    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 336.6k Views 89 Watching
    • Didier BurD Offline
      Didier Bur
      button to the toolbar which would open the PDF file
      Why not, good idea.
      what slider are you using
      @TIG: I'm using a custom slider programmed in js by K. Gilbert http://kegisiteweb.com/presentation.php. It's copyright free but rather old, that's maybe why it freezes under some specific configurations os/web browser/javascript version ?
      It is in the JS folder in CompoSpray folder, and I've only added some trivial functions at the end of the file.
      DB
        gistman
        "Plugin downloaded 12179 times" I just wanted to say thank you for all of your work. You and others here have made SU such a great tool.
          Mra
          Anyone else getting the error "Cannot place component on selection" when it is just a basic ground mesh and assigning using the "point" method?
            manwe
            I've huge problem with using this plugin. Properties of this plugins is quite high & I've wide screen display so I can't reach the accept button...
            My website: http://webnarts.pl
              Didier Bur
              @mra: check your altitudes settings in the dialog, possibly a bug in there 😳
              or did you select anything that isn't face(s) ?
              @manwe: click on the Settings icon and tell the script to use sliders in the Style dialog list.
              Hope this helps,
              DB
                rpinkham
                I'm having some trouble with this tool not covering the selected face completely. It works on most but there are a handful of faces on this triangulated surface that clump my grass proxy together. I am pre-selecting the face and using the "selected faces" option.
                Any ideas?
                  Didier Bur
                  @rpinkham: maybe do you have some other faces hidden ?
                  DB
                    rpinkham
                    Didier,
                    Thanks for the reply. There is no hidden geometry. It happens in a few locations in this larger scale site model...
                      Didier Bur
                      Are some faces reversed ? (apparently not on your screenshot, but still searching for a cause...)
                      DB
                        rpinkham
                        The faces are all oriented correctly. I deleted the face and re-drew it with the same results.
                          Didier Bur
                          ❓ πŸ˜• 😲 😞
                          DB
                          • FletchF Offline
                            Fletch
                            Thanks for the update - looking forward to trying it out.
                            one tiny thing...
                            Searching the terms "component spray" and "compo spray"(without the quotes) on the Ruby Depot website via the link provided in the original post yeilds ZERO results. 😐
                            "Your search - compo spray - did not match any documents. " (even if it claims to be a google search, I think the search is set up incorrectly somehow)
                            Here's the link to the Compo Spray tool on the Ruby Depot website. (had to do a "real" google search specific to the site to find it. πŸ˜’ )
                            http://modelisation.nancy.archi.fr/rld/plugin_details.php?id=76
                            (I didn't see the tiny "Discover it HERE" under the "blog post" on the Ruby Depot at first - which has the correct link)
                            C'est la vie, n'est-ce pas? πŸ˜„
                            Fletch
                              Didier Bur
                              Hi Fletch,
                              Yes I know that, I must fix it for a long time 😳
                              Note that even if the search return matches, these matches only direct you to the section, not the plugin page itself πŸ‘Ž
                              DB
                                t6nis
                                I also had the problem Compo Spray was not working. The reason was, it is actually included in the SFC Powerbar set (didn't notice that!). So you have to remove it from there first. Or use the Powebar one.
                                  What is this SFC Powerbar?
                                  • charly2008C Offline
                                    charly2008
                                    Hi thomthom,
                                    have a look here:
                                    http://rhin.crai.archi.fr/rld/plugin_details.php?id=607
                                    http://forums.sketchucation.com/viewtopic.php?t=14770
                                    Charly
                                      I tried to set up my plugins to be loaded from a custom folder so I could easily sync between multiple SketchUp versions and computers.
                                      For the most of the plugins it went fine, but I got an error with Component Spray because it tries to load the language files from the SketchUp plugins folder instead of where the plugin is actually located.
                                      If you use File.dirname( __FILE__ ) to get the path instead of Sketchup.find_support_file then it would solve this and the plugin could be installed to any location the user wants.
                                      • 3 Offline
                                        32bits
                                        I have problems with this plugin, could anyone help?
                                        Here is what the console tells me:
                                        Error; #<FloatDomainError; Infinity>
                                        (eval);2844;in `to_i'
                                        (eval);2844;in `cs_n_points'
                                        (eval);1905;in `facesBrushTool'
                                        (eval);279;in `cs_dialog'
                                        (eval);340;in `call'
                                        (eval);340;in `show_modal'
                                        (eval);340;in `cs_dialog'
                                        (eval);116;in `compoSpray_main'
                                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/compoSprayToolbar.rb;17
                                        (eval);2486;in `call'
                                        (eval);2486
                                        Thank you very much! πŸ‘
                                          rock1
                                          i'm havin' a problem using this tool i hv a horizontal resolution of 1024 pixels and i don't want to change that, i can't find the green tick button. please didier, can u tweak this window for me? πŸ˜’
                                          Signature removed by SCF Admin
                                            Didier Bur
                                            As it is said in the doc, go to settings and change your dialog box style (with/without scrollbars)settings.jpg.
                                            DB
                                            • 13
                                            • 14
                                            • 6 / 14
