    WebDialog.set_html fails under Safari 5.0.6
    111 Posts 7 Posters 22.7k Views 7 Watching
      driven
      @thomthom said:
      TIG: The problem is that when you use .set_html you do not get access to local resources any more under OSX Safari 5.0.6+.
      have you got an example of .set_html that works on older Safari, I've been going through all my old bits and I can't find an example that ever worked, heres some variations of .set_url and .set_file that all (bar one) work under Safari 5.0.6, I'm not including the files, unless you want them, it's more about the syntax, which is slightly different from 5.0.3 if you use .set_file("file:///...) Safari adds an additional file:/ to the url and reports an error
      dlg1 = UI;;WebDialog.new("BoilerPlate1", true, "BP1", 200, 200, 110, 0, true);
      dlg1.set_url("file;///Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/WD_BoilerPlate_cln/demo/tests.html")
      dlg1.set_background_color("#fff")
      dlg1.show_modal
      #works
      dlg2 = UI;;WebDialog.new("BoilerPlate2", true, "BP2", 200, 200, 310, 0, true);
      dlg2.set_file("/Volumes/Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins/WD_BoilerPlate_cln/demo/elements.html")
      dlg2.set_background_color("#fff")
      dlg2.show_modal
      #works, BUT an external ajax call for js fails, local backup js loads instead
      dlg3 = UI;;WebDialog.new("BoilerPlate3", true, "BP3", 200, 200, 510, 0, true);
      dlg3.set_file("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/WD_BoilerPlate_cln/test/index.html")
      dlg3.set_background_color("pink")
      dlg3.show_modal
      #works
      dlg4 = UI;;WebDialog.new("BoilerPlate4", true, "BP4", 200, 200, 710, 0, true);
      dlg4.set_url("file;///volumes/Macintosh%20HD/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/WD_BoilerPlate_cln/test/index.html")
      dlg4.set_background_color("grey")
      dlg4.show_modal
      #works
      dlg5 = UI;;WebDialog.new("BoilerPlate5", true, "BP5", 200, 200, 910, 0, true);
      dlg5.set_url("file;//localhost/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/WD_BoilerPlate_cln/404.html")
      dlg5.set_background_color("#fff")
      dlg5.show_modal
      #works
      dlg6 = UI;;WebDialog.new("BoilerPlate6", true, "BP6", 200, 200, 1110, 0, true);
      dlg6.set_file("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
      dlg6.set_background_color("#fff")
      dlg6.show_modal
      #works
      dlg7 = UI;;WebDialog.new("BoilerPlate7", true, "BP7", 200, 200, 1310, 0, true);
      dlg7.set_url("file;///volumes/Macintosh%20HD/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
      dlg7.set_background_color("#fff")
      dlg7.show_modal
      #works
      dlg8 = UI;;WebDialog.new("BoilerPlate8", true, "BP8", 200, 200, 1510, 0, true);
      dlg8.set_url("file;//localhost/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
      dlg8.set_background_color("#fff")
      dlg8.show_modal
      #works
      dlg9 = UI;;WebDialog.new("BoilerPlate9", true, "BP9", 200, 200, 1710, 0, true);
      dlg9.set_url("http://localhost/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
      dlg9.set_background_color("#fff")
      dlg9.show_modal
      # DOSEN'T work[it is a pdf afterall]... but do I get a Not Found message
      #The requested URL /Library/Application Support/Google SketchUp 8/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf was not found on this server.
      dlg10 = UI;;WebDialog.new("aceSUedit", false,"ace", 900, 600, 50, 350, false);
      dlg10.set_url("http://upstairs.lan/cloud9/cloud9/support/ace/ModalWindow.html")
      dlg10.show_modal
      #works and is an extremely complex html with lots of dynamic content
      I'll set these all up on Safari 5.0.3 tomorrow and see how they fair.
      • Dan RathbunD Offline
        Dan Rathbun
        @driven said:
        ... if you use .set_file("file:///...) Safari adds an additional file:/ to the url and reports an error...
        I'm purty sure that it's the Sketchup API UI::WebDialog code that prepends all set_file() arguments with "file://", happens on Windows as well.
        I tried set_file("file://localhost/path/to/local/file.html")
        and got that Sketchup error dialog (I believe it had the Sketchup icon in the upper left of the caption bar,) saying:
        ' %(#8000BF)[Could not find file: "file://file://localhost/path/to/local/file.html"]'
        I would say that method should check to see if the substring is already there before prepending it.
        I'm not here much anymore.
          Dan Rathbun
          Here's a bug report at Webkit Bugzilla on local file:// handling broken.
          Webkit bug #10777
          It was reported in 2006 !
          The 'reporter' also filed a bug at apple: #4809075
          .. because he was unsure if it was Safari, or Webkit; but never got back to his original report and said what happened.
          So the status remains: UNCONFIRMED
          I tried to log into the apple bug reporter to check on #4809075, but got a login error.
