    Problem with Projection Extension plugin for SU8
    7 Posts 4 Posters 720 Views 4 Watching
      Cody Richeson
      This plugin, which can be found at
      http://modelisation.nancy.archi.fr/rld/plugin_details.php?id=303
      Doesn't seem to work. I've installed and reinstalled the plugin EXACTLY as stated on the instructions, and the toolbar refuses to show up in SU8, even though the Ruby Console says that it recognizes it. A comment on the link furthers my suspicion that there may be a compatibility issue with version 8. Has anyone else encountered such a problem?
        Assuming you've extracted the zip file correctly, the next step would be to make sure you've ticked the box for it in Preferences>Extensions.
          Cody Richeson
          Turns out that it was there the whole time, I just didn't go to View >> Toolbars >> Projections. However, I have a new problem: only one of the 17 icons works; the second one, which which adds guide points. The others do not respond as implied in the PDF document that came with the zip. Clicking on the icon simply causes nothing to happen.
            Do you get any message related to the tool in the bottom left part of the screen?
              Cody Richeson
              When I click on any of the buttons associated with this plugin, it just reads "Ready" on the bottom left corner. As soon as I move the mouse after clicking, it just gives me a brief description of what the tool does. But it does not actually affect any of the geometry I try to apply it to.
                kyyu
                Try the updated version: http://forums.sketchucation.com/viewtopic.php?t=20140
                  Also run it with the Ruby Console open and report any error messages from there...
