    PLUGIN REQUEST - GFA Calculation
    12 Posts 6 Posters 2.3k Views 6 Watching
    • H Offline
      haynesc
      Hello
      the may already be a plugin for this - I dont know
      See attached image
      I would like a plugin to display the AREA and GFA of a group like the one shown as red
      GFA = [AREA] * [FLOORS] ....
      [FLOORS] = [HEIGHT] / [FLOOR TO FLOOR HEIGHT]
      [FLOOR TO FLOOR HEIGHT] = USER SPECIFIED
      Any thoughts ?
      • honoluludesktopH Offline
        honoluludesktop
        Might be difficult to do for building volumes that have different floor areas, heights, etc.
        • sdmitchS Offline
          sdmitch
          For a simple block, load and run the following code from the Ruby Console
          def gfa_calc
          	mod=Sketchup.active_model
          	sel=mod.selection
          	if sel.first.is_a?(Sketchup;;Group)
          		ans=inputbox(["Floor to Floor spacing"],[3.m],"GFA calculation")
          		if !ans then return end
          		f2f=ans[0].to_l
          		unit=Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
          		case unit
          			when 0;uf = 1.0;u="inches"
          			when 1;uf = 12.0;u="feet"
          			when 2;uf=0.03937007874;u="mm"
          			when 3;uf=0.3937007874;u="cm"
          			when 4;uf=39.37007874;u="m"
          		width=sel.first.bounds.max.x - sel.first.bounds.min.x
          		depth=sel.first.bounds.max.y - sel.first.bounds.min.y
          		area = (width * depth)/ uf**2
          		height=sel.first.bounds.max.z - sel.first.bounds.min.z
          		floors = height/f2f; height /= uf; ta = area * floors
          		UI.messagebox "Area;     #{area}\nHeight; #{height}\nFloor to Floor; #{f2f}\nFloors;  #{floors}\nGFA;     #{ta}"
          http://sdmitch.blogspot.com/
          • H Offline
            haynesc
            A few dialog popups to assign building names to simple blocks and produce a schedule for all of them would be nice
            Assuming each Building is a Group ... you could name the Group - "CP-03" - Building Name
            Data for CP 03
            From Skecthup :
            Area
            Height
            From Data Entry:
            Floor-to-Floor Height
            From Formula Calculation:
            Floors: [Height] / [Floor-to-Floor Height]
            GFA: [Floors]*[Area]
            • sdmitchS Offline
              sdmitch
              GFA_Report.rb is my attempt to solve your problem. In addition to displaying the information in a messagebox, it writes it to a .txt file.
              GFA Report
              • H Offline
                haynesc
                thanks sdmitch ...
                Its a start πŸ˜„ ... What I was thinking of was a dialog box system that would work as a live & update-able schedule for Assigned Buildings ...
                Something like my attach image
                http://img694.imageshack.us/img694/592/skpgfa0000layercomp1.jpg
                http://img832.imageshack.us/img832/3964/skpgfa0001layercomp2.jpg
                • sdmitchS Offline
                  sdmitch
                  That's just a little beyond my limited ability. Maybe someone else has done something like that. Good luck.
                    riserise
                    funny to find your request here, was looking for the same thing for same project on our end... will let you know if i find anything...
                    • H Offline
                      haynesc
                      BUMP
                      Just wondering if anyone has had any progress with this? ...
                        Look at doing it with a Dynamic Component: you can then set/scale to give the rectangular footprint and height, enter the story height, name, color etc - it'd then calculate the footprint area and GFA automatically for you etc. Each instance is individually editable, or you can edit several together, or report on the selected ones etc at any time...
                          Have you had a look at http://www.modelur.com/ ? Might that be something for you?
                          • H Offline
                            haynesc
                            Hey thanks thomthom looks looks fantastic I will test it thanks !
