    Write all faces id's and point information to text file
    13 Posts 3 Posters 1.4k Views 3 Watching
    • N Offline
      neon_daytona
      Thanks for the quick reply.
      There is no selection of faces. All the faces have to be written out. So your code should work.
      dX and dY in my case are not the width and height of the face.
      Basically I need these 3 steps:
      1. Select a face.
      2. Select the extreme points for that face at its bottom. (Point 1 and Point 4 in the attached image)
      3. difference in coordinates for these 2 points is my dX and dY.
      Need to do this for all the faces in the model
      • TIGT Online
        Assuming your face is an orthogonal rectangle then the dX=bb.width and dY=bb.height [oddly the 'Z-height' in the SKP is called the 'bb.depth' !]
        Unfortunately your explanation is illogical.
        Points 1 and 4 are dX apart [without recourse to finding their coordinates at all!]
        If the face is not flat or orthogonal or a rectangle then the issue is more complex but still solvable...
        Please explain a little better...
        • N Offline
          neon_daytona
          Points 1 and 4 are definitely dX apart but may not be in the same Y coordiante.
          As I mentioned in my first post, the face can be of any shape.
          I guess this new image will clear the question. Sorry for the confusion.
          There are 2 faces in the XY plane in the image. The first face on the left, I need dX and dY between point 1 and 4. In the second face on the right, I need dX and dY between points 1 and 6. The faces can be of any shape and have as many edges as possible.
          But the common thing is that all faces are in XY plane. So I need to find the edge/line that is at the bottom of the face and pick the 2 points attached to line to get the dX and dY.
            ktkoh
            A question along similar lines:
            I am trying to write the input data to a file named like the rb file and in the same directory as the rb file. This will provide users with their on default data not what the author picked. Currently in windows the file is written to the desktop and I have not found code to change it. Where I would like it is in .....plugins\K2WS.
            Keith
            • TIGT Online
              Shashi
              That's much clearer...
              The faces are 'flat' in the Z-plane BUT can any number of vertices and you need to find the length of the edge that has a vertex that has the minimum Y value, since every vertex will have two faces the edge required is the one where its other vertex also has the minimum Y value.
              One scenario not covered is what if the minimum Y vertex has two edges that both have other vertices that have the same Y - I assume we take the one with the lesser X ?
              Here's some code
              faces=[]
              Sketchup.active_model.active_entities.each{|e|faces << e if e.class==Sketchup;;Face and e.normal.z.abs>0.9999}
              ### == 'flat'
              num="1"
              text="No,dX,dY\n"
              faces.each{|face|
                pts=[]
                verts=face.vertices
                verts.each{|v|pts << v.position}
                pt=pts[0].clone
                minY=pt.y
                minX=pt.x
                pts.each{|p|
                  if p.y < minY
                    pt=p.clone
                    minY=pt.y
                    minX=pt.x
                ### pt is at minY vertex
                ve=verts[0]
                verts.each{|v|ve=v if v.position==pt}
                ### ve is minY vertex
                edges=ve.edges
                edges.each{|e|edges.delete(e) if not face.edges.include?(e)}
                ### 'edges' is just the face's 2 edges with 'minY'
                edge=edges[0]
                ey=edge.other_vertex(ve).position.y
                nedges=[]
                edges.each{|e|
                  if e.other_vertex(ve).position.y <= ey
                    nedges << e
                if not nedges[1]
                  nedge=nedges[0]
                else
                  n0=nedges[0]
                  n1=nedges[1]
                  if n0.other_vertex(ve).position.x <= n1.other_vertex(ve).position.x
                    nedge=n0
                  else
                    nedge=n1
                ### 'nedge' is the required edge
                ps=nedge.start.position
                pe=nedge.end.position
                dX=(ps.x-pe.x).abs.to_s
                dY=(ps.y-pe.y).abs.to_s
                ### now add data to 'text'
                text << num+","+dX+","+dY+"\n"
                num.next!
                ### '1' >> '2' etc
              ### now write the completed 'text' to a file
              file=File.join(Sketchup.active_model.path, Sketchup.active_model.title+"_FaceDump.txt")
              fi=File.open(file, "w")
              fi.puts(text)
              fi.close
              ### done!
              this is untested - please try and report back...
              • TIGT Online
                Keith
                Your separate question.... πŸ˜‰
                The .rb file's details are got from the special __FILE__ variable which returns the full path the the .rb file.
                So let's assume that the Ruby file is called ' keith.rb'...
                Then
                rb=__FILE__ >>> 'C:\Program Files\Google\Google SketchUp 7\Plugins\K2WS\keith.rb'
                To find its folder use
                folder=File.dirname(rb) >>> 'C:\Program Files\Google\Google SketchUp 7\Plugins\K2WS'
                To find its name use
                name=File.basename(rb,".*") >>> 'keith'
                To compile the path to the new matching .txt file use
                txtfile=File.join(folder, name+".txt") >>> 'C:\Program Files\Google\Google SketchUp 7\Plugins\K2WS\keith.txt'
                NOTE: another 'one-step' way [but somewhat less clear] would be this
                txtfile=__FILE__.gsub(/.rb$/,'.txt')
                Which directly returns 'C:\Program Files\Google\Google SketchUp 7\Plugins\K2WS\keith.txt' without any intermediate steps...
                I show the File parsing/join methods because they do have wider uses...
                Remember that ' txtfile' is only a string representing the file path and you need to use the File.open... etc to make the file and write to it... See the example[s] in the post[s] below...
                πŸ€“
                  ktkoh
                  Thanks TIG That should help me out. I had already worked out the file new/open etc. but found no help on directories etc.
                  Keith
                  • N Offline
                    neon_daytona
                    Thanks TIG for the help.
                    There was one small typo, which I edited.
                    The text file is always saved to πŸ˜„ directory not in the active model path.
                    Need to verify that, But the main functionality works like a charm.
                    Trying it on bigger models and will then update back.
                    Thanks Again
                    • TIGT Online
                      Shashi
                      Glad to hear it helped...
                      I hadn't tested the code as I typed it 'cold', from memory as one stream of consciousness - can you tell me were my 'typo is' - I can then edit the original code-block so that anyone else trying to use it doesn't have to fret about sorting that out... Saving the data file with the model OR to a fixed file-path is your choice - so if that's the 'typo' then I need not worry... as I just needed a 'FaceDump.txt' file to write to... πŸ˜‰
                      • N Offline
                        neon_daytona
                        TIG,
                        this is the typo
                        minX=py.x
                        needs to be changed to
                        minX=pt.x
                        • TIGT Online
                          Thanks! fixed it... πŸ€“
