    [Plugin] Slicer v4.3 20110619
    102 Posts 20 Posters 149.4k Views 20 Watching
      Gschwartz9
      I tried both methods, but unable to make either work.
      Someone please tell me if my expectations are unreasonable, or point me toward a solution.
      There's always a better way.
        I still think Zorro[2] should do what you want...
        I have 'chop.rb' [unreleased] that does something similar - simply splitting all of geometry inside the preselected things along the plane defined by 3 picked points...
        I'll see if I can get it decent for the public... If I recall it only chops to one level of nesting - probably more than enough for you... but not great as a general tool... πŸ˜•
          kyyu
          @gschwartz9 said:
          I've tried: Subtract, Split, Trim, Zorro & Zorro2. All either don't do the job, or require significant "repair" work on the cut pieces.
          This snippet of code can take care of the repair work, after using the solid tools (Trim?). Right click the group and select "Divide Group after Trim". Just be sure no loose geometry is touching it(groups & components are ok), otherwise they may be incorporated into the new groups.
          divide group after trim.rb
            Gschwartz9
            I'll give Zorro[2] another try. Also interested in your chop tool. You're right about only one level of nesting needed.
            I think it would be great as a general tool. Examples: *Plumber working with sections of 2" copper pipe for a long run that has many changes in direction and varying lengths of pipe, *Landscaper laying tiles along a curved path, *Carpenter determining which length of lumber will be most efficient for a project that needs several pieces of varying lengths, *A craftsman determining how much of a very expensive wood he needs, *A retired Mechanical Engineer attempting to optimize usage of laminate flooring.
            Of all the tools I've looked at, Section Plane seems to have the essence of what's needed. It lacks is the option for retaining both sides of the section cut. An enhancement would be user-selected distance between the sides. That distance would vary depending on the material being cut; e.g. copper pipe, construction wood, model-makers wood, concrete ...
            Is the code for Section Plane available?
              Gschwartz9
              [attachment=0:1q6mm088]<!-- ia0 -->divide group after trim.rb<!-- ia0 -->[/attachment:1q6mm088]
              WOW!
              This does the job. Thank you kyyu.
                Gschwartz9
                One remaining question:
                When I apply short reference lines to the edge of planks to use when I stagger the rows by 1/3 plank-length, the group is recognized as a group, but not a solid.
                If I edit the group & erase the reference lines, it is recognized as a solid.
                Where did I go wrong?
                  A solid is a group/definition where all edges have two faces - no more no fewer!
                  So faceless-edges, faces without a neighbor [a flap], internal partitions where an edge has three or more faces or otherwise 'solid' forms that meet on a common edge so that edge actually has four faces... will all report as non-solids...
                  So to avoid 'unsolidness' ensure that all edges have two, and only two faces... and use other means of adding 'guides'...
                    kyyu
                    You could use "guide point/lines" placed by the "Tape Measure Tool". Or there are plugins that make center points (aka construction points) and you can copy/paste them after they are replaced. Or plugins that may place the construction point directly. The picture below, illustrates the two methods.
                    Or making construction lines, outside of the group, may turn out to be a better solution. That's how I normally do alot of my alignment.
                      Cubcrafter
                      Is it possible to have variable spacing of the slices.
                      Such as the first slice is at the face of the object, second slice at 3", next slice at 8" and so on.
                      Thanks,
                      Larry
                        Not unless you rewrite the code!
                        It would be possible if you rewrite the loop that steps through the slice spacing - instead of using the spacing to move the intersecting 'disk' in even steps, you'd compile an array of the spacings and then iterate those in turn...
                        Why do you want to do this ??
                          Cubcrafter
                          Tig,
                          I want to use something like slicer to locate bulkheads at exact locations along the fuselages of some aircraft designs that I am working on. I like the way it can take the slices and lay them out flat so that I can export them to my laser cutter.
                          Maybe there is a better way, I don't know.
                          Larry
                            Make a large vertical rectangular face that will readily include the whole fuselage.
                            Group it.
                            Copy that group along the fuselage at the desired centers, typing in the exact dims as you go [Move+Ctrl...].
                            Double-click each face-group in turn and 'select-all' [double-click on the face].
                            Right-click and context-menu = Intersect > with Model...
                            The fuselage outline is imprinted on the face.
                            Erase any edges/faces you don't want.
                            Pushpull the required face[s] by the desired distance [tip once you've done a Pushpull you only need to double-click on a face to repeat the same 'extrusion']
                            Repeat this for all of the 'cross-sections' until you have all of the 'bulkheads' made.
                            To lay them 'flat' view in side elevation [perspective off] and use the Rotate tool on each one individually to flip them so they are horizontal.
                            When they are all done move them around in a plan view as desired... print off...
                              Cubcrafter
                              Thanks TIG.
                              Attached is a quick and dirty sample of what I think you were talking about.
                              Larry
                              Slicing.skp
                                That's about it... but I trust your fuselages are a little more complex! πŸ˜‰
                                Use layers to hide the fuselage [which I hope is grouped/componented] when you no longer need to see it...
                                Tip: when you are editing a group/instance you can switch everything else off during an edit - under the menu 'View' - 'Component' Edit - 'Hide Rest of Model' - that makes seeing what you are doing much easier! The fact it's hidden in the edit won't affect the intersecting you might do... πŸ€“
                                • X Offline
                                  xrok1
                                  @tig said:
                                  @xrok1 said:
                                  I have a [privately written and hopefully paid for] 'Slicer v4' that has such lines added etc for CNC work - watch this space.
                                  hey, are you finally going to make your own and bust that slicemodeler @&&hole
                                  I have written a paid commercial version [private] - Slicer_v4 - for someone for CNC use etc... it [or some of its ideas] might leak out to you too... πŸ˜‰
                                  Did u ever decide to do this? πŸ˜›
                                    Yes and no...
                                    I have two slicer-like commercial projects on... one day when they finish I hope to up date using some of the ideas in them... but don't hold your breath waiting...
                                    πŸ˜•
                                    • X Offline
                                      xrok1
                                      OK. I still appreciate all you do though. 😍
                                        I'm waiting....
                                        http://blog.nutrex.com/wp-content/uploads/2011/08/holding_breath1.jpg
                                          Exlax...
                                            Aaaaaaaaaahhhhhhh πŸ‘
                                            • 5 / 6
