    Any randomizing plugin which can do this?
    9 Posts 5 Posters 850 Views 5 Watching
    • dereiD Offline
      derei
      I need to make a large board looking like in attached image, but to make each plank on random size by hand is a really nasty work.
      Is there any plugin or method to randomly scale the elements between two (max and min) sizes?
      thanks.
      DESIGNER AND ARTIST DEREI.UK
      • dereiD Offline
        derei
        I tried to use Random Push-Pull plugin, but it did not worked as expected: http://forums.sketchucation.com/viewtopic.php?f=180&t=15824&p=340440#p340440
        • Chris FullmerC Offline
          I've got one you could try,
          404 Not Found
          (forums.sketchucation.com)
          • dereiD Offline
            derei
            404 Not Found
            Your plugin would be awesome if I could choose to scale about one axis. As I could see in the presentation movie, it scales the same on x,y,z.
            See Pixero's suggestion http://forums.sketchucation.com/viewtopic.php?f=323&t=17507&hilit=plugin&start=30#p155067
            • sdmitchS Offline
              sdmitch
              dereeei, Are the "boards" existing groups, components or what? Or is the plugin suppose to create them? If so then
              def random_boards
              	@Mod=Sketchup.active_model
              	@Ent=@Mod.entities
              	@Sel=@Mod.selection
              	ans=UI.inputbox(["Board Width;","Minimum Length;","Maximum Length;"],[6.inch,5.feet,10.feet],"Random boards")
              	if !ans
              		@Mod.select_tool nil
              		return
              	else
              		wid,min,max=ans; avg=(min+max)/2.0; last=0.feet
              		puts "min=#{min}, max=#{max}, avg=#{avg}" if $sdm_debug
              		xa=[1,0,0];ya=[0,1,0];za=[0,0,1]
              		@Mod.start_operation "random boards"
              		for i in 1..11
              			begin
              				len = (rand * 2.0 * avg).feet
              			end until (len >= min && len <= max && (len-last).abs > 1.0.feet)
              			puts "len=#{len}" if $sdm_debug
              			x=i*wid;dx=wid/2.0;dy=len/2.0;last=len
              			ctr=Geom;;Point3d.new(x,0,0)
              			pt1=ctr.offset(ya,-dy).offset(xa,-dx)
              			pt2=ctr.offset(ya,dy).offset(xa,-dx)
              			pt3=ctr.offset(ya,dy).offset(xa,dx)
              			pt4=ctr.offset(ya,-dy).offset(xa,dx)
              			face=@Ent.add_face(pt1,pt2,pt3,pt4)
              			face.back_material=face.material="[Wood_ Floor]";
              			face.pushpull -0.5.inch
              		@Mod.commit_operation
              http://sdmitch.blogspot.com/
                the random Push pull gives the result : just take one positive value and one negative value πŸ˜‰
                You can also use the Random Replacement COmponents by Sdmitch πŸ˜‰
                Draw a decreasive line of components by any method (with the Grow plugin by TiG for example) as Source
                Then draw a line of the number needing of a same component as Target
                Then launch Random replacement
                et voilΓ  πŸ˜‰
                (if you want "pasted boxes" draw the Target component with the same width than the Source!
                  • dereiD Offline
                    derei
                    @tig said:
                    See this example too...[attachment=0:2tl8pxlo]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2tl8pxlo]
                    This is how I did it yesterday πŸ˜„ And this is the reason I insisted on fixing RandomPushPull plugin β˜€
                    Thanks again
                      The RandomPushPull tool is at last working properly πŸ˜’
