    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 298.2k Views 41 Watching
      OK...
      I now see the issue. πŸ˜•
      Before you do any of the steps I mentioned in converting the group into a cutting component we need to ensure that the groups bounds are reset so its bbox is parallel to the face...
      Insert these steps between making the grouped hatch and flattening it.
      We find the group's rotation in 3d relative to the main axes.
      We rotate the faces in side the group so they lie on the X_AXIS and the bounds are a rectangle.
      We rotate the group back so it is back on the face.
      tr=Geom::Transformation.new(bbc,zaxis)
      where 'bbc' is the group.bounds.center and zaxis is the face.normal will transform the group.entities axes correctly so, then transform the group.bound.center back to bbc which itself should be transformed translated inversed back to the origin...
      This is all getting too too complex. πŸ˜’
      I'll try to write some simple generic code to turn a grouped face that's coplanar to a face into a group that is placed on the face with its z-axis==face.normal...watch this space...
      • jolranJ Offline
        jolran
        OK! Now I think I've actually found the problem. And it's kind of a careless and stupid one.
        In the code I first make a group called gp2. Then I add the selected component instance to the group.
        I do that by it's definition and transformation. Now since I did it in an iterator using e=instance (e.definition, e.transformation) the transformation is using defintion.origin!! I must use another transformation in (e.definition, e.?)
        Be back soon πŸ˜„
        Edited: Sorry TIG I was typing when your answer came, I think this issue is THE problem
        Or maybe at least have a look at it before you make a fix. This is happening at the very first in the plugin.
        • jolranJ Offline
          jolran
          Γ„hh.. 😞 Nothing seams to work.. I'm trying to add the function to use groups in the plugin. Like the testingcode from TIG.
          Anyway, here is the part where the sketchup selection get's turned into groups. ...
          Probably some basic faults in here. Would appreciate a cleanup on this.. I do have to add the instance by definition to cents, no? Also the groups in cents don't get exploded.
          Edited Well, found a thread about adding groups. So now that feature is added(code changed), but not without issues.. At least one can use groups for 2dbooleans, now. Could be useful.
          Did not fix transformation issue, though... My guess is I cannot use the groups own instance transformation?
          Very wierd to see groups as instances though. Illogical... lets see what TIG will comes up with..
           if comps ##comps=Collection, array of instances and groups #######
                  gp2=ents.add_group(); cents=gp2.entities; gp2.name=name; gp2.layer=hatch_layer
          	   comps.each{|e| #Add instance to group and erase original.
          	       if e.class==Sketchup;;ComponentInstance
                         cents.add_instance(e.definition, e.transformation)
          			   e.erase!
          		   if e.class==Sketchup;;Group
          		     gp2ents = e.parent.entities
                       gp2defn = e.entities.parent
                       gp2tran = e.transformation
                       cents.add_instance(gp2defn, gp2tran) ### group instances
                       e.erase! ### remove original groups  ###################
          	 ####### Explode everything inside gp2.entities ####
          	   cents.to_a.each{|e|
          	           e.explode
          	           e.explode
          • jolranJ Offline
            jolran
            Yes, I feel it maybe be a complex transformation, no? TIG, are you working on something or should I dig in to the rotation part?
            I'm still not sure if I'm creating the instances from definition correct. I've split the code up for testing.
            After exploding the instances into group B.BOX looks OK.
            After intersection and deleting edges still OK.
            It's when turning group.to_component the B.BOX reaches to ORIGIN.
            I've already shown this in picture, just doublechecked it again..
            Although! If I manually make component from group at each step described. In Sketchup, the boundingbox reaches to ORIGIN. So that's why I'm wondering if the instances has been created improperly from the definition, regarding the transformation.
            Once again: When saying B.BOX I mean entity bounds from doubleclicking the component.
            • jolranJ Offline
              jolran
              BTW. Is there any possibility to explode the instances first thing? Collect the exploded entities and put them into a group, before they merge with underlying entities. I know there are some issues in this field.. Don't have time to test that right now.
              But maybe that would be better than messing around with definitions and transformations..
              After surfing info in this forum, I think doing above is not possible.. Not without trouble anyway..
                This code takes any 'flat' 'group' drawn on a 'face' [that's at any orientation] and turns it into a gluing/cutting component... it needs completing for the name/layer etc and also testing for nested groups... You also don't need the start/commit operation code as it'll be inside another set - it's put there for testing separate from the main code...
