    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.2k Views 41 Watching
      Do you have a crystal ball or some sixth sense? Will I be able to cut the grass tomorrow or will it rain?
        sergey2402
        The really good thing can not be free. It understandable without a crystal ball and without sixth sense. ๐Ÿ˜‰
        Good question, but a great pity to spend my magical powers to answer it. ๐Ÿ˜Ž
        • jolranJ
          jolran
          Ver 1.3 added!
          Hole "issue" should work. At least it does for me..
          Note. Crosshatching does NOT work yet. Only menu items has been added. Layer Hatching now gets made with hatching in it.
          What say you about choice of keeping Face and being able to add material?
          This version needs to be tested. Have not recieved feedback from TIG about this update, and that makes me nervous ๐Ÿ˜„
          • jolranJ
            jolran
            Kyyu! Thank you so much for your detailed explanation. Now I understand better. Much apreciated.
            I think your intersect method is worth experimenting with for upcoming features. And or what features is possible.
            this plugin will be not freeware
            No one in here needs to worry this will become a comersial plugin.
            Yes, of course I need to make money. But I have gotten so much help from TIG and Kyyu, Jim and others, so going comers. would be HIGHLY unethical! If even legal? This is a great learning experience for me, and I will try too remain humble and listen to
            advice and suggestions being made.
            in the new version of SketchUp this plugin should become a standard feature
            Hatches, yes. So this work might be for nothing ๐Ÿ˜„ Although, it is possible only Layout will be the program that get hatches.
              sergey2402
              Yes! It happened! ๐Ÿ˜
              Even if this is the final version of the plugin - that would be enough. ๐Ÿ‘
              Many thanks you and those who helped you in this difficult and very necessary work.
              But I want to go further in my desires ๐Ÿ˜ณ
              How about this?
                My comments...
                Code like
                jol_icons = Sketchup.find_support_file "Plugins/Hatchfaces/hatchfaces_s.png"etc would be safer as
                jol_icons = File.join(File.dirname(__FILE__)), 'Hatchfaces', 'hatchfaces_s.png')
                because some users don't/can't put their stuff in the main Plugins folder - Sketchup.find_support_file() is best avoided.
                Also how about adding a Plugins [or Tools?] menu item so users can shortcut to it easily...
                Enabling the crosshatch options is relatively straight forward...
                I would have three questions Angle, Spacing, and Crosshatch?
                If the user has said 'Yes' [default='No'] as second dialog opens - the Angle set to the first set angle*-1 and the same Spacing - OK to do crosshatching or Cancel to not do crosshatching...
                To process the hatching I'd move that part of the code out to a sub-method that takes several arguments - e.g. def hatch(angle,spacing,gents)
                Then if there's no crosshatching you call if once passing the three values so it knows what to make and where to put stuff [gents]... If there is crosshatching it makes the hatch-group and then a group inside that, it runs the hatch sub-method in that sub-group entities... and then adds another sub-group for the crosshatching and runs the hatch sub-method with the new values in the second sub-group entities. This way the two hatches are grouped as one, but in each their own sub-group, so one of them could be erased later if a user desired it...
                • jolranJ
                  jolran
                  It is not the final version ๐Ÿ˜„ There are things to fix. But I'm happy if the plugin is working for you, keep testing.
                  How about this?
                  That can easy be made manualy in Sketchup if you use r.click intersect with selected(face and hatchgroup) so the hatched lines adds to the face. Then go into styles-> edit->profiles, and work with the setting there.
                  If you want border "thin" faces to be drawn, that's a different issue. This feature in code might not be that easy. I can have a look on that later. First I will try to get the crosshatching working.
                  One have to consider what feature to add or not. If that feature is 1 click in Sketchup, it might not be worth adding it to the code.
                    sergey2402
                    Yes. It can be done. But in this case I am losing one large face, and in return get a lot of small faces. Seems to me it is not very well.
                    • jolranJ
                      jolran
                      Ok I see what you mean. I will take a look at that later on. My 1st thought is that it will not be that easy to do.
                      In native Sketchup just use offset, doing that in code is not that straightforward, from what I know.
                      Crosshatching is on the next TODO list, and TIG's recommendations for filepaths.
                      Could spend some time on those...
                      • jolranJ
                        jolran
                        Did not think of that ๐Ÿ˜ณ good point.
                        Yes, yes. That should have been done earlier.
                        That's smart. I wasn't planning on doing it like that. But of course your way is more logical.
                        The code will need some work for this to happened. And I will try your method, if I can understand how to.
