    [Plugin] UVprojection
    27 Posts 20 Posters 31.4k Views 20 Watching
    • N Offline
      notareal
      Thanks. More UV tools the better - maybe google get's the message in some point - proper UV tools are really needed for SU.
        @rhplus said:
        Thank You thomthom for your quick reply to my problem. I had checked this new UV toolkit, but I'm affraid that it works only with projected textures.
        I should work with any mapping. Can you post an example of what gives you unexpected results in the UV Toolkit thread?
        • H Offline
          hgdn
          Thanks so much for giving a wonderful plugin, it is so great for terrain work and done so fast! Hope you or any one can figure out of how to have uv texture works on spherical or odd curvy shapes as well!
            indeed. Have a look at this tutorial topic where I used wrapped textures exclusively (then later on, cylindrical projection on a cylinder)
            and sorry Jan for littering your topic.
              RHPLUS
              Thank You Thomas & Csaba, I had check out one more time and now I know that the mesh had to be selected before chosing both commands: Remember & Restore.
              This is wonderful plugin - Thomas - U R Great!!
                RHPLUS
                Now, when maps are fixed on a human model, the next step should be rigging and weightmappng to make modifications easier.
                  Ben Ritter
                  Jan, thank you very much!
                    agamemnus
                    Nice plugin; just one problem -- how do I position the texture once I map it? (or before I map it)
                      Booman
                      Great plugin! I usually do it manually by adding a material to a face, adjust UV coordinates, then inherit the position and apply to the rest of the object.
                      This plugin should speed up my workflow!
                      Thank you
                      Brian McCracken
                      In The Red Website Design
                        castromann
                        thx for this great plug - used it a lot in my projects.
                        one question though - would it be possible to add a feature that lets you specify the angle of projection. not all shapes are easily aligned to the red or green axis all the time. so in my imagination if you could choose any angle between the red and the green axis (+90/-90) or maybe even taking the blue axis rotation into account that would be perfect. i hope you understand what i´m talking about 😳
                          Bertier
                          sweet
                            Gillman
                            Somebody smarter than me probably already figured this out, but I was using this plug-in to add a camo pattern to an aircraft model. I kept messing up the projection from one group to the next until I created a flat plane that was slightly bigger than the whole model, painted that, then pasted it into each element as I was texturing it. Then I ran the UV projection plug in on each element. Because the flat plane was the same dimensions and in the same place for all the disparate groups, it acted as a consistent point of reference for the plug in as long as I kept the same settings. That made the job far easier for me.
                            • 2 / 2
