    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.2k Views 41 Watching
    • K
      kyyu
      If you want to use the profile edge style. I was thinking you could keep the hatch faces and give them a transparent material. That worked. But then I thought, it's even simpler is just to hide them. I was worried that "unhide all" would unhide the faces, but it doesn't seem to effect the grouped faces.
      • jolranJ
        jolran
        Is that duplicate line needed at line# 136 ?
        No ๐Ÿ˜ฎ
        Thank you for spotting that ๐Ÿ‘ Sometimes I get wierd results when I copy from ruby code editor and paste to Notepad ++.
        Did not doublecheck the results well enough.
        Note. It is AS ruby code editor, not Jims version. Is Jims more stable? I think it's a webdialogthingy-bug.
        Thank you for keeping on testing stuff! It's of big help. How about a choice of keeping faces? With possibility to attach
        material? That way one could use transparent material or whatever? Wonder if it is possible to use a dropdownlist getting the materials already added in the palette...
        Anyway, must get this second crosshatching inputbox working correctly first, and do some fancy methoding.
          sergey2402
          Have I understood you correctly?
          • jolranJ
            jolran
            Sergey. Yes that is the behavior of profiles. I can see the problem you are getting at.
            If I put in an option for "keeping face", you will get that behavior WITHOUT manipulating the original selection. Hatched lines and faces in one separate group called "Hatching".
            On top of that,(as TIG recommended), when you want crosshatching. There will be 2 groups in that "Hatching" group.
              If you want 'thin' hatch lines you simply don't erase the faces within the hatching group[s] [i.e. keep the perimeter edges too]... then make a material if it doesn't exist called say 'HatchFaceMat' set it's color rgb=[255,255,255] and it's alpha=0 so it's completely transparent and apply that to all faces in the hatching group. If the Style has edges thin and profiles thick you get thin hatching.
              It could even be a dialog option - Line-Style: 'Thin|Thick' - 'thin' where the faces are kept and made transparent OR 'thick' when the faces are erased...
              • jolranJ
                jolran
                Thoose are exellent ideas! See if I can get this crosshatching work first ๐Ÿ˜„
                Getting some hard time putting structure to the code.
                I have made "line hatches" and "intersection" into 2 different methods. A heck of lot of instance variables..
                I was wondering if it would be easier to let the 1st hatches get done first. Then make the second inputbox pop up?
                Then just call the methods on @gents and do some sort of grouping. This can probably be done in several ways.
                Question is wich method gives best performance, regarding workflow, edge creation etc.
                • jolranJ
                  jolran
                  Hmm I got the second inputbox poping up after line creating. It's quite instant response. So having the 2nd inputbox first
                  or after 1st hatching doesent really matter, "workflow-wise" that is. I wonder if it's a risky way of doing things.
                  Also wondering if I call on for 2nd Hatching, Using the line_making and intersect_method varibles in those are set
                  from earlier = @spacing and @angle. Could one use something like @spacing=20.to_l if not @spacing instead and just call the again in the method for crosshatching. Or would that mess up the default values, next time one run the plugin?
                  Could of course put the whole rest in the crosshatch method, bit doesent feel very clever..
                  • jolranJ
                    jolran
                    Or do the arguments in the definition heading like TIG said ๐Ÿ˜„
                    def hatch(angle,spacing,gents)
                    Hehum.. I'm to new to this.
                    • kenK
                      ken
                      Jolran, just a thought. I see that you now have the hatch assigned to a separate layer. It occurred to me if the hatch patterns were assigned layers by the distance between hatch lines. You would have a layer for small hatch patterns, medium patterns and large patterns. This way if I make a scene or PNG file of a small section of the overall model, I would just have the small hatch patterns turned on. And if I was making a scene or PNG graphic for the larger section of the over all model, I would have the small and medium hatch patterns turned off. This may be over kill and too much additional work.
                      And I can just assign layers to the hatches I make according to my wants.
