. If an error has happened it will be recorded there. Note that there is n Export feature (as a TXT file) which might be useful for reporting problems to the author if needed.
          4) Plugin directory location
          Just to recall that LibFredo6 (and all my scripts) can be located in another directory than the standard SU one.
          In this respect, it might be useful to install 000_AdditionalPluginFolders.rb script. This will allow you to specify additional plugin directories and put LibFredo6 there.
          I recommend to install LibFredo6 v4.0 as it will be more robust and easier (for me) to support.
          See Main Post for detailed documentation and download.
          • bac9-flclB Offline
            bac9-flcl
            Great release! 😍
            However, there seems to be a small issue... It seems that if you won't manually delete an old ZLoader, the new menu won't appear (and perhaps the library won't be loaded properly?). The problem is that I don't remember how exactly that ZLoader file was called, something like ZLoader__LibFredo.rb, but I'm not sure at all, - just deleted it and there is now no way to know the exact name, unfortunately. 😕 And it's not there in LibFredo 3.7b archive I found around, so perhaps it's some ancient file from a very old release. Anyway, after I've deleted it, everything loaded properly, and is now working well. 😄
              Lulliloo1
              There are a lot of links ABOUT '[Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'. I've spent quite some time unsuccessfully looking for the link to actually download '[Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'. Would someone please provide that? It would be helpful to others to also provide that as part of this subject.
                In the first post, there is a big Download button under which there is the link (or click on the image below - you need to be logged in)
                http://forums.sketchucation.com/download/file.php?id=49285
                  Lulliloo1
                  ref my post this morning regarding downloading:
                  The download link did not work with Google Chrome, but it did with Windows Explorer (9). Problem solved...
                    that's odd. I've never had any trouble downloading any files from here with Chrome. You might want to check your settings in Chrome.
                      bimbachi
                      hello
                      i'm having problem with "Check Plugins for Update"
                      attached screen info
                      any idea how to solve it?
                      regards
                      ps.-i'm on mac, osx 10.7.1
                      • fredo6F Offline
                        @bimbachi said:
                        hello
                        regards
                        Can you check your version of Safari.
                        If it is Safari 5.0.6, then bad luck, there is a big issue (which is under resolution, see that thread)
                        Thanks to confirm. Also, do you see the images in the dialog box (I mean the small + and - at the top of the table, on left)?
                        PS: I hope I can publish a fix soon.
                          bimbachi
                          Safari is Version 5.1 (7534.48.3)
                          You are right images not showing correctly.
                          regards
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
                            LibFredo6 4.1 is a technical release which normally fixes some issues for recent version of Mac OS and Safari 5.0.6 and above (images not displayed and check for update not working).
                            • fredo6F Offline
                              hm, problem persist the same !
                              Could you try with this patch (drop the attached file into LIBFREDO6_Dir_41 folder)
                              Lib6WebWdlg.rb
                                bimbachi
                                "Fredo6"]NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
                                hmm, problem persist the same - images and update, message is;
                                "ERROR in Check for Update
                                Please verify your Internet connection
                                The Following URLS could not be checked
                                -- Sketchucation Forum (http://forums.sketchucation.com/viewtopic.php?f=180&t=3263)"
                                  bimbachi
                                  [attachment=0:28se3n33]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:28se3n33]
                                  yes - done - unfortunately no change
                                  • fredo6F Offline
                                    [attachment=0:q3lrc8is]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:q3lrc8is]
                                    Then there is another difference between 5.0.6 and 5.1.
                                    In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally". This refresh the web dialog box. Can you then see the images.
                                      bimbachi
                                      [/quote]
                                      <<In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally".>> - yes
                                      <<This refresh the web dialog box.>> - dose not refresh box!
                                      <<Can you then see the images.>> - checkbox yes images no, text only
                                      regards
                                      bimbachi
                                      • fredo6F Offline
                                        Bimbachi,
                                        Alternatively, click on one of the colored filtering cross box. This should refresh the dialog box.
                                        Also, can you then try with this patch
                                        to drop into LIBFREDO6_Dir_41 folder
                                        Thanks very much
                                          Myro21
                                          Iv down loaded the plugin and put it the directory stated above but nothing shows up when i start up sketchup? im using a mac and have followed all the steps but still nothing... any help please
                                          • fredo6F Offline
                                            Do you have a menu Windows > LibFredo6 settings....?
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 109
                                            • 110
                                            • 97 / 110
