    How can I disable keyboard shortcuts while in a tool?
    5 Posts 5 Posters 3.2k Views 5 Watching
      Alan Chatham
      I'm developing a plug-in to allow for First Person Shooter style WASD movement in SketchUp, and I'm wondering if it's possible to disable or override SketchUp's keyboard shortcuts when it's active? Right now, my janky fix is to require that Shift be held down while navigating with WASD, since that seems to block out shortcuts, but obviously having to keep holding down the shift key isn't ideal. Thanks!
        You can't...
        You can only disable the VCB in a tool, but keys are read anyway...
        Use the arrow-keys, or number-keypad - these shouldn't be short-cutted...
        • Dan RathbunD Offline
          Dan Rathbun
          @tig said:
          You can't...
          .. which I do not understand. We can 'intercept' all manner of key combos... but the keys still "bubble up" to the application window!
          It's annoying! It can cause another tool to inadvertently become active in the middle of a Ruby tool process.
          I'm not here much anymore.
            @dan rathbun said:
            @tig said:
            You can't...
            Yup. I've requested a few times that we should be able to return true/false to the key events in order to control the event bubbling.
            I've often wanted to intercept the key presses.
            There are some characters that can be pressed while a tool is active, if they are typed after a number. c d e g m s - so we can type, 1m 1mm 1cm 1dm 1deg 1s etc...
            So SketchUp natively intercepts keys for its own usage. So I really think custom Ruby tool should have that power as well.
            • renderizaR Offline
              renderiza
              Hi, I am running on this same issue... Has this been fixed yet or is there a trick around this?
              Thanks in advance!
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
