    Get rotation(transformation)
    31 Posts 3 Posters 1.9k Views 3 Watching
    • jolranJ Offline
      jolran
      You are so helpful. I can almost not believe it..
      Thank you TIG!
      I will continue with my script since I understand easier where variables are pointing to.
      See where I have gone wrong in some areas and use your script as a guidence.
      Thanks a million!
        kyyu
        @jolran said:
        I'm getting it to work almost.
        vector.length=20.0
        The copied distance will always be desired length on the vectors line, but depending on the angle of diagonal the edges will not be same distance apart. So I guess I will have to do another compensation? Or is there some Quick fix like the last one(thank you TIG)
        I'm guessing will have to do a comparison between Diagonal, user(desired angle, here 45 deg) and somehow
        compensate the copy distance for that. Boy this is hard..
        Here is a example of finding the normal vector of a grouped line, using a cross product. The cross product of two vectors prduces a third vector, at right angles to the original ones.
        model = Sketchup.active_model
        ent = model.entities
        sel = model.selection
        line = ent.add_line [3,3,0], [5,5,0]
        group = ent.add_group line
        v1 = line.vertices[0].position.transform(group.transformation)
        v2 = line.vertices[1].position.transform(group.transformation)
        v = v1.vector_to v2
        # I used z vector as 2nd vector, but can try "face.normal" for general case
        normal_vec = v.cross([0,0,1])  #cross product to get normal vector
        pt = [0,0,0]
        demo = ent.add_line  pt, pt.offset(normal_vec)  #drew demo line representing normal vector
        demo.material = 'red'
        n = normal_vec
        n.length = 1
        g1 = group.copy
        g1.transform! n  # moved copied group using normal vector
        • jolranJ Offline
          jolran
          Hi Kyyu!
          Interresting. So you mean I use the 3rd vector for measuring? Or was it meant to be
          a method to get an angle 45 deg of the vector?
          Remember 45 deg is just an example for this particular hatching. The user must be able to
          choose any angle for the lines across the face.
          I will look into it more and see if I understand you code a little better.
          Thank you Kyyu.
            kyyu
            @jolran said:
            Hi Kyyu!
            Thank you Kyyu.
            The 3rd vector would be your translation vector. In your code you have it as:
            vector=diag_vect
            vector.length= user_length
            It's perpendicular to what ever your final line is. Here, I just changed the line to a random new angle, not 45 deg. I set the length of the vector (distance of translation) to 1.
            I found this picture that explains cross product pretty well.
            • jolranJ Offline
              jolran
              Translation vector? The translation must be on the diagonal or the lines wont cover the whole face.
              I already have the rotation of lines, copy/translation set up. Except that the "bug" is that
              the translation distance doesent get 100% accurate if the face is very distorted.
              Maybe that is what you are trying to fix, and I don't see it.
              If thats the case sorry 😳 I'm a noob, you know.
              The angles of lines on the picture are the identical. Although they don't appear to be.
              • jolranJ Offline
                jolran
                Hate to bother again, but I've been going on all day and intersect_with is troublesome. 😞
                Tried TIG's combo, and others but I think I'm making a fundamentional fault.
                Doesent intersect_with work with nested groups?
                tr3=Geom::Transformation.new()
                face_group.entities.intersect_with(recursion,tr3,face_group,tr3,true,[hatch_lines_group])
                  If you read through the way I did it... I make a hatching group then simply add a face and overly long hatching lines to it, intersect everything with each other, erase the faceless edges outside of the face perimeter and then erase the faces too. I never use subgroups - if you want to then just explode them...
                  You are better off transforming points/vectors and drawing the edges that grouping things endlessly/needlessly it'll be slooooow πŸ˜‰
                  • jolranJ Offline
                    jolran
                    Aha! Did not quite understand what was going on.
