    Camera import and control
    23 Posts 6 Posters 5.4k Views 6 Watching
      mbark
      I am not sure if this is the right place to post, but i am new 😄 so bare with me.
      Is there a plugin or a way to import the camera's from 3ds Max into sketchup - and have them set up as scenes. They need to have the precise parameters regarding position (X,Y,Z), target (x,y,z), roll (tilt of the camera) and focal length.
      Also, is there a plugin where the scene and view can be controlled by using the exact same camera parameters - position (X,Y,Z), target (x,y,z), roll (tilt of the camera) and focal length.
      The goal is to use known camera parameters in sketchup.
      • mitcorbM Offline
        mitcorb
        My approach would be to use Sketchup command: Camera> Position Camera, and Camera> Field of View. I believe Jim Foltz has a plugin having to do with camera Roll. Use Window> Scenes to set up these positions and run the scenes sequentially with View> Animation> Play. Also, you can do your scene setups under View>, as I just rediscovered while checking the menus.
        Hope this helps. This is my approach since I do not use 3dsmax.
          mbark
          Thanks for the reply.
          I am though looking for a more precise way of setting up the camera.
          I have a well known camera with GPS measured position, and calculated target, so my pricision is down to centimeter lever.
          In Max one can set the camera parameters through number input, and it would be a script that can do that I am looking for.
            If you can get some simple data out of the 3ds file you can then import that to make cameras and scene-tabs in the SKP.
            Can you export name,eye,target,up,fov as
            name, x,y,z, x,y,z, x,y,z, angle
            one per line into a txt/csv file then it can be done...
            BUT the question is can you export the data from 3ds so readily ?
            If you can then please post a file and I show you how to make new cameras from it...
              mbark
              Sounds great.
              Actually i am using photomodeler - to calculate camera parameters, and it can deliver camera information i txt.
              I am not quite sure what the third coordinate is that you are refering to - the UP value.
              I can get the roll/til value which is in degrees - roll left or right.
              I can send a text file later today.
              Thanks!!
                You could also look at the PageExIm script available from Smustard.com for just $5.
                It writes and reads '.sup' files in the format
                SceneName;(-107.49665, -174.644951, 91.64628);(201.036983, 201.920125, -22.396436);(0.144554343836861, 0.17642847255434, 0.973641122667915);true;30.0
                plus other stuff about location and style etc...
                The 'true' part is for 'perspective'.
                Its main purpose is to duplicate scene-tab cameras between SKP files, but clearly if you make a .sup file out of 3ds it'd import it too [perhaps with some tweaks to the code etc which might be 'a step too far']...
                  The 'up' is a vector in Sketchup camera code to determine the 'roll' it could be simple to calculate that from an angle [from the vertical ?]...
                    mbark
                    I will look into the script.
                    Can you please explain what the following code describes (0.144554343836861, 0.17642847255434, 0.973641122667915)
                    Is it camera tilt parameters?
                      That's the 'up' vector.
                      For now forget the .sup file example, all I need to make a simple importer is a simple text file with
                      name, xeye,yeye,zeye, xtarget,ytarget,ztarget, rollangle, fovangle
                      I can then get the 'up' vector from all of that and make scene-tabs with cameras to suit...
                        mbark
                        Hi again
                        I have here two cameras that I would like get into sketchup. If you can explain the procedure and if there is a way to manipulate the cameras once in sketchup.
                        The coordinates follow
                        Camera_1 160,4 130,52 2,12 10,20 1,53 1,32 -1,52 26,89
                        Camera_2 2510,23 1263,25 2,56 12,25 4,89 2,39 2,56 16,96
                          What units are the xyz values ? meters/inches etc...
                          I assume you are using a ',' as a decimal-separator and separate the values with a 'space' !
                            Here's a first pass...
                            Copyright 2011 (c) TIG
                            All Rights Reserved.
                            THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
                            WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
                            MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                            Usage:
                            Menu "View" > "ImportCamera..."
                            Choose the file containing the camera data, in the following format:
                            name,xeye,yeye,zeye,xtarget,ytarget,ztarget,rollangle,fovangle
                            You can have one camera per line.
                            The xyz values should be in 'inches'.
                            The two angles should be in degrees.
                            If the ",rollangle," is replaced with ",upx,upy,upz," a vector can be used.
                            New scene-tabs are made, each called 'name', with cameras as specified.
                            Edit the ICVSEP and ICDSEP constants below to suit your typical file's
                            value-separator [' ',;:\t] and decimal.separator [. or ,]...
                            Donations:
                            info @ revitrev.org via PayPal.com
                            Version:
                            1.0 20110908 First issue.
                            Put into the Plugins folder and restart Sketchup - read the instructions!
                              mbark
                              Hi TIG
                              Sorry I havn't given a quick answer...
                              The script works!!!
                              Would it be hard work to thange the units from inches to meters?
                              Also, would it be possible to make a input panal inside sketchup where the camera values could be entered and manipulated.
                              I appreciate your help very much, and i didn't think it was possible to get the same precision in sketchup as in 3ds Max - awsome!!
                                @mbark said:
                                Hi TIG
                                Sorry I haven't given a quick answer...
                                The script works!!!
                                Would it be hard work to change the units from inches to meters?
                                Also, would it be possible to make a input panel inside Sketchup where the camera values could be entered and manipulated.
                                I appreciate your help very much, and i didn't think it was possible to get the same precision in Sketchup as in 3ds Max - awesome!!
                                This is a version that assumes the units are in 'meters'...
                                Usage:
                                The xyz values should be in 'METERS'.
                                Donations:
                                Version:
                                1.1 20110910 METER version.
                                TIGimportcamera.rb
                                  You can get a dialog that takes some input for camera data [but 'up' is a vector!] using this code [PC only, I'm afraid!]
                                  <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera Info..."</span><span class="syntaxkeyword">){</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">10624</span><span class="syntaxkeyword">)}</span><span class="syntaxdefault">unless&nbsp;file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxdefault"></span>
                                  copy+paste this code into a file called camera_info.rb in the Plugins folder and you get the new item in the menu after a restart...
                                    mbark
                                    Thanks TIG
                                    I have been looking for a way to get my exact camera information from max to sketchup for ..... a long time.
                                    Thank you for your time and work.
                                    • E Offline
                                      eco
                                      I was looking something like this but I have different camera coordinates information: xeye,yeye,zeye, xrotation,yrotation,zrotation, focallenght(mm), framesize(px)
                                        lapx
                                        pageexim is not working for me. Has anyone else had a problem getting it to work in su8? It makes the .sup file on export but when I try importing the .sup file it's doing nothing. It doesnt even give and error.
                                        Thanks,
                                        Lapx
                                          mbarker
                                          <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera Info..."</span><span class="syntaxkeyword">){</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">10624</span><span class="syntaxkeyword">)}</span><span class="syntaxdefault">unless file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxdefault"></span>
                                          Dear TIG
                                          It has been a long time since last and i would like to ask you a big favor regarding the camera import script. I used to have the user name mbark and you made the TIGimportcamera.rb. I am now using Sketchup 2015 and the script will not import. Can you help with an updated version. I would really appreciate it!
                                            I'd expect the old RB file still to work OK in v2015.
                                            However, how are you making the camera-data file ?
                                            Try Notepad++ and set the file's encoding to UTF8-without-BOM...
                                            Report back...
