    1.5k Posts 476 Posters 3.9m Views 476 Watching
    • dereiD Offline
      derei
      By the way, is it just for RoundCorner or for other plugins like ToolsonSurface?
      I will try with TOS too, as soon as I can and I will post the conclusions.
      Thanks for your attention.
      DESIGNER AND ARTIST DEREI.UK
        TonyGasz
        I do not understand anything, set as indicated.
        when doing surgery just gives an error.
        They are used - Google SketchUp 8
        -LibFredo6 3.7c - 07 Jun 11
        -RoundCorner 2.3a - 26 May 11
        what could be the problem, do put a small block parameters 0.10 and 6. help
        sorry for my english I'm from Russia
        • dereiD Offline
          derei
          If you don't tell what error (maybe a print-screen), I wonder how somebody could help. πŸ˜•
            TonyGasz
            I think I figured out in your plugin, I stood apart from the fact that I listed above - Podium render, when I removed the folder completely plug and insert a blank without any plug-ins in addition to the required course, then it worked. so here, but about the Scrin is a common mistake Google's screen. πŸ˜‰
              kimley2011
              Very helpful! thanks a lot!!!
                lilsamofro
                I was having a problem with RoundCorner...
                Both 2.3a and Fredolib 3.7 are installed
                I have had curviloft and fredoscale installed for some time and they have been a great help, (Many Thanks!!).
                I installed Roundcorner the same way but it simply wont work, the Roundcorner toolbar appears and the Roundcorner extension appears in the FredoCollection tool tab but clicking on the icons on the tool bar do nothing, similarly if i select it through the tools menu nothing happens.
                Curviloft and Fredoscale still work fine, however select edges mouse for Round Corner simply wont appear, do you know any reason why this may be?
                  dizain
                  Hello,
                  I have uploaded ROUNDCORNER_Dir_23 (with ZLoader__RoundCorner) and LIBFREDO6_Dir_40 (with LibFredo6) in the dir πŸ˜„ \ Program Files \ Google \ Google SketchUp 8 \ Plugins, but the plugin does not load, there is not even the toolbar, or and not appear any error message.
                  I ask for help ...
                  • fredo6F Offline
                    @dizain said:
                    Hello,
                    I ask for help ...
                    Since you have LibFredo6 40, could you go to Window > LibFredo6 Settings > View Trace Log files and check if it says something about RoundCorner (and other scripts).
                      dizain
                      Hello Fredo,
                      I attach the txt file View trace log files.
                      I do not see anomalies ...
                      thank you very much
                      LibFredo6Trace_8_1314724767421.txt
                      • fredo6F Offline
                        @dizain said:
                        Hello Fredo,
                        thank you very much
                        It seems you do not have a folder ROUNDCORNER_Dir_23 in the Plugins directory (or if you have it, it is not properly unzipped - you must have a RoundCorner.plugin file). I suggest you check the content, which should be something like
                        Note that the Zloader__RoundCorner.rb with LibFredo6 4.0+ is of no use (you can delete it).
                          dizain
                          Dear Fredo,
                          my file is identical to your!
                          Where is the problem??
                          thank you very much
                          • fredo6F Offline
                            @dizain said:
                            Dear Fredo,
                            thank you very much
                            Very simple!
                            From the trace file, I see that you have put LibFredo6 in an additional folder Plugin_8.
                            You must move all my plugins (FredoScale, RoundCorner, etc...) in this folder as well (this is indicated in the doc). It should then work.
                            PS: I could of course allow to have my plugins in other folders, but I decided not to because it could quickly become messy if you have version in different places.
                              dizain
                              Thanks Fredo,
                              I had suspected that was what the problem resolved.
                              Thanks again.
                                stoneshawnp
                                Greetings.
                                I am somewhat new to the forum & just getting into the whole Plugin's scene, but very excited.
                                I have enjoyed the RoundCorner tool for sometime, but after installing the "training" version of TGI3D Amorph (link below), now I get a "Bug Splat" everytime I try to execute a "RoundCorners" option, even on the most simple box. I have updated the Fredo6 Library to 4.2, but the results are the same. Does anyone have any ideas?
                                http://www.tgi3d.com/index.php?Page=Download
                                Thanks for any feedback, Shawn
                                Google Splat Log files for this problem
                                  I have Tgi and round corner under the same SU 8 install (on XP) and have never had an issue. Try to remove Tgi plugin (or rather simply rename the tgi3d.rbs to something else with a different extension like tgi3d.txt) and restart SU. See if round corner crashes now.
                                    stoneshawnp
                                    Thanks! That was a followup question actually, how to "deactivate" or "uninstall" a Plugin.. Some seem to be just very simple Ruby scripts (not that I know how to read them, I don't), but others (like TGI3d Amorph) seem to propagate through many of the menus, etc.. and do not offer an obvious "uninstall/deactivate" option that I could see.
                                    Anyway, tried what you said (eg. renaming TGI3DS.RPS to *.TXT and observed 2 things
                                    (1) ALL things related to TGI3dS disappeared from SU 8 (cool)
                                    (2) My BugSplat on Edging 1 face of a simple cube is still there (Not cool)
                                    Any other suggestions? I have attached the new BugSplat log files for any of you why can glean something from them? πŸ˜‰
                                    Help!
                                    Thx, Shawn
                                    BugSplat files w/TGI3dS disabled
                                      As you have learnt, any file in the Plugins folder ending in .rb or .rbs is auto-loaded by Sketchup as it starts.
                                      I usually add .TXT after the .rb/.rbs ending of name [rather than instead of], as I then don't have to decide what the original suffix was! [others add a '!']. If later on you decide you want to load a particular tool for that session only you can do so by opening Window > Ruby Console and typing load "filename.rb.TXT" and it will then load for that session only.
                                      Now onto the problem... Have you loaded or updated any other plugins recently?
                                      If so try disabling these is turn by 'renaming' and restarting Sketchup and trying RoundCorner each time to see if it still splats... Once you have success you have a suspect - try renaming all of the other ones back again and see if all is well with the one suspect script disabled - if you find it let us know!
                                      There are rarely clashes between scripts - most of the ones available from here are relatively stable/friendly ...
                                        stoneshawnp
                                        Thanks TIG. I am learning a bit more about the Architecture here.
                                        I renamed my Plugin's directory & created a new empty one.
                                        Then I started re-installing the Plugin's 1-by-1, and so far RoundCorners as such, is working again.
                                        When (if) i figure out the offending Plugin, I will post it here.
                                        Thanks for helping a Newbie! πŸ˜‰
                                          rollerhaus
                                          Fredo, you're a God-send! Thank you so much. One question for you...is there a way to map textures to the curves or have it to use already placed maps? It doesn't seem to like image maps πŸ˜•
                                          • fredo6F Offline
                                            Do you have an example to illustrate it?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 74
                                            • 75
                                            • 22 / 75