                    Yes, yes I will TRY to do the same. That way I will learn the right way. Slow doesent sound good πŸ˜„
                    My resulted line_groups apears pretty fast on screen for the moment though, and its possible to make
                    a manual intersect with selected. But a lot cooler if it is manual.
                      kyyu
                      @jolran said:
                      ...Except that the "bug" is that the translation distance doesent get 100% accurate if the face is very distorted.
                      Yes, that is what I am showing how to fix.
                        Where my script does a transformation.rotation on things simply using 45.degrees so it your user inputs an angle in a dialog as a 'float' - e.g. 12.5 use - angle=results[0] and spacing=results[1] (or whatever your dialog returns) and then in the transformation.rotation use angle.degrees instead...
                        • jolranJ Offline
                          jolran
                          Great!! Will try that. But? That correction will just be a fix for the dialoginput, no?
                          I havent gotten that far yet 😳
                          Or maybe you mean your advice WILL fix missing geometry in the corners in certain angles)? Cause thats what bugging me, atm. I was only using Int's changing the angles and spacing.
                          Maybe that face.normal rotation of yours doesent work in all angles? Unless som serious fix?
                          Then using grouped edges might be more suitable, what do you think?
                          I'm not questioning anything, just don't know wich way to go.
                          Thank you TIG.
                          • jolranJ Offline
                            jolran
                            BTW. The splats in my script was probably coming from the outliner open.
                            So Hmm. The direction I'm taking now is using edge_group_copying(my original idea). I cannot modify TIG's version due to lack of understanding. Not sure it will work like it is. But I'm a screwbie with bad solutions, so TIG can probably just wack in something just like that to prove I'm wrong πŸ˜›
                            But I will try to use the face normal to align my copies like in TIG's script, just to
                            have something to work on.
                            And use Kyuu's example for getting better accuracy with the distance between copies.
                            Methods for each view/axis would prob. make the script unnecessary long.
                            ABout adding groups. Sketchup doesent like it when your inside a group in model mode-
                            select a face- then by code add a group?
                            No suggestions I suppose? 😐
                            • jolranJ Offline
                              jolran
                              Ok! Thats very nice Kyyu!
                              Will rework your advice. It looks like a smart solution. But I'm pretty confused right now...
                              I managed to get the intersect_with working in "my" code. It hatches as it should do in the X,Z-axis, although with the distance-error, your trying to correct. However selecting a face inside a group in Sketchup and running the script gives a constant bugsplat. So I don't know if I should go forward an do the other views yet. Does not feel solid.
                              I'm also worried going against TIG's advice with using groups hey-wild, but I can't implement his code into mine. It's to complicated to understand for me and can't get it to run properly.
                              IF I can get the problem with creating hatches inside Sketchup model.groupes, and the distance between lines can be fixed, I think the performance would be OK with my version. But maybe the problem cannot be fixed other
                              than rewriting everything as TIG says..
                              I'm not lazy, just dumb..
                              • jolranJ Offline
                                jolran
                                Ok, take2. A little bit forward. Baby steps.
                                So I've been going trough TIG's script 2 days now and I think I understand it better.
                                It's of course much more sofisticated an more effective than my intentional idea,
                                not surprisingly πŸ˜„
                                vp.length=di*2
                                      tot=0
                                      until tot>=di*3 # fixes -45 deg. corner issue
                                Made an adjustment to line 27 di*3(was di). It's an until.statement, where it keep copying the edges on an offset until the "offset-amount" has reached the length of the diagonal?
                                (Hope I got that right..) So by multiplying the di by 3 it will get those extra edges
                                needed to cover the corners with steep angles. Extra calculation YES! But needed.
                                Have not fixed issues of spacing. The spacing is OK when kept around 45 degrees.
                                But gets narrower when the degrees amount goes "away" from the original amount.
                                MOST cases doing hatches one uses 45 degrees anyway. -45 and 45 degrees.
                                So I will go ahead and try too make the ver1. UI now.