                      To you Jolran and all who are helping, thanks for the running tutorial in making a plugin. This continued conversation is helpful.
                      Thanks to all, for the plugin and the ruby help.
                      • K
                        kyyu
                        No ๐Ÿ˜ฎ
                        I don't have any problems with copy/paste from Jim's Ruby Web Console (older one, not his newer one).
                        It's up to you about the features, keeping faces, or materials, ..etc. I don't have any preference as, I don't need to hatch stuff.
                        -Kwok
                        • K
                          kyyu
                          Yes, just hide or apply a transparent material to all the many small faces in the hatch group. Very easy to do with ruby.
                          • K
                            kyyu
                            I do it the way TIG is suggesting, passing arguments. I make instance varibles only when I really need to. I'm not saying I know the best way, but here is an example from a recent plugin of mine. Notice I have a @scale instance variable, but also a scale variable that's local to the scale method. What I'm doing in this paticular case is scaling back down. So I use "1/@scale", when calling the method. Also the method can't accicently change the instance variable, it's all local. Just to be clear, I'm not saying make instance variable and pass them to the method. It just happened that's the way I had it in that plugin. I think it was because, I had an initialize method at the begining and I wanted those values available to the main program method. So I made them class and instance variables.
                            def main
                              ...stuff
                              scale(@@ent.to_a, (1/@scale.to_f))
                              ...more stuff
                            def scale(ent, scale)
                              tr = Geom;;Transformation.new(scale)
                              Sketchup.active_model.active_entities.transform_entities(tr,ent)
                            • K
                              kyyu
                              def main
                              >   ...stuff
                              >   ...more stuff
                              > end
                              > end
                              Ok, that was a strange example. How about this one, more applicable to your case.
                              def main
                                @spacing1=20.to_l if not @spacing1
                                @spacing2=20.to_l if not @spacing2
                                  ...some stuff
                                scale(ent, @spacing1)
                                scale(ent, @spacing2)
                                  ...more stuff
                                Jim
                                Careful here. It is because the type of the parameter is a Float that is can not be accidentally changed. If @scale were almost any other type of object, the local variable scale would be a reference to the passed-in object and changing scale could change @scale.
                                It doesn't help to think of Ruby variables a containers for values. Ruby variables are pointers to objects in the computer memory. Here's my attempt at a graphical explanation. It's an over-simplification because different types are treated differently. Floats and Fixnums are not passed by reference, for example. You also need to be aware of the circumstances when a new object is created, or the current object is modified.
                                The local variable a refers to the same String object as s.
                                • K
                                  kyyu
                                  Jim,
                                  Good point. I knew of variables being a reference to an object, but still confusing at times.
                                  • jolranJ
                                    jolran
                                    Hi Ken. Thoose layers thing are very good ideas! They may or may not be hard to do, not sure yet. But IF they get implemented one could have them as an option? I don't think it should be default behavior of the plugin.
                                    I thought I was babbling nonsense ๐Ÿ˜„ But if you like it, I will continue to report and discuss openly.
                                    Kyyu. Many thanks again for your advice ๐Ÿ‘ I think I am at sleep when you guys are active here on the forum.
                                    Different timezones.
                                    I will head for doing as you advice. Using @varibles just when needed. I tried the opposit, but it got messy, and inefficient. Your code looks well structured.
                                    When ordering methods and things right now, I must also think a little bit forward about the next steps.
                                    Added features like other hatch-types, and bugtracking etc. The "face-creating" part must be a method or a block itself(sort of main code), if I am going to use it with other hatch-types. The subroutine for crosshatches might get a little repetitive code, not sure yet. IF I will be able to do other hatch-types, it might be a good idea to split up thoose, AND the line-hatches in different modules. Calling from the main "face-creating" script. Eventually I might do a fast version
                                    of crosshatching so you have something to try.
