[Plugin] 2dBoolean ver1.3.1 beta UPDATE 20 dec 2013
Joel, thanks so much for this plugin!! I have 2d elevations that I needed to glue to a massing, and this works absolutely perfect for my needs. Good work!
Andy -
can anyone check if this pluging works with meshes?
when importing several pieces from GoogleMaps, the pieces usually end overlapping each other, causing texture errors.
You cant use 3D boolean because obviously, meshes, are not solids.
So I would usually "zorro" the different meshes, and cut the parts that overlap. Obviously, a HUGE work when you are dealing with dozens of different GoogleEarth imported meshes. If this plugin works with those, it will be great!
Hey, I missed some posts in here!
Andybot. I'm glad someone have use for this plugin! Appreciate it!(we all know TIG's part of this of course)
AcesHigh.
I've seen your request in other post regarding this subject. Like I said. I think it lies more in the 3d domain, since the surfaces are not flat.
IF the intersecting geometry would be flat at intersectionpoints, 2dBoolean should activate. But I see your case you would need a subtraction-algorythm.
At this point 2dboolean only subtracts geometry outside the face it's lying on(or selected face).
What you are asking for is really needed, and I will see what can be done about that in the future. I'm kinda busy at the moment.
Have to deal with Hatchfaces webdialog, which unfortunaly proves very difficult.
I thought I only had to learn Javascript, HTML, CSS and JQUERY . But there is need for some JSON and maybe AJAX as well. Kinda much required to make a simple dialog if you ask me. -
Nice update.
But! If you are gonna further developp this tool, and display it in this thread with my icons included. Please don't scramble the code, so other can benefit from your code like you did on mine and Tig's.
Besides your plugin will be lost in this thread posting it here.
Best regards.
Sorry, but actually I prefer the code scrambled. The code is not very optimized because I did it to translate to C after.
I don't use any line of your code. I used a simplicans planar theory. (I taked your one icon, feel free of use my icons)Best regards
watch out, the 's around here will unscramble your code and make sure you're telling the truth
Ok. If you say so.
That's ok. I don't mind that. 2 min PS for me.
Ok, about that. I find it somewhat strange to post stuff for free, scrambled. thats not very helpful for other programmers.. Personally I rather tell to much then nothing at all.
Actually I'm working in 2D boolean of polygons in Sketchup because I need for other stuff. I did this plugin using simplicians theory.
May be could be usefull for someone.You need to select two groups with a general planar polygon.
General planar polygon = A single polygon or a polygon consisting of a set of non-intersecting single polygons. -
New version 1.3.1 added:
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=39661
Whole lot is rewritten so there may be lot of things broken. I suggest a lot of testing and report back bugs and wishes
Intersections should now be a Little quicker. And some new stuff as well.
Make sure to read the manual in second post.
Will try and add to pluginstore later.
I added it to the SketchUcation PluginStore for you...
http://sketchucation.com/resources/pluginstore?pln=2dBoolean
You might want to edit the listing and add documentation, release notes etc... -
Thank you TIG. Really appreciate it!
I havent done any update for a long time and must get up to date with how the pluginstore works, more in detail.
I suppose I should move the manual there to, perhaps ? Did not manage to downsize it to less then 1.8 mb.
