    [Plugin] CleanUp
    974 Posts 217 Posters 832.9k Views 217 Watching
      @charly2008 said:
      I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
      That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
      • charly2008C Offline
        charly2008
        Thanks for the tip, I had an older version of TT_Lib2. Now it works again.
        Charly
        • dereiD Offline
          derei
          @thomthom said:
          Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
          Sorry,my mistake ! the model was on Monochrome style view and I forgot I had materials applied.That is why the Cleanup didn't worked as expected. It overlapped with plugin update, so I thought is a plugin issue.
          • Z Offline
            Zacchia
            @thomthom said:
            I really do not understand why.
            What is your Internet Explorer version btw?
            1. IE? Why is this important?
              If it had been IE6 it would. WebDialogs use the IE engine under Windows.
                leocallejas
                Hi ThomThom.... I just recently discovered your plugin, and I´m really excited to test it out, but I get that same blank window in Windows 7 x64 running Sketchup 8, and Internet Explorer 8. Here are my screenshots, maybe they'll help you sort it out.
                Cheers! 😄
                http://img694.imageshack.us/img694/8228/blankhr.jpg
                http://img217.imageshack.us/img217/8760/versionsq.jpg
                http://img821.imageshack.us/img821/6006/propertiest.jpg
                http://img163.imageshack.us/img163/7218/sourceh.jpg
                  I'll post an update to TT_Lib shortly. Not sure if it helps, but we'll see.
                  Meanwhile, do you see a Compatibility Files button in Windows explorer when you view the plugins folder?
                  • Z Offline
                    Zacchia
                    I do not understand this...
                      Cheers! 😄
                      Can you update to TT_Lib version 2.5.6 and report back if that made any difference?
                        That was for leocallejas - he's on Vista. You won't see such a button in XP.
                        If you want, you could try CleanUp 3.4.6 with TT_Lib 2.5.6 and see if that works.
                          blajnov
                          With the new library TT_Lib 2.5.6, the same problem, blank screen menu....
                            sigh I'm completely stomped. I have no idea why it fails on one computer but not the other - without any errors... 😞
                            I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?
                              blajnov
                              With the new library TT_Lib 2.5.6, the same problem, blank screen menu....[/quote]
                              [quote:344sw0qv]
                              I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?[/quote:344sw0qv]
                              Returned to the library and TT_Lib 2.5.4 CleanUp 3.1.4, instead TT_Lib 2.5.6 and CleanUp 3.1.6, it worked ...
                              It is unclear what the problem is!
                                Did you try the file I sent you?
                                  blajnov
                                  I apologize for any inconvenience, I threw inputbox.rb file in the wrong folder, now replaced in the folder 😄 \ Program Files (x86) \ Google \ Google SketchUp 8 \ Plugins \ TT_Lib2
                                  Everything works fine.
                                  Many thanks for the sympathy!
                                    Update TT_Lib to 2.5.7 - I hope this finally fixes things.
                                      leocallejas
                                      Yep, I see the "Compatibility Files" button when I'm im the Plugins folder.
                                      EDIT: Wow I seem to have missed a lot of posts.. lol. Reading.
                                        That might be causing the problems. Ensure you have admin rights and move the files from that folder to the plugins folder. Windows Vista/7 some times moves things to a ghost folder to "protect" users - but when it comes it the plugins folder it just causes problems.
                                          @leocallejas said:
                                          Didn't have to do that, TT_Lib 2.5.7 workes like a charm!
                                            leocallejas
                                            Didn't have to do that, TT_Lib 2.5.7 works like a charm! I'll keep that "compatibility files" thing in mind in case of further problems. Thanks a lot for the quick fix!
                                            Leo Callejas
                                            • 48
                                            • 49
                                            • 4 / 49
