    [idea plugin] push + group + move
    6 Posts 3 Posters 584 Views 3 Watching
      jorge2011
      Idea for a plugin:
      I find it interesting to create stairs, tables, etc ... using as a base drawing in 2D.
      operating
      01 - run the plugin> set starting height and thickness.
      02 - to click on a face> create a group with the thickness and height set will.
      03 - Pressing the Ctrl key, and I click on other side> creates a group with the thickness and heightx2 set will.
      something like this plugin
      http://hinoado.com/index.cgi?id=4&eid=136
      is it possible? interesting?
      • EarthMoverE Offline
        EarthMover
        Trying to understand what the plugin in the link does. It looks to give four ways to handle 2D CAD lines depending on what they represent. Does that sound right. I can't read chinese, so I'm just guess based on this .gif in the link you gave. Are you trying to get a plugin that does the same thing or something a little different? Can you provide an image describing what you are asking for? Might be easier to get it accomplished if the masters here have something more to go on.
        Content Creator at Skapeup
        • TIGT Online
          Actually it's in Japanese... πŸ˜’
          πŸ€“
          But these tools already seem to do what you want... so why not use them ?
          The scripts are editable and the meaning of the Japanese words is pretty clear from their variable names and use in the dialogs - so making an English version is not so hard [or ask the author if there's an English version ??]... I see that the scripts do use an awful lot of $ global variables... which are never recommended - it's a clash waiting to happen - and these would be best recast as @ or @@ variables with their classes... πŸ€“
            jorge2011
            Thank for responding
            The Japanese plugin is interesting, but it generates that sketchup is closed sometimes.
            My idea is a similar plugin, but:
            first> set starting parameters of push-pull and move
            second> click on the face ( this creates push-pull and move x1)
            third> to click on another face + key Ctrl(this creates push-pull and move x2)
            quarter> click on another face + key Ctrl(this creates push-pull and move x3)
            fifth> click on another face + key Ctrl(this creates push-pull and move x4)
            ..... etc
            This idea seems good to create stairs using the basis of a 2D drawing (eg imported from autocad)
            understand my idea?
            • TIGT Online
              Yes.
              So why don't you just write it [and launch it] as a Tool [ class] so that the dialog only appears the first time the tool in activated, then after the OK the @state changes... with that new @state each picked point finds a face to process and uses the dialog's values, repeating until another tool is activated...
              The processing is quite simple too. Use a pick_helper to get the face below the clicked point. Clone the face into the entities of a new group=model.active_entities.add_group() [you could limit a 'valid face' to be one within the active_entities, or alternatively transform it's info to suit, if it's inside a group/instance]. The cloning should copy all inner_ loops and the face.outer_loop, and remove holes ensure the same face.normal direction and face.material, face.back_material, face.layer etc etc... Then make a new transformation tr=Geom::Transformation.translation([0,0,dialogZ]) [here I assume you only want to move the face 'up' by a give Z]. Then use it to transform the face to where its wanted with group.entities.transform_entities(tr,face.vertices) and then face.pushpull(dialogThickness)... Repeat πŸ€“
                jorge2011
                Mr. Tig. Thank you very much for the explanation.
                Unfortunately I do not understand programming. : (
                It's asking a lot, you program this plugin?
                Thank you very much for your time