            ...if you use .set_file("file:///...) Safari adds an additional file:/ to the url and reports an error...
            BUT surely that's not really an 'error' ? It's just a logical application of some rules.
            The .set_file() method is expecting a file path - like 'C:/temp/myfile.txt'.
            The .set_url() method is expecting a url like 'http://www.forums.sketchucation.com' OR 'file:///C:/temp/myfile.txt' if it's a local file path.
            The .set_file() method takes its argument and it prepends a hard-coded initial 'file:///' to make it into suitable 'url' friendly code, from the bald file path: this is just like what happens when you try to open a local file with UI.openURL(), which requires that you have added the initial 'file:///' to any local file path etc.
            The .set_**html**() method is expecting a some 'html code as text' and this is a more serious issue, to this side one.
              webdialog.set_html( 'Hello World<hr><img src="file:///Users/thomas/Desktop/helloworld.jpg" alt="image should be here"><hr>Bye World' )
              Very crude example, invalid HTML, but it's the bare bones. The image would load in older Safari.
              @dan rathbun said:
              P.S. : I wonder if Mac Sketchup changes any of these Safari security policies when it installs, to enable correct use of WebDialogs, ... and by upgrading to a newer Safari version, the policy file is overwritten. (So a comparison of the Safari manifest file, both pre and post Sketchup install, may also be in order.)
              Never been a problem before... Something must have changed at 5.0.6.
                .set_file and .set_url isn't really the problem here. They both work the same as pre-5.0.6 as far as I can tell.
                .set_html is the core of the problems.
                  Dan Rathbun
                  @thomthom said:
                  @dan rathbun said:
                  P.S. : I wonder if Mac Sketchup changes any of these Safari security policies when it installs, ...
                  Meaning, you have upgraded Safari a number of times in the past, without causing adverse effects on Sketchup WebDialogs ??
                    Dan Rathbun
                    And can someone check the Apple Bug site.. to see if anyone else has filed a local resource regression bug for 5.0.6 ??
                      Could this be the 'security update' that's messing it up?
                      WebKit in Apple Safari before 5.0.6 has improper libxslt security settings, which allows remote attackers to create arbitrary files, and consequently execute arbitrary code, via a crafted web site. NOTE: this may overlap CVE-2011-1425.
                      http://www.cvedetails.com/cve/CVE-2011-1774/ http://support.apple.com/kb/ht4808
                        Dan Rathbun
                        Refering to my earlier post on Security Policies, I went thru the Apple Developer Library, and the Webkit.org docs, looking for a similar policy list to the Chrome list. Could not find anything. (Sheesh.. I hate that Apple website, so hard to find anything.)
                        Has anyone checked to see if Safari has a manifest file like Chrome, with policy settings ??
                          Yes, at least not in terms of permissions. Updating Safari off course means updated render engine, like when you update IE. But never have I experienced blocking changes like this.
                            Summary
                            In order to link to local resources in webdialogs one has to use file:/// prefix.
                            Problem arise under OSX with Safari 5.0.6 or higher: local resources are not allowed to be accessed any more. Images, CSS and JS will not load. External resources do work though.
                            What might be happening:
                            Under windows when you use webdialog.set_html, document.location will report a file located in the user's temp folder.
                            Under OSX on the other hand, document.location reports about&#058;blank. So it appear to be feeding the HTML to the webdialog differently from Windows.
                            The current theory to why .set_html fails in 5.0.6 is that a security issue has been closed where about:blank pages where used to gain access to the local resources. Due to the design differences between Windows and OSX .set_html now fails to load local resources.
                            Workaround
                            Here is a quick bare bone wrapper class:
                            %(#BF0000)[Issue
                            Under OSX the garbage collector is not triggered upon SketchUp exit - so any webdialogs that's not been garbage collected will leave their temp files behiond. Looking into the matter...]
