    [Plugin] Title block from title v1.2 (20110713)
    27 Posts 9 Posters 27.8k Views 9 Watching
    • mitcorbM Offline
      mitcorb
      So, then, whatever one has named the file is then placed in the database, but you must use # as part of the title, and in the order of the fields. The @ sign tells the cartouche generator to look at the title for the appropriate value?
        Matt666
        Absolutely.
        '#' sign is just the separator of all informations in the drawing title. If you want to use another sign, change title AND whange separator in the cartouche settings.
        @ = just look at the title. Just one thing: You can't put ONLY 3rd title information in the cartouche. First and second title information must be in the cartouche. I will try to improve this plugin soon.
        Just a little improvment : If you put '@@' sign in the value field, information will be capitalized. Otherwise, it keeps title case.
        Frenglish at its best !
        My scripts
        • EarthMoverE Offline
          EarthMover
          Great idea Matt. Thank you for sharing! 👍
          Content Creator at Skapeup
            Matt666
            Thank you Adam!
            My scripts
            • srxS Offline
              srx
              Interesting...thank you. Maybe this plugin will put the order in my su files 😄
              www.saurus.rs
                Matt666
                Hi srx, hope this little script will help you...
                My scripts
                  Matt666
                  A small bug-fix.
                  My scripts
                    Matt666
                    New version soon available (tomorrow). 2 new variables : %DIR (to add directory of the drawing in cartouche) and %PAGE (an interesting variable that add name of the current scene in the cartouche. And every change of page will also modify cartouche).
                    A help file is here now. I modified call system of case change (no @@, but < or >). And now you can change order of title information.
                    My scripts
                      EarthMover
                      Matt, would it be possible to tie this into the Scene Tabs to change page numbers and label each view according to the named scene tabs? (i.e. Front Elevation, Rear Perspective, etc.)
                      • EdsonE Offline
                        Edson
                        sorry, but I cannot find the link to download this plugin! 😕
                        http://www.mahfuz.arq.br
                          Matt666
                          That's normal, Edson. I work on some improvments, and I will upload it soon.
                          My scripts
                          • EdsonE Offline
                            Edson
                            thanks, matt, I thought I had a problem. 😉
                            • U Offline
                              unclex
                              thanx for ur nice plugins
                              but Download from Where???
                                Unclex, Matt indicated he was working on improvements. He must have removed the link temporarily.
                                  Matt666
                                  Ok, you can download plugin at the end of the first post.
                                  Enjoy!
                                  My scripts
                                  • U Offline
                                    unclex
                                    Got it
                                    Thanx Dave & Matt
                                      Matt666
                                      Do not hesitate do give your opinion! 😄
                                      My scripts
                                        Torontoww
                                        This is a wonderful plugin, but I find that changing the X and Y values do nothing to change the position of the text on the screen or on a print out. I've tried 0, .5, 1 and even higher numbers(even though 0 to 1 seems to be the range) but nothing changes. Also, what was or is 0 and 1 supposed to signify? X=0 left side of page, X=1 right side of page? I would like to place the text on the lower left of the screen underneath a title box I have placed using the watermark feature.
                                        Lastly, when I click 'record existing cartouche' a box keep pops up telling me to 'please select a cartouche before you use this plugin'. How do you do that? I thought that that is what I was doing by clicking 'settings' and then 'add'. What am I doing wrong?
                                        Now, my wish list:
                                        1. A %TIME variable. I often print multiple printouts of the same drawing in a day and forget which was the last I printed.
                                        2. The box that pops up when you click on settings is so high that I can barely click the OK button as it is almost scrolled off the bottom of my screen. Could the box maybe be resized more square, ie 2 columns, so that it fits better within the screen boundaries?
                                        3. Ability to put text anywhere on the page with the X and Y feature (which doesn't seem to work for me).
                                        4. Ability to leave a blank line or have double spaced lines rather than single spaced.
                                        Thanks for a great plugin.
                                          Matt666
                                          Hi Torontoww, and thank you for your answer.
                                          Strange, X & Y values don't change anything. Did you put "0.4", "0,4", ".4" or ",4"? Can you open ruby console, run plugin and show me the result please?
                                          To use plugin "record existing cartouche", you have to click on an existing cartouche in the drawing (a text generated by cartouche plugin), and it will change this text if you want to update cartouche. In theory you don't have to use it, main plugin should find existing cartouche in the current drawing if exists.
                                          1. Ok for %TIME.
                                          2. I currently work on a HTML version of the box which will be resizable. But I don't have any time... Be patient please.. 😳
                                          3. See behind
                                          4. Ok, I will try to do something.
                                          My scripts
                                          • brookefoxB Offline
                                            brookefox
                                            Matt, Thanks very much for this and for the detailed instructions and explanations at the top. Very helpful.
                                            I wish folks would post example pics of how they are using this.
                                            ~ Brooke
