    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.1k Views 172 Watching
      driven
      @rombout said:
      I also think it doesnt have something to do with safari i use firefox as a standard and a have edited it so that all files will be opened through FF
      SU uses 'Safari' webkit, so anything in a WebDiaolog needs to work on Safari,
      for example if you remove your Safari Flash Plugin, Googles Photo Match won't work inside SU.
      knowing which Safari version SU has use of can make debugging a bit easier.
      cheers
      • romboutR
        rombout
        oke here you go
          As the basis of its webdialogs the Sketchup API uses 'IE' on a PC and on a MAC it uses 'Safari' ...
          Recent changes to Safari have made it less forgiving than it used to be, IE may well follow suit in its own time.
          Now it does things 'by the book' it can break methods which worked on earlier versions, or still work on PC - this happened to some of my code, where I was setting an 'innerHTML' value as an attribute rather than a property - it was working fine on all PCs and MACs for well over a year, then it was suddenly broken on a few MACs...
          We [TBD to be precise] finally tracked it down to the initial 'error' in my coding which had actually always worked until Safari got updated and became super-strict - insisting I code things properly [cheek! πŸ˜‰ ]
            matidami14
            it doesn't work.
            i dont know wat u do with the plugin but a nob, following this steps gets the results thet i get.
            may be u have a ivy version better or u change something on the file.
            i have SU 8 pro and IVY 1.6.3
            • EscapeArtistE
              EscapeArtist
              I thought I posted this in this thread, but it seems to have disappeared. (?!) Anyway, used SUIvy and flipped it upside down, replaced some leaves with flowers and it makes a hanging flower for a window box. If I have time I'll see if I can improve it, but I'm still trying to get the growth right.
              • P
                pancho179
                Nice Plugin Pierreden!
                I see great potential in it, however I can't get it to work. 😐
                I see the red outlines perfectly, but when I shift+click in order to "render" the ivy it only constructs the first branch in lines, no faces, no more branches, no leaves, nothing at all.
                I donΒ΄t know if anyone has had this problem, I skimed through the 250 posts on this thread and didn't see anything similar.
                Hope someone can help.
                  Open the Ruby Console and try again. See if it reports anything.
                  • V
                    vidy
                    dear pancho,
                    have you already check on page 17, some issued are solved in that page.. πŸ‘
                    regards,
                    still so much to learn..
                      scrappy24
                      Thank you Pierreden, this is very nice! Looking forward for a new Release with new features.
                      With Vray
                      • romboutR
                        rombout
                        NICE... great result you have there
                        • tibetT
                          tibet
                          hi ,
                          a very nice plugin,thank you!
                          do you know how to reset setting please ?
                          thanks!
                          SU 2015 Pro on Win10 x64
                          • bac9-flclB
                            bac9-flcl
                            First of all, awesome work there! Really nice plugin, easy and fun to use.
                            http://img.gameru.net/th/3e95e.jpg
                            http://img.gameru.net/th/9e47e.jpg
                            http://img.gameru.net/th/df80e.jpg
                            http://img.gameru.net/th/91379.jpg
                            http://img.gameru.net/th/72aa6.jpg
                            However I've wanted to ask: is it possible to improve leafs placement anyhow?
                            At the moment they only look relatively good on ivy grown at a vertical surface because the foliage are always facing downwards. And the problem is not that the default direction is downwards, I can edit leaf components to alter it.
                            http://img.gameru.net/th/b8c3e.jpg
                            As you can see here, the problem is that growing direction isn't taken into account, so even when ivy is growing over the horizontal surface, leafs are still placed downwards, right into the surface. Still, I see that leaf components aren't facing to the same horizontal angle, and that means that you have some kind of direction check taken into account for leaf placement - just not for the vertical angle.
                            So, the question is: can you implement vertical direction dependence in addition to existing horizontal one, so that foliage will be placed correctly relatively to branch direction and base surface orientation (floors, ceilings and other cases)?
                            Also I don't recall any problems in ivy models made with original generator you've mentioned in the first post, so maybe it's possible to use already written advanced foliage placement code from it.
                            Upd: Oh wait, why scrappy24 render features perfectly proper foliage orientation on the floor? πŸ˜„
                            • O
                              Onslaught
                              Awesome plugin. One thing though is that I can't adjust any of the Parameters, any idea what the problem is?
                              http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                              ILLUSTRATIONS
                              • EarthMoverE
                                EarthMover
                                Have any of you checked out the Ivy texture pack that is on the Lutz Ivy generator page? - http://graphics.uni-konstanz.de/~luft/ivy_generator/ There are some great Ivy textures there with bump and spec maps, even a few premade maxwell ivy textures that could be used to replace the ones that come with Sketchup Ivy.
                                Content Creator at Skapeup
                                • kaluK
                                  kalu
                                  Hi to all:
                                  I try the IVY plugin is awesome what I see but I don't understand what are the steps to make it grow. Can someone place here the shortcut keys to make it work and grow and show leaves and menu for some reason I cant see the menu I have sketchup pro 8 and Windows 7 64.
                                  Thanks.
                                  THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                  • L
                                    lapx
                                    Hello all,
                                    Installed yesterday and was working now i cant get leaves to grow with final shift click 😒
                                    • V
                                      vidy
                                      @kalu said:
                                      Hi to all:
                                      Thanks.
                                      try this kalu:
                                      ALT-Click : Make the ivy grow towards the mouse position (Mac: Cmd)
                                      Mouse-Click : Grow Ivy stem
                                      CTRL-Click : Grow Ivy leafs (Mac: Alt)
                                      SHIFT-Click : Finish Ivy
                                      Keyboard 'i' : Start over
                                      • V
                                        vidy
                                        @lapx said:
                                        Hello all,
                                        maybe you can check on page 17 for this issue..
                                        regards,
                                        • L
                                          lapx
                                          Vidy , yes! Thank you! Change the default values of the Spread from "0" to "1" and it works like a charm.
                                          • L
                                            lapx
                                            Spoke to soon. Was working fine. Now it's back to its old bad behavoir 😞 Shift click to make leafs is where I end up with a problem. It appears to make several duplicate copies of just 1 ivy branch and thats it. Leaves are not drawn. What can be going wrong? Using SU 804811.
                                            Thanks,
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 36
                                            • 37
                                            • 15 / 37
