    [Plugin] CleanUp
    974 Posts 217 Posters 833.9k Views 217 Watching
    • Z Offline
      Zacchia
      Hi Tom
      It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
        Cursed! 😞
        Ok, can you Right Click and empty window and click "View Source" ?
        • Z Offline
          Zacchia
          @thomthom said:
          Cursed! 😞
          In german lanuage "Quelltext anzeigen", hope you mean this...
            I really do not understand why.
            What is your Internet Explorer version btw?
            • charly2008C Offline
              charly2008
              Hi Thomas.
              I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
              Charly
              Command: Clean
              Command: Clean with last settings
                That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
                  charly2008
                  Thanks for the tip, I had an older version of TT_Lib2. Now it works again.
                  Charly
                  • dereiD Offline
                    derei
                    @thomthom said:
                    Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                    Sorry,my mistake ! the model was on Monochrome style view and I forgot I had materials applied.That is why the Cleanup didn't worked as expected. It overlapped with plugin update, so I thought is a plugin issue.
                    • Z Offline
                      Zacchia
                      1. IE? Why is this important?
                        If it had been IE6 it would. WebDialogs use the IE engine under Windows.
                          leocallejas
                          Hi ThomThom.... I just recently discovered your plugin, and I´m really excited to test it out, but I get that same blank window in Windows 7 x64 running Sketchup 8, and Internet Explorer 8. Here are my screenshots, maybe they'll help you sort it out.
                          Cheers! 😄
                          http://img694.imageshack.us/img694/8228/blankhr.jpg
                          http://img217.imageshack.us/img217/8760/versionsq.jpg
                          http://img821.imageshack.us/img821/6006/propertiest.jpg
                          http://img163.imageshack.us/img163/7218/sourceh.jpg
                            I'll post an update to TT_Lib shortly. Not sure if it helps, but we'll see.
                            Meanwhile, do you see a Compatibility Files button in Windows explorer when you view the plugins folder?
                            • Z Offline
                              Zacchia
                              I do not understand this...
                                Cheers! 😄
                                Can you update to TT_Lib version 2.5.6 and report back if that made any difference?
                                  That was for leocallejas - he's on Vista. You won't see such a button in XP.
                                  If you want, you could try CleanUp 3.4.6 with TT_Lib 2.5.6 and see if that works.
                                    blajnov
                                    With the new library TT_Lib 2.5.6, the same problem, blank screen menu....
                                      sigh I'm completely stomped. I have no idea why it fails on one computer but not the other - without any errors... 😞
                                      I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?
                                        blajnov
                                        With the new library TT_Lib 2.5.6, the same problem, blank screen menu....[/quote]
                                        [quote:344sw0qv]
                                        I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?[/quote:344sw0qv]
                                        Returned to the library and TT_Lib 2.5.4 CleanUp 3.1.4, instead TT_Lib 2.5.6 and CleanUp 3.1.6, it worked ...
                                        It is unclear what the problem is!
                                          Did you try the file I sent you?
                                            blajnov
                                            I apologize for any inconvenience, I threw inputbox.rb file in the wrong folder, now replaced in the folder 😄 \ Program Files (x86) \ Google \ Google SketchUp 8 \ Plugins \ TT_Lib2
                                            Everything works fine.
                                            Many thanks for the sympathy!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 48
                                            • 49
                                            • 19 / 49
