    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.0k Views 172 Watching
    • bac9-flclB Offline
      bac9-flcl
      First of all, awesome work there! Really nice plugin, easy and fun to use.
      http://img.gameru.net/th/3e95e.jpg
      http://img.gameru.net/th/9e47e.jpg
      http://img.gameru.net/th/df80e.jpg
      http://img.gameru.net/th/91379.jpg
      http://img.gameru.net/th/72aa6.jpg
      However I've wanted to ask: is it possible to improve leafs placement anyhow?
      At the moment they only look relatively good on ivy grown at a vertical surface because the foliage are always facing downwards. And the problem is not that the default direction is downwards, I can edit leaf components to alter it.
      http://img.gameru.net/th/b8c3e.jpg
      As you can see here, the problem is that growing direction isn't taken into account, so even when ivy is growing over the horizontal surface, leafs are still placed downwards, right into the surface. Still, I see that leaf components aren't facing to the same horizontal angle, and that means that you have some kind of direction check taken into account for leaf placement - just not for the vertical angle.
      So, the question is: can you implement vertical direction dependence in addition to existing horizontal one, so that foliage will be placed correctly relatively to branch direction and base surface orientation (floors, ceilings and other cases)?
      Also I don't recall any problems in ivy models made with original generator you've mentioned in the first post, so maybe it's possible to use already written advanced foliage placement code from it.
      Upd: Oh wait, why scrappy24 render features perfectly proper foliage orientation on the floor? 😄
      • O Offline
        Onslaught
        Awesome plugin. One thing though is that I can't adjust any of the Parameters, any idea what the problem is?
        http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
        ILLUSTRATIONS
        • EarthMoverE Offline
          EarthMover
          Have any of you checked out the Ivy texture pack that is on the Lutz Ivy generator page? - http://graphics.uni-konstanz.de/~luft/ivy_generator/ There are some great Ivy textures there with bump and spec maps, even a few premade maxwell ivy textures that could be used to replace the ones that come with Sketchup Ivy.
          Content Creator at Skapeup
          • kaluK Offline
            kalu
            Hi to all:
            I try the IVY plugin is awesome what I see but I don't understand what are the steps to make it grow. Can someone place here the shortcut keys to make it work and grow and show leaves and menu for some reason I cant see the menu I have sketchup pro 8 and Windows 7 64.
            Thanks.
            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
              lapx
              Hello all,
              Installed yesterday and was working now i cant get leaves to grow with final shift click 😢
              • V Offline
                vidy
                @kalu said:
                Hi to all:
                Thanks.
                try this kalu:
                ALT-Click : Make the ivy grow towards the mouse position (Mac: Cmd)
                Mouse-Click : Grow Ivy stem
                CTRL-Click : Grow Ivy leafs (Mac: Alt)
                SHIFT-Click : Finish Ivy
                Keyboard 'i' : Start over
                still so much to learn..
                • V Offline
                  vidy
                  @lapx said:
                  Hello all,
                  maybe you can check on page 17 for this issue..
                  regards,
                    lapx
                    Vidy , yes! Thank you! Change the default values of the Spread from "0" to "1" and it works like a charm.
                      lapx
                      Spoke to soon. Was working fine. Now it's back to its old bad behavoir 😞 Shift click to make leafs is where I end up with a problem. It appears to make several duplicate copies of just 1 ivy branch and thats it. Leaves are not drawn. What can be going wrong? Using SU 804811.
                      Thanks,
                        gianpier1
                        HI Boys.
                        I have a problem. I can´t never see the leafs!!!!!
                        Help me please! 🎉
                          gianpier1
                          Hello guys again!!!
                          I can not see how the leaves are drawn? 😲 😲
                          I don´t understand it!!!
                          • romboutR Offline
                            rombout
                            @gianpier1 said:
                            Hello guys again!!!
                            all depends on which version of SU you use...
                            try searching this forum post for updates and working version! for me a custom revised version 6.05 something does the job... try to look for it!
                              gianpier1
                              i´m using ivy 0.6.3 to SU 8.0. but i didn´t find ivy 0.6.5. Neve i can´t see the leafs man
                              not understand because the leaves do not work when I press SHIFT, the vines are also up.
                              Thanks man
                                lapx
                                For me its sometime works and sometimes not. Cant put my finger on it. Mostly stops working when using shift click. If it means anything, I can see the google and standard tool bar ghosting when I hit shift click 😕 using ivy 0.6.3
                                  lapx
                                  Any developement? This is such a wonderful program to let go. Does anyone have it working consistently in sketchup 8?
                                  Shift click seams to be the problem. Its not making the leaves.
                                    lapx
                                    Anyone else have consistent success with the plugin? Might it be in conflict with other scripts?
                                    Would love to use it on this current project...
                                    http://forums.sketchucation.com/viewtopic.php?f=333&t=38590
                                    • V Offline
                                      vidy
                                      still working at mine, i know i dont make it so dense.. but still work... 😉
                                      here is the screen shot
                                        penniner
                                        cool !
                                          lapx
                                          Its working now. If I can just find out why its not working in some cases. The only thing done differently that I can think of is shutting down the computer and reactitvating sketchup_ivy.
                                          • N Offline
                                            niks
                                            hi.. i've used both Ivy version 0.6 and .5, its working if im on a new scene but once i usethe plugin on my saved sketchup model it does not work. im using sketchup v.8 pro,windows....here's the result of the plugin when i apply it to my saved file. when i shift-click, it only add a single black vine line.. i also tried different suggestion posted on this thread but no luck.
                                            • 36
                                            • 37
                                            • 5 / 37
