⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Is there a model exporter plugin that writes C++ files?
15 Posts 6 Posters 546 Views 6 Watching
  • O Offline
    OricAtmos
    Hey,
    I'm looking for a model exporter plugin that writes C++ files I can just drop into my C++ projects to get the models into my program. Is there such a plugin?
    Ralf
      There is a SDK that uses C++ to write custom importers/exporters BUT you'll have to write the code πŸ˜’
        I don't quite understand the request.
        You want a 3d model written as a C++ file?
        If so, would it not then depend in the data structure you use in your C++ app?
        • O Offline
          OricAtmos
          Yes. πŸ˜„
          I would use the data structures the exporter gave me. All I really needed would be some arrays with vertex, face and normal data for the given model. Then I could easily render the models with OpenGL. Face colors would be nice, but not really neccessary.
            Why do you need C++ ?
            If you search for exporters there are several Ruby-based ones - for DXF, OBJ, STL, KML, CSV, TSV etc as well as the built-in ones...
            If you know the format you need and there isn't an existing one then see how it might be similar to an existing one and modify it... 'Binary' format files are NOT easy to write but 'text' based ones are... πŸ˜•
            • O Offline
              OricAtmos
              Because it would be quick and easy.
              I don't need any specific format, I just need to be able to use the models in my C++ program and render them with OpenGL. I could start looking for C++ libraries that import collada for example, because that's built-in. But experience tells me, getting to know my way around a new library can be a lot of work.
                Yes. πŸ˜„
                If you got C++ skills then I'd think there'd be little work for you to write a small ruby script that exports the model data the way you want. Ruby gives you all you just mentioned. And then you could easily output it in the exact format you want.
                  bigstick
                  I'm told, by someone that knows a lot about this stuff, that C++ is 10x faster (or so) than Ruby for exporting geometry.
                  • O Offline
                    OricAtmos
                    I think there's a misunderstanding. I don't care whether the exporter is written in Ruby or in C++. I want the output to be C or C++ that I can compile in my C++ project. But since there doesn't seem to be an exporter like that, I'll have to write my own.
                      You want the model to output as a text file that happens to be in C++ syntax, right? That is simple enough if you know C++, and you have your own syntax your are trying to tie into. But no one else would be able to write it for you very well, since no one else knows exactly how you would want to handle the C++ file structure.
                      OBJ is just a text file, for example. Why not just learn how to parse their structure instead of making up your own file structure?
                        I'm sure there is a very simple light weight OBJ importers in C++. Such a common format.
                        • O Offline
                          OricAtmos
                          That was the idea, yes.
                          That is simple enough if you know C++, and you have your own syntax your are trying to tie into. But no one else would be able to write it for you very well, sine no one else knows exactly how you would want to handle the C++ file structure.
                          I don't want anyone to write anything for me. I just wanted to know if there already was an exporter like this. πŸ˜„
                          Basically I wanted to save me the step of parsing an input file and just let the compiler do it. I just want to have two 3D models in my program, no more.
                          • O Offline
                            OricAtmos
                            Thanks for the suggestion, I will have a look into the OBJ format. I don't know much about 3D file formats so I wasn't aware that OBJ is very common.
                            • O Offline
                              OricAtmos
                              Hey,
                              I just wanted to say that I'm using the Open Asset Import Library (http://assimp.sourceforge.net/ ) now to load my two models. It can do a lot more than I need but it's not that hard to use.
                                Jim
                                Thanks, I was not aware of this library, but it looks like a nice thing.