                                    They say Ruby is an easy language to learn. I haven't got any experience of other languages, so I can't tell.
                                    However there seams to be many ways to do things in Ruby, and that can get confusing for a newbie.
                                    Jim. I like your graphic. Visual guides like that is very helpful.
                                    • jolranJ
                                      jolran
                                      Hi. I trying to figure out the "clever" way to setup the structure of the code. If anyone has any comments, I would be most greatful. Having decision anxiety.
                                      I am little afraid to destroy the structure of current code and getting flamed for doing something inappropriate.
                                      I'm trying to avoid using @varibles everywhere. I get the impression that could give some troubles later on.
                                      The simplest way would of course be to repeat the whole last part(linecreation, intersection) without nesting so many methods, but that would probably be cheating. However the script is not that long so I guess it would not be a catastrophy to repeat things.
                                      Also having trouble grouping. Where as we will have the structure:
                                      (maingroup)/(hatchgroup1) (hatchgroup2)
                                      Questions are. Should "face-cloning" be a separate method?
                                      Should one create a method for only using 1 inputbox getting values twice?(2 promts, 1 box) OVERKILL?
                                      Another possiblities is to recreate the linehatching and intersection in a submethod calling on @gents?
                                        Collect all of your dialog data at the very start.
                                        If the 1st dialog has 'Yes' for 'Crosshatching?' then a second dialog opens with the -ve version of the angle and the same spacing - the user can change these if desired and press OK, or Cancel to skip crosshatching.
                                        After the dialogs you use the data to make the grouped hatching.
                                        If there is no crosshatching then the code is as currently.
                                        If there is crosshatching then you simply run the coder twice.
                                        However, as explained before - you remove the hatch code into a sub-def method where you pass values this
                                        def hatch(angle, spacing, gents)
                                        where 'gents' is ANY entities set that's passed to it [I left it called that because when you move the code into the method the name can remain - however, note how the angle/spacing variables can NO LONGER be @ variables inside the hatch def because they can be different @'s depending on whether you are making a hatch or a crosshatch from dialog input!]
                                        and to use for the non-crosshatched version
                                        self.hatch(@angle, @spacing, gents)
                                        where you pass the @angle/@spacing variables
                                        and 'gents' is entities of the 'group' that contains the hatching.
                                        When you have crosshatching you first make 'group' to contain the TWO groups needed.
                                        Then add two sub-groups
                                        hgroup=gents.add_group() cgroup=gents.add_group()
                                        here 'hgroup' will contain the hatching and 'cgroup' the crosshatching
                                        To make then first make the hatching
                                        self.hatch(@angle, @spacing, hgroup.entities)
                                        note how we have passed a different entities set this time
                                        To make the other part of the crosshatching use
                                        self.hatch(@cangle, @cspacing, cgroup.entities)
                                        Note here we have used different @ variables for the crosshatching - derived from the 2nd dialog AND we use the other entities set too...
                                        By using the sub-def method for 'hatch' you can reuse the code for hatching or crosshatching as the values are remembered separately as @'s for the two types and if there is crosshatching then a simple extra step of making sub-groups inside the main hatch-group is all you need...
                                        • jolranJ
                                          jolran
                                          Thank you TIG! Much appreciated, was a bit stuck.
                                          I think I understand better now what you meant before. Before when you said "code into a sub-def method", I thought you meant ADDING a method or "doubbling" the code. There's where I was lost, should have asked earlier for help but pride got in the way.
                                          Very clever solution! And probably quite natural solution for some off you guys in here ๐Ÿ˜ณ
                                          I will digest this and continue. Thanks again.
                                            sergey2402
                                            Unexpected results of hatching.
                                            All hatches are made with the same distance and with the same angle.
                                            Maybe is necessary to select not only the face, but also the baseline?
                                            (And maybe the baseline can be anywhere in the drawing, not necessary on the face?)
                                            • 17
                                            • 18
                                            • 4 / 18
