    Back face/material reverse
    24 Posts 5 Posters 2.3k Views 5 Watching
      Alienizer
      Either I'm insane or Sketchup is s.up πŸ‘Š
      I've been trying everything and still it isn't working right. Here is the code...
      def reverseBackFaces
        view = Sketchup.active_model.active_view
        @ip = Sketchup;;InputPoint.new
        eyevec = view.camera.eye.vector_to(view.camera.target)
        i = 0
        y = view.vpheight-1
        unless y < 0
          Sketchup.set_status_text(y.to_s)
          x = view.vpwidth-1
          unless x < 0
            @ip.pick view, x, y
            if @ip.valid? and @ip.face
              if eyevec.dot(@ip.face.normal) >= 0
                @ip.face.material = @ip.face.back_material
                @ip.face.back_material = nil
                @ip.face.reverse!
                i += 1
            x -= 1
          y -= 1
        Sketchup.set_status_text(i.to_s+" faces reversed")
      It work, then it doesn't, then it does, then it doesn't. What's wrong with my code? I can't find anything wrong 😑
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
      • Dan RathbunD Offline
        Dan Rathbun
        Uh... the UI::Inputpoint class, needs to be used within a Tool class instance.
        The pick method is normally called from within one of the mouse button callbacks of your tool.
        I'm not here much anymore.
          Alienizer
          I don't think it makes any difference how it is used. It accept a view and a screen point and has no idea that the point comes from a mouse or any other screen poiting device. The Mouse and InputPoint are not related at all. Otherwise, it would be mouse.get_item_it_points_to or something like that, where you can't change the x and y. It has no idea it's from a mouse event, nor for a tool.
            What would you like to happen ? In words, not code...
              Alienizer
              Back face/material reverse, I know you have a script for that, but I want to make my own where it scans the screen and reverse any faces that are facing back at the camera. Then I want to make it so that if you hover the mouse over your model, it'll do the same, but only on the face your mouse is pointing at.
              The code works, but if I rotate my model 90deg CW, it works half way! Some faces are not reversed, and some that should not, are!
                You need to make it [and launch it] as a Sketchup Tool.
                Then you can get the mouse position on screen and find the face below the mouse if any, and then flip it [and front/back materials] if you are looking at the back of it and it has a material etc...
                  Alienizer
                  ?? My code works fine 100% of the time on any models in SU7, it's screwy in SU8. Perhaps it's a bug in SU8, and nothing wrong with my code?
                    How is your code finding the mouse position without a tool to monitor the cursor ?
                    How is the input_point finding anything other than the near top left screen pixel point ?
                    Perhaps you haven't posted all of the code but as it stands it will not do what you want 'on its own'...
                      Dan Rathbun
                      Alan.. it would likely be easier for you to start with letting the user use the built-in SelectionTool to choose single or multiple faces, then react to changes in the Selection set, ie: Sketchup.active_model.selection
                      You could add a call to your reverse face method in the mouse context menu... or get a bit fancier with a SelectionObserver
                      P.S. : The InputPoint class is defined within the UI module for a reason. It's meant to interact with the user.
                        Alienizer
                        It's not using the mouse! If you read my code, I have 2 for loops to scan the screen viewport.
                        Later I will add mouse support, but my code now is only viewport scanning.
                          Alienizer
                          @dan rathbun said:
                          Alan..
                          I know what you mean, but I found out in another thread that raytest is FUBAR in SU8, pick is more likely using the same code as raytest.
                          That explain why my code works 100% in SU7 but not in SU8
                          from thread...
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=31326&p=275718&hilit=FUBAR#p275718
                          @thomthom said:
                          Why do you not want to use an InputPoint? You can use the ip.face to test if you got the point from a face and ignore the rest.
                          But, yes, you can shoot a ray:
                          ` ray = view.pickray(x, y)
                          result = model.ray_test( ray )
                          TODO: Recast on hidden entities`
                          Then remember that in SU8 the ray_test is FUBAR.
                            Your code does indeed decrement x & y by 1 [having set them to the bottom-right screen-pixel] so it should scan the whole screen ?
                            The model.raytest() does work OK now in the latest SUpv8M1 but your method should work OK too...
                            Read Dan's comments...
                              Alienizer
                              def onMouseMove(flags, x, y, view)
                                Sketchup.set_status_text(x.to_s+" ; "+y.to_s)
                              Dan, the above code show the mouse coord to be 0,0 at the top-left corner of the viewport, regardless where the window is on the desktop. Any reference to screen coords are within the viewport, not the physical screen. I know about the status text, SK needs to refresh for it to show, and it gets replaces when you move the mouse.
                              TIG, my version is 8.0.4011 in the 'About' box.
                                Dan Rathbun
                                1) **Sketchup.set_status_text()**
                                does not work well outside a custom Tool instance, because there must be another tool active (either someone else's custom Tool, or one of the OEM tools.)
                                As soon as you move the mouse 1 pixel, or Sketchup decides (per some other criteria,) to redraw the UI, ... your message will be overwritten. (It can happen so fast, that the user never has time to read your message.)
                                2) You are not scanning the view. (Yes you are, I see now the unless loop.)
                                ..removed...
                                3) And perhaps (because UI::InputPoint uses inferencing,)
                                you might wish to use Sketchup::PickHelper instead.
                                EDITED AGAIN: removed confusing subject matter.
                                  Dan Rathbun
                                  Yup.. sorry I got confused. Removed bogus suggestions.
                                  and you do have MR1 of ver 8
                                    Dan Rathbun
                                    > end
                                    or ...
                                      Sketchup.set_status_text("x; #{x} , y; #{y}")
                                    BTW.. on Window... you can use a Coordinate Tool that displays in model units:
                                    Sketchup.send_action( 21324 )
                                    the tool_name is "CoordinateTool" but there doesn't seem to be a send_action string for it.
                                      Alienizer
                                      @dan rathbun said:
                                      or ...
                                      > end
                                      or...
                                        Sketchup.set_status_text("x=%d, y=%d"%[x,y])
                                      How did you come up with 21324?
                                        Dan Rathbun
                                        I cheat! 🀣
                                        Really I make a copy of all the SU binary executables, and put them in a %(#804000)[Dev/_EXE] folder, renaming them thus:
                                        SketchUp.exe to SketchUp.8.0.4811.exe so they have ver and build in the name.
                                        Then I open these copies in MS Visual Studio, to check resources (like String Tables, Menu Definitions, etc.)
                                        Many of the ids are already listed in the API doc: Sketchup.send_action()
                                          Alienizer
                                          Ah!
                                            Alienizer
                                            Problem solved.
                                            After doing more testing, displaying the dot(face.normal, ray) returned <0 and when viewed cam rotated 45deg it was >0
                                            So after applying a transformation_at the dot() returned the correct cosine. So now my code works perfectly
