    Multiple components on a plane
    3 Posts 2 Posters 191 Views 2 Watching
      stuartcuss
      Hi all,
      Wondering if you guys could help me out, I'm not sure if there's a script or technique I can use to achieve this.
      I have a series of components in the same plane (horizontal) which need to be moved on the blue axis until they touch a surface below.
      Is there a quick way of doing this or do I need to pick up each component, snap to blue axis and drag it down until it hits the plane.
      I've uploaded an image which should illustrate this...
      Thanks,
      Stu
        You think you need 'Drop' http://www.smustard.com/find/
        Simply select the things and 'drop'... they stop at the first surface hit, or z=0
          stuartcuss
          Thanks for the speedy reply TIG, that worked a treat. Saves me a lot of time πŸ˜„
