    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      Kelly, what are you trying to install? (LibFreo will not do anything - it is just a "background" library for a bunch of Fredo's "real" tools)
      • W Offline
        wagoneer
        Sorry Gaieus, realised I hadn't said what I was doing as I hit 'submit'.....
        I want to use FredoScale. I have installed as per instructions, and have also installed RoundCorner. Enclosed is a picture of my plugins.
        • fredo6F Offline
          Wagoneer
          You have a file __loader.rb in the Sketchup Plugin directory.
          I don't know how you manage to have it there, but try to remove it and check if it works
          PS: for RoundCorner, you did not do the correct installation too. Please read the main thread and check the footprint. It seems that your unzip method does not create the proper folder and files. I would suggest that you unzip in a neutral place, then check the files and folders and then copy to the Sketchup directory.
          • W Offline
            wagoneer
            Fredo, thank you very much. I also downloaded FredoScale to my Mac at home last night where I only use the inbuilt OSX extraction software and it worked fine. Seems the problems were with the Zipeg extraction software. Having just thrown that software away and downloaded your plug-ins again, everything works fine.
            Cheers folks.
            Kelly
              lavangmuathu
              thank you so much , great
                billjest
                Thank you this transforms the whole package for me.
                  gobilman06
                  Hi there i already install lilfredo6 plugins but the thing is i cant see the icon in my tool bar. pls help... cheers!
                    Do you know why you installed LibFredo6 in your Plugins directory? Or are you just installing all the plugins you can find?
                    This is a support file for many of Fredo's excellent plugins. It is required by them to operate correctly.
                    • fredo6F Offline
                      At least, do you see the menu Windows > LibFredo6 Settings....?
                      If so, you just have to install the plugin (like FredoScale, RoundCorner, ...) and it should be OK.
                        gobilman06
                        No worries already sort it out. thanks a lot!
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v4.0a - 23 Aug 11
                          LibFredo6 4.0 is a major technical release. The intention is to simplify the installation of my plugins and make their loading more robust, with error detection and protection.
                          A main feature of LibFred06 4.0 is that the ZLoader__xxx.rb files are no longer used(it will work however even if you still have them in your plugin folder, but it is advised to delete them). This means that my plugin will now be published as a simple folder (like ROUNDCORNER_Dir_22) to be put in the same directory as LibFredo6. The plugins will only be loaded if you have LibFredo6 installed and load errors will be tracked and reported.
                          LibFredo6 4.0 also includes a few plugin maintenance utilities available in the Windows > LibFredo6 Settings... menu:
                          1) Purge Obsolete files
                          This utility shows the files which are no longer useful and that you can safely delete. Indeed, you will see there all the ZLoader__xxx.rb files which are now ignored.
                          2) Plugin load performances
                          It displays the time for loading the plugins based on LibFredo6. I am interested in getting a feedback on these load times as it seems to be different on different machines and systems.
                          3) Trace Log viewers
                          LibFredo6 4.0 stores some traces (in a temporary folder). Currently this is mainly related to the load cycle of the scripts. If an error has happened it will be recorded there. Note that there is n Export feature (as a TXT file) which might be useful for reporting problems to the author if needed.
                          4) Plugin directory location
                          Just to recall that LibFredo6 (and all my scripts) can be located in another directory than the standard SU one.
                          In this respect, it might be useful to install 000_AdditionalPluginFolders.rb script. This will allow you to specify additional plugin directories and put LibFredo6 there.
                          I recommend to install LibFredo6 v4.0 as it will be more robust and easier (for me) to support.
                          See Main Post for detailed documentation and download.
                          • bac9-flclB Offline
                            bac9-flcl
                            Great release! 😍
                            However, there seems to be a small issue... It seems that if you won't manually delete an old ZLoader, the new menu won't appear (and perhaps the library won't be loaded properly?). The problem is that I don't remember how exactly that ZLoader file was called, something like ZLoader__LibFredo.rb, but I'm not sure at all, - just deleted it and there is now no way to know the exact name, unfortunately. 😕 And it's not there in LibFredo 3.7b archive I found around, so perhaps it's some ancient file from a very old release. Anyway, after I've deleted it, everything loaded properly, and is now working well. 😄
                              Lulliloo1
                              There are a lot of links ABOUT '[Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'. I've spent quite some time unsuccessfully looking for the link to actually download '[Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'. Would someone please provide that? It would be helpful to others to also provide that as part of this subject.
                                In the first post, there is a big Download button under which there is the link (or click on the image below - you need to be logged in)
                                http://forums.sketchucation.com/download/file.php?id=49285
                                  Lulliloo1
                                  ref my post this morning regarding downloading:
                                  The download link did not work with Google Chrome, but it did with Windows Explorer (9). Problem solved...
                                    that's odd. I've never had any trouble downloading any files from here with Chrome. You might want to check your settings in Chrome.
                                      bimbachi
                                      hello
                                      i'm having problem with "Check Plugins for Update"
                                      attached screen info
                                      any idea how to solve it?
                                      regards
                                      ps.-i'm on mac, osx 10.7.1
                                      • fredo6F Offline
                                        @bimbachi said:
                                        hello
                                        regards
                                        Can you check your version of Safari.
                                        If it is Safari 5.0.6, then bad luck, there is a big issue (which is under resolution, see that thread)
                                        Thanks to confirm. Also, do you see the images in the dialog box (I mean the small + and - at the top of the table, on left)?
                                        PS: I hope I can publish a fix soon.
                                          bimbachi
                                          Safari is Version 5.1 (7534.48.3)
                                          You are right images not showing correctly.
                                          regards
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
                                            LibFredo6 4.1 is a technical release which normally fixes some issues for recent version of Mac OS and Safari 5.0.6 and above (images not displayed and check for update not working).
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 108
                                            • 109
                                            • 17 / 109