                ### turns the 'group' into a component glued/cutting 'face'
                def g2cut(group, face)
                  model=Sketchup.active_model
                  model.start_operation('g2cut')
                  ents=model.entities
                  pents=group.parent.entities
                  gents=group.entities
                  bb=group.bounds
                  bbc=bb.center
                  norm=face.normal
                  if pents==ents
                    xaxis=X_AXIS.clone
                    yaxis=Y_AXIS.clone
                    zaxis=Z_AXIS.clone
                  else ###??? unsure if we need to redefine for nested groups?
                    xaxis=X_AXIS.clone
                    yaxis=Y_AXIS.clone
                    zaxis=Z_AXIS.clone
                  ve=group.transformation.origin.vector_to(bbc)
                  tr=Geom;;Transformation.translation(ve)
                  group.transform!(tr)
                  tr=Geom;;Transformation.translation(ve.reverse)
                  gents.transform_entities(tr, gents.to_a)### centered
                  tr=Geom;;Transformation.new(group.transformation.origin, norm)
                  tr=Geom;;Transformation.rotation(group.transformation.origin, group.transformation.xaxis, -90.degrees)
                  ang=xaxis.angle_between(group.transformation.xaxis)
                  tr=Geom;;Transformation.rotation(group.transformation.origin, zaxis, ang)
                  pt=gents[0].vertices[0].position
                  ve=Geom;;Vector3d.new(0,0,-(pt.z))
                  gents.parent.invalidate_bounds
                  bc=group.bounds.center
                  ve=bc.vector_to(bbc)
                  v=ve.reverse.transform(group.transformation.inverse)
                  tr=Geom;;Transformation.translation(v)
                  ### make component
                  inst=group.to_component
                  defn=inst.definition
                  be=defn.behavior
                  be.is2d=true
                  be.cuts_opening=true
                  be.snapto=0
                  inst.glued_to=face
                  ### complete these items...
                  #defn.name=
                  #inst.name=
                  #inst.layer=
                  model.commit_operation
                • jolranJ Offline
                  jolran
                  Yeeehhaaa TIG!! β˜€ BIG job from you. Thanks a million+ times.
                  That's quite some extra bit of code. We will have to see some performance tests when/if I manage to add this.
                  Already the plugin is quite processor intensive, doing all the iterators face_classify, erasing stuff etc..We won't know until tested.
                  In general, do transformations put a lot of strain on the calculation/computation?
                  Anyway, thanks again. This will be interesting to test.
                  • jolranJ Offline
                    jolran
                    Much better TIG!
                    There are still some issues. Pic says all. Now I was gonna put this "is as" a method at the end no, passing arguments? There won't be any problem with putting declarations inside a method I persume. I mean for ex model=Sketchup.active_model..
                    It works perfectly on Y axis. X axis it flips upside down. Off axis, a little troublesome..
                    The definition has quite a lot of transformations πŸ˜„ might take a while before I understand what's going on, and can track issues.
                    Performance is good. Havent tested on super heavy geometry.
                    • jolranJ Offline
                      jolran
                      Going through your script trying to get a grasp on it. It's comparing axis to vectors a lot, no? I wonder would it be more predictable to use crossproducts where possible? I don't know, from for ex face.normal? Just a wild guess.
                      • jolranJ Offline
                        jolran
                        Talking to myself mostly... Another pic(will delete older pics later on, in case I'm overusing this function a little to much).
                        I think we are hitting some bug here. Isent this strange behavior?
                        • jolranJ Offline
                          jolran
                          TIG, yes I got true on all of those.
                          Did a little test! Placed the face at origin and the component on top. Changed the transformation to 0 rotation=NO transformation. Transformation is not needed when placed on ORIGIN, of course. Did the test on both the created component instance, and on a new freshly inserted instance. And voila it glues, and cuts the face.
                          Test nr2 I removed ANY transformation made on the component, (after group.to_component).Still on ORIGIN.
                          And it worked as well??? Of course this only works when the component is lying flat at 0 position.
                          Is this some sort of bug? Cause I get the impression you can only invoke cutting behavior IF you do it on 0,0,0 and 0 rotation= ORIGIN ❓
                          Maybe the problem has to do with what position you create the component from group(group.to_component).
                          And it's position relative to insertion-point.
                          SO what's the fix? Transform the group to ORIGIN. Make the comp and remove it back to where it was?
                          Seams a very strange solution but can't figure out the logic in this one..
                          I guess just have to find a transformation that get the group to origin flat from ALL postions, do the behavior and transform back with an inversion of that transformation.
                          **Edited:**As it turns out TIG's rotation transformation is all that's needed(first rotation), if it only get's translated to the ground at 0.
                          Now, this must be done in 1 transformation OR multiplied because I am going to use THIS transformation.inverted to get back to the face. PFFIooUUH. Don't have a grasp of this transformation stuff yet. It's quite complex to understand when doing multiple transformation's.
                            I'm absolutely sure we can streamline this code a lot - I threw it together to show it was 'do-able'...........
                            • jolranJ Offline
                              jolran
                              I trying to understand what you are getting at. πŸ˜„ The cutting behavior is still not working.