                                • jolranJ Offline
                                  jolran
                                  vector.length=20.0
                                  mod = Sketchup.active_model # Open model
                                  ent = mod.entities # All entities in model
                                  sel = mod.selection # Current selection
                                  =begin
                                  TODO
                                  Wrap in module.
                                  Get proper names. Shorter strings.
                                  def methods for different Axis. Name them as SU views.
                                  After Inputbox call appropriate method.
                                  Use instance or global variables, necessary?
                                  INPUTBOX promt; Hatch line degrees, distance between edges.
                                  Extras; Background color, keep background?
                                  Intersect with method.
                                  =end
                                  face_group = ent.add_group(sel)
                                  Sketchup.active_model.selection.add( face_group )
                                  bbox = face_group.bounds
                                  bpt1 = bbox.corner(0)
                                  bpt2 = bbox.corner(1)
                                  bpt3 = bbox.corner(2)
                                  bpt4 = bbox.corner(3)
                                  bpt5 = bbox.corner(4)
                                  bpt6 = bbox.corner(5)
                                  bpt7 = bbox.corner(6)
                                  bpt8 = bbox.corner(7)
                                  pt1 =bpt1
                                  pt2 =bpt2
                                  pt3 =bpt3
                                  pt4 =bpt4
                                  pt5 =bpt5
                                  pt6 =bpt6
                                  pt7 =bpt7
                                  pt8 =bpt8
                                  # get center, diagonal vector directions from bbox
                                  # mesure angle between x and diagonal
                                  x_cen = bbox.center
                                  x_diag = bbox.diagonal
                                  x_vect = pt1.vector_to pt4   # horisontal X-axis line
                                  diag_vect = pt1.vector_to pt6  # vector across
                                  x_ang = x_vect.angle_between(diag_vect).radians
                                  user_input = 45   # Will get shorter alias
                                  user_length = 20.cm # Will get shorter alias substitute for cm? Must work in inches.
                                  h_group =ent.add_group()
                                  line_group=ent.add_group() ###==new empty groups
                                  line_group.entities.add_line(pt1, pt6)
                                  # rotate and reset parallel to X
                                  tr1 = Geom;;Transformation.rotation x_cen, [0,1,0],(x_ang).degrees
                                  tr2 = Geom;;Transformation.rotation x_cen, [0,1,0],(user_input).degrees
                                  ent.transform_entities tr1, (line_group)
                                  ent.transform_entities tr2, (line_group)
                                  cop_dist = x_diag/2   #copy distance/2 copies from center to top corner
                                  cop_times = cop_dist/user_length
                                  vector=diag_vect
                                  gp=line_group
                                  groups=[gp]
                                  cop_times.to_i.times{|i|
                                  tgp=gp.copy
                                  tgp.transform!(Geom;;Transformation.translation(vector))
                                  gp=tgp
                                  groups << gp
                                  #my_transformed_vector.length=20.0
                                  • jolranJ Offline
                                    jolran
                                    I finally got TIG's version going(forgot to comment out #def.self when running it in R.code.editor, amanidiot!)
                                    SOme funky thing going on when changing hatch_angle. But its stable and works in any axis.
                                    Not what can be said about "my" script. A bit unstable, until the intersectionpart.
                                    My intuition tells me doing copying edges within groups + intersection gives more predictable hatch_result when rotating hatches. But is alot more unstable when gathering and erasing?
                                    Plan A: Stop whining and get the work done so Layout-users finally have a hatch-plugin πŸ˜„
                                    Plan B: Adjust TIG's script so it works in all angles, with menus and such.
                                    (will be difficult, since I don't totally understand it yet)
                                    PlanC: Continue to work on mine(a bit egoistic but I won't learn from copy/paste), integration as much of TIG's script as I can, thus make my script more stable if possible.
                                    However. That might not be possible, and I would have to do at least 5 different methods for views.
                                    I guess I'm asking if there is any pointers for things to avoid that make this script crash.
                                    • 2 / 2
