    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 368.5k Views 89 Watching
    • Didier BurD
      Didier Bur
      Are some faces reversed ? (apparently not on your screenshot, but still searching for a cause...)
      DB
        rpinkham
        The faces are all oriented correctly. I deleted the face and re-drew it with the same results.
        • Didier BurD
          Didier Bur
          ❓ πŸ˜• 😲 😞
          DB
          • FletchF
            Fletch
            Thanks for the update - looking forward to trying it out.
            one tiny thing...
            Searching the terms "component spray" and "compo spray"(without the quotes) on the Ruby Depot website via the link provided in the original post yeilds ZERO results. 😐
            "Your search - compo spray - did not match any documents. " (even if it claims to be a google search, I think the search is set up incorrectly somehow)
            Here's the link to the Compo Spray tool on the Ruby Depot website. (had to do a "real" google search specific to the site to find it. πŸ˜’ )
            http://modelisation.nancy.archi.fr/rld/plugin_details.php?id=76
            (I didn't see the tiny "Discover it HERE" under the "blog post" on the Ruby Depot at first - which has the correct link)
            C'est la vie, n'est-ce pas? πŸ˜„
            Fletch
            • Didier BurD
              Didier Bur
              Hi Fletch,
              Yes I know that, I must fix it for a long time 😳
              Note that even if the search return matches, these matches only direct you to the section, not the plugin page itself πŸ‘Ž
              DB
              • T
                t6nis
                I also had the problem Compo Spray was not working. The reason was, it is actually included in the SFC Powerbar set (didn't notice that!). So you have to remove it from there first. Or use the Powebar one.
                  What is this SFC Powerbar?
                  • charly2008C
                    charly2008
                    Hi thomthom,
                    have a look here:
                    http://rhin.crai.archi.fr/rld/plugin_details.php?id=607
                    http://forums.sketchucation.com/viewtopic.php?t=14770
                    Charly
                      I tried to set up my plugins to be loaded from a custom folder so I could easily sync between multiple SketchUp versions and computers.
                      For the most of the plugins it went fine, but I got an error with Component Spray because it tries to load the language files from the SketchUp plugins folder instead of where the plugin is actually located.
                      If you use File.dirname( __FILE__ ) to get the path instead of Sketchup.find_support_file then it would solve this and the plugin could be installed to any location the user wants.
                        32bits
                        I have problems with this plugin, could anyone help?
                        Here is what the console tells me:
                        Error; #<FloatDomainError; Infinity>
                        (eval);2844;in `to_i'
                        (eval);2844;in `cs_n_points'
                        (eval);1905;in `facesBrushTool'
                        (eval);279;in `cs_dialog'
                        (eval);340;in `call'
                        (eval);340;in `show_modal'
                        (eval);340;in `cs_dialog'
                        (eval);116;in `compoSpray_main'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/compoSprayToolbar.rb;17
                        (eval);2486;in `call'
                        (eval);2486
                        Thank you very much! πŸ‘
                          rock1
                          i'm havin' a problem using this tool i hv a horizontal resolution of 1024 pixels and i don't want to change that, i can't find the green tick button. please didier, can u tweak this window for me? πŸ˜’
                          Signature removed by SCF Admin
                          • Didier BurD
                            Didier Bur
                            As it is said in the doc, go to settings and change your dialog box style (with/without scrollbars)settings.jpg.
                            DB
                              rock1
                              @didier bur said:
                              As it is said in the doc, go to settings and change your dialog box style (with/without scrollbars)[attachment=0:12is74un]<!-- ia0 -->settings.jpg<!-- ia0 -->[/attachment:12is74un].
                              thanks a lot
                                rock1
                                Can this plugin be tweaked so that in the components lists, the thumbnails of the components be
                                shown, just like we see in the component window of the sketchup? 😎
                                • L
                                  lapx
                                  DB,
                                  Thanks for such a useful program. I'm having more trouble with this one when I was having so much success with the old dialogue box 😞 I like the ideas though. I know it will work it self out.
                                  What am I doing wrong here? tried to populate by selection not working well, "shape is not available yet". What is the "shape" refering to?
                                  Is this tool similar to Chris's component on surface is similar?
                                  Once again, thanks!
                                    rachmatrf
                                    Hi Didier///
                                    THank you for this amazing plugin... You Rock...
                                    • V
                                      voxdei_999
                                      first at all thank's for this useful plugin didier, but i'm having problems changing the default settings in the panel, simply i can't, why?
                                      i have a x64 xp os & the su v8 & of course the v 1.4.2 compo spray
                                      • Didier BurD
                                        Didier Bur
                                        😲 😲 πŸ˜’
                                        Never heard of such a behaviour ! Are the fields blanks ? Can't you select items in the lists ? Can't you move the sliders ?
                                        Please let me know more details...
                                        Regards,
                                        DB
                                        • V
                                          voxdei_999
                                          thank you didier about your interest, but i resolved the problem, i just update the internet explorer (i was the v6,'cause i prefer chrome) so now its ok. πŸ˜„ πŸ˜„
                                          anyway the problem was the sliders, they did'nt move, the other settings were able.. 😳
                                          • boofredlayB
                                            boofredlay
                                            I keep getting 7 script errors every time I launch the tool. I have to close out as it is unusable. Hmmm.
                                            I just downloaded it today and unzipped it into the plugins folder.
                                            • 13
                                            • 14
                                            • 6 / 14