                        Thank you TIG I will work on you advice. ๐Ÿ˜„
                        PS: If it looks like I make promises for new features to be added and expect TIG to come to the rescue, it's not like that.
                        I understand you have other business to attend to, and I'm greatful for all the help I get.
                        Thanks โ—
                        • K
                          kyyu
                          Is that duplicate line needed at line# 136 ?
                          • K
                            kyyu
                            If you want to use the profile edge style. I was thinking you could keep the hatch faces and give them a transparent material. That worked. But then I thought, it's even simpler is just to hide them. I was worried that "unhide all" would unhide the faces, but it doesn't seem to effect the grouped faces.
                            • jolranJ
                              jolran
                              No ๐Ÿ˜ฎ
                              Thank you for spotting that ๐Ÿ‘ Sometimes I get wierd results when I copy from ruby code editor and paste to Notepad ++.
                              Did not doublecheck the results well enough.
                              Note. It is AS ruby code editor, not Jims version. Is Jims more stable? I think it's a webdialogthingy-bug.
                              Thank you for keeping on testing stuff! It's of big help. How about a choice of keeping faces? With possibility to attach
                              material? That way one could use transparent material or whatever? Wonder if it is possible to use a dropdownlist getting the materials already added in the palette...
                              Anyway, must get this second crosshatching inputbox working correctly first, and do some fancy methoding.
                                sergey2402
                                Have I understood you correctly?
                                • jolranJ
                                  jolran
                                  Sergey. Yes that is the behavior of profiles. I can see the problem you are getting at.
                                  If I put in an option for "keeping face", you will get that behavior WITHOUT manipulating the original selection. Hatched lines and faces in one separate group called "Hatching".
                                  On top of that,(as TIG recommended), when you want crosshatching. There will be 2 groups in that "Hatching" group.
                                    If you want 'thin' hatch lines you simply don't erase the faces within the hatching group[s] [i.e. keep the perimeter edges too]... then make a material if it doesn't exist called say 'HatchFaceMat' set it's color rgb=[255,255,255] and it's alpha=0 so it's completely transparent and apply that to all faces in the hatching group. If the Style has edges thin and profiles thick you get thin hatching.
                                    It could even be a dialog option - Line-Style: 'Thin|Thick' - 'thin' where the faces are kept and made transparent OR 'thick' when the faces are erased...
                                    • jolranJ
                                      jolran
                                      Thoose are exellent ideas! See if I can get this crosshatching work first ๐Ÿ˜„
                                      Getting some hard time putting structure to the code.
                                      I have made "line hatches" and "intersection" into 2 different methods. A heck of lot of instance variables..
                                      I was wondering if it would be easier to let the 1st hatches get done first. Then make the second inputbox pop up?
                                      Then just call the methods on @gents and do some sort of grouping. This can probably be done in several ways.
                                      Question is wich method gives best performance, regarding workflow, edge creation etc.
                                      • jolranJ
                                        jolran
                                        Hmm I got the second inputbox poping up after line creating. It's quite instant response. So having the 2nd inputbox first
                                        or after 1st hatching doesent really matter, "workflow-wise" that is. I wonder if it's a risky way of doing things.
                                        Also wondering if I call on for 2nd Hatching, Using the line_making and intersect_method varibles in those are set
                                        from earlier = @spacing and @angle. Could one use something like @spacing=20.to_l if not @spacing instead and just call the again in the method for crosshatching. Or would that mess up the default values, next time one run the plugin?
                                        Could of course put the whole rest in the crosshatch method, bit doesent feel very clever..
                                        • jolranJ
                                          jolran
                                          Or do the arguments in the definition heading like TIG said ๐Ÿ˜„
                                          Hehum.. I'm to new to this.
                                          • kenK
                                            ken
                                            Jolran, just a thought. I see that you now have the hatch assigned to a separate layer. It occurred to me if the hatch patterns were assigned layers by the distance between hatch lines. You would have a layer for small hatch patterns, medium patterns and large patterns. This way if I make a scene or PNG file of a small section of the overall model, I would just have the small hatch patterns turned on. And if I was making a scene or PNG graphic for the larger section of the over all model, I would have the small and medium hatch patterns turned off. This may be over kill and too much additional work.
                                            And I can just assign layers to the hatches I make according to my wants.
                                            To you Jolran and all who are helping, thanks for the running tutorial in making a plugin. This continued conversation is helpful.
                                            Thanks to all, for the plugin and the ruby help.
                                            • 17
                                            • 18
                                            • 4 / 18