                            <span class="syntaxdefault"><br /></span><span class="syntaxcomment"># Custom WebDialog wrapper that works around problems with WebDialog#set_html<br /># under OSX after Safari 5.0.6 is installed.<br />#<br /># Example is bare bone without any error checking. Expand as you find fit.<br /></span><span class="syntaxdefault">class WebDialogPatch </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog<br /><br />  </span><span class="syntaxcomment"># @note Safari 5.0.6 made .set_html unusable under OSX because any links to<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#   resources ( Images, CSS, JS ) on the local computer failed to load.<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#   Previously it would work when you spesified file;/// but now it is denied.<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @param [String] html_string<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Nil]<br /></span><span class="syntaxdefault">  def set_html</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> html_string </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Clean up any old temp file.<br /></span><span class="syntaxdefault">    cleanup_temp_file</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Finalizer is attached to the webdialog so when it gets garbage collected<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># temp file is erased.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># <br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># The temp filename needs to be different from the last on in order for the<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># html to be loaded. If the name is the same the content is not refreshed.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># For both the temp directory and temp file handling with better error<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># handling it'd probably best to port `tmpdir.rb` and `tempfile.rb` from<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># the Standard Ruby Library.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># http://www.ruby-doc.org/stdlib-1.8.6/<br /></span><span class="syntaxdefault">    tempdir </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> ENV</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'TMPDIR'</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> ENV</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'TMP'</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> ENV</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'TEMP'</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    unique_seed </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"#{self.object_id}#{Time.now.to_i}"</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">hash</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">abs<br />    filename </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"webdialog_#{unique_seed}.html"<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> tempdir</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> filename </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    cleanup_proc </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.class.</span><span class="syntaxdefault">cleanup_temp_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dup </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">define_finalizer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> cleanup_proc </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Write the HTML content out to the temp file.<br /></span><span class="syntaxdefault">    File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">open</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'w'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> html_string </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    set_file_original</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    nil<br />  end<br />  <br />  </span><span class="syntaxcomment"># @tempfile is set to `nil` when using #set_file and #set_url so the temp file<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># will be deleted. Since the #set_html wrapper uses #set_file it must be<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># aliased<br /></span><span class="syntaxdefault">  unless private_method_defined</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">set_file_original </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Prevent redefining in case of script reloading which cause infinite loop.<br /></span><span class="syntaxdefault">    alias </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">set_file_original </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">set_file<br />    private </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">set_file_original<br />  end<br />  </span><span class="syntaxcomment"># @param [String] filename<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Nil]<br /></span><span class="syntaxdefault">  def set_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> filename </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    cleanup_temp_file</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    set_file_original</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> filename </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />  <br />  </span><span class="syntaxcomment"># @param [String] url<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Nil]<br /></span><span class="syntaxdefault">  def set_url</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> url </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    cleanup_temp_file</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    super<br />  end<br />  <br />  </span><span class="syntaxcomment"># @return [Nil]<br /></span><span class="syntaxdefault">  def cleanup_temp_file<br />    if </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile<br />      ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">undefine_finalizer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br />  end<br />  private </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">cleanup_temp_file<br />  <br />  </span><span class="syntaxcomment"># @private<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @see #set_html<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @see http://www.mikeperham.com/2010/02/24/the-trouble-with-ruby-finalizers/<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @param [String] filename<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @return [Proc]<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">cleanup_temp_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> filename </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    proc </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> filename </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> filename </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  end<br />  <br />end </span><span class="syntaxcomment"># class<br /></span><span class="syntaxdefault"> </span>
                            Revision 3
                              driven
                              a couple observation while trying to get my head around all of this.
                              firstly, in Apples and probably Googles eyes the title of this thread should probably be 'WebDialog.set_html finally works as expected under Safari 5.0.6'. It does not appear to be not considered a 'bug', but a security enhancement.
                              It seems to have been implemented in Safari 4, to stop about:blank pages pirating local files and that some problem/oversite has allowed files:/// and other anonymous url's to work with about:blank pages in SU WebDialog and other WebView apps.
                              I have a number of html editors and they use temp files written to the relative folder, so if I try to edit index.html (for example) all the links, src's, url's, etc.. all remain relative and are considered safe. if I open the temp from a different folder I get load errors.
                              Although I know temp files can be anywhere (with corrected links) I think they should be in the originating plugins subfolder if they are unavoidable.
                              I also think bypassing 'about:blank' completely by having an actual html file that is then updated dynamically is also preferable.
                              but, since I'm not writing the rubies, time permitting, I'll test whatever you want to try.
                                I'm implementing a workaround where I manually use a temp file and .set_file into a patch I hope to release very soon.
                                It seems that at implementation level of .set_html differs from OSX and Windows. Where under Windows they create a temp file and feed that file to the web control. Where under OSX this is not the case, which is why we get about:blank and therefore get affected by strengthens security controls.
                                  Dan Rathbun
                                  That's nice but it will depend on your Library ?
                                  Has anyone logged this with Google ?? I'd think they'd wish to release patches if Safari 5.0.6 will break WebDialogs on all Mac versions.
                                    The only thing you need to implement is TT::System.temp_path which returns the temp directory. Other than that, the code snipped I posted is standalone.
                                      Fixed a small bug in the sample code.
                                        Dan Rathbun
                                        Not personal.. but I'd prefer to rely on "tmpdir.rb" in the Standard Lib.
                                          Sure, it's just a bare bone example. In fact, it'd probably be best to use tempfile.rb to create the temp file as well.
                                            I did some further testing I found some issues which I addressed in my example: http://forums.sketchucation.com/viewtopic.php?f=180&t=39842&p=352375#p352375
                                            .set_file doesn't cause the content of the webdialog to update if the filename is the same. So I made the example generate a new file with a unique seed in the filename to ensure it's updated.
                                            .set_file and .set_url now immediately cleans up the temp file if .set_html was used prior.
                                            No more references to my TT_Lib in the example.
                                            Linked to the Standard Lib in the comments for more robust temp file handlers.
                                            • 3 / 6