                              Unless face is on "ground" an I apply NO transformation or O rotation(same thing).
                              Blue Z axis should point in the face.normal direction? To have a chance invoking inst.glued_to=face
                              Well It does, after your rotations, and the instance is glued to the face.
                              But must not the World axis origin be at the instance to get cutting behavior?
                              To do that: move group to global(world?) origin. Reset any rotations= group made flat. THEN make instance from group and move back to face?? I know it sounds strange but why is the inputpoint at orgin if inserting an instance(copy) of the result?
                              • jolranJ Offline
                                jolran
                                Are you testing at ORIGIN by a chance? Or does it work for you in all positions? Another pic..
                                EDITED After some rigorous testing, I have a strong feeling the entities inside the group is off according to the group. Must experiment more with rotation axis etc, but time is running out for this.. Must move on.
                                Give it another day..
                                  You seem to be invoking it at a weird point - use it after all of the other processes leave the exploded-instances/trimmed group...
                                  • jolranJ Offline
                                    jolran
                                    I threw it together to show it was 'do-able'...........quote]
                                    πŸ˜„
                                    Honestly, I don't know if I can be of much assistance in that regard. There's so much going on with rotations and stuff I get a migraine. I can of course try, but just by touching the computer you will beat me to it πŸ˜„
                                    So, you don't think theres any trouble in the starting of the script, where I create the instances from definition?
                                    Do you want my sample W.I.P code to see if there is trouble elsewhere? It's without menys and linehatching..
                                    And quite documented..
                                    I don't know. At the end? As a definition passing group and face. Maybe thats wrong timing..
                                      Here's some shorter updated code that I think now works better to make a selected 'group' that has its faces overlaid onto a 'face' into a cutting component...
                                        ents=model.entities
                                        bbc=group.bounds.center
                                        norm=face.normal
                                        tr=Geom;;Transformation.new(bbc, norm)
                                        gents.transform_entities(tr.inverse, gents.to_a)
                                        ve=ORIGIN.vector_to(bbc)
                                        ve.transform!(group.transformation.inverse)
                                        tr=Geom;;Transformation.new(ve)
                                        ### make component
                                        be=defn.behavior
                                        be.is2d=true
                                        be.snapto=0
                                        inst.glued_to=face
                                        #defn.name=
                                        #inst.name=
                                        #inst.layer=
                                      Please try it out... again remember that you don't need the start/commit operation parts IF it's to be embedded into a wider set of code...
                                      • jolranJ Offline
                                        jolran
                                        After some testing. I've only had 1 incident so far when the axis.center wasn't on face, on an extreme angle. Otherwise it seams to be working πŸ˜„
                                        Now, when axis align better on face(thanks to TIG), one can explode and the materials merge on face underneath more consistent.
                                        It's a perfect modeling tool. 😲
                                        Textures will transfer as well. And I suppose the option of saving a component with textures gives many possibilities.
                                        There are some experiments to be made, to see what can be done....
                                        • jolranJ Offline
                                          jolran
                                          A lot of experiments going on. I welcome ideas and possible options that could be added or improved πŸ’­
                                          look at the dialogs what is planned, already.
                                          Got the tiling going pretty nicely. (Not from file yet) It's quite slow if having complex patterns. Fewer (tile) copies is considerably faster regardless of the sum of edges πŸ˜• So crosshatching may be restricted to linehatches only. Rather create more patterns=larger library than doing a 2nd computation? Patterns with faces is slowest.
                                          Since the goal is to have a big library of hatches, they may be difficult to remember by name. So I guess webdialog is the best solution. Im not to sure about that one yet, though. Havent done any webdialogs, yet. It might be a very step learning curve to get it right for all plattforms ❓ On the pic there is a inputbox version with dropdownlist. For round 1 that might be the solution, there are a lot of quirks to sort out first..
                                          http://sketchupapi.blogspot.com/2011/07/gofaster-parameter.html
                                          FYI: saw this post on API blog and performed som tests with this method(not the pic, more complex pattern), and boy what an speed increase!
                                          On test 1: 5.226 seconds
                                          On test 2: 2.793 seconds! Just typing "true" in the model.start_operation('bla bla', true)
                                          On test 3: 2.496 seconds. Same test as 2, but outliner closed.
                                          There are some issues with this method though..
                                          404 Not Found
                                          (forums.sketchucation.com)
                                          This is of course interesting as well. But maybe before doing any performance increases I will work on the features.
                                          • jolranJ Offline
                                            jolran
                                            Excellent TIG!
                                            So far so good! Havent failed yet. Works in off axis, strange rotations etc.
                                            Needs some more testing of course, but THANK YOU! THANK YOU!
                                            Things can probably move forward now.
                                            Oh Yeah, and the code is much more streamlined, as you call it. πŸ‘
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 17
                                            • 18
                                            • 12 / 18
