    Get rotation(transformation)
    31 Posts 3 Posters 2.7k Views 3 Watching
    • jolranJ Offline
      jolran
      I used the term 'container' to refer to the generic 'entities container'...
      I suspected it was something like that you meant. I'm so new on this so I dont grasp the "talk"
      donte walk the walk etither πŸ˜„
      Do you want the translation vector to have a length of: "user_length = 20" ?
      Hi Kyyu. I want to have multiple copies in vector direction. User-length is the amount of distance
      between copies. In this case 20.
      I should have documented my code better. Its difficult to understand want I am trying to do.
        Once you have transformed the vector you can change its length using my_transformed_vector.length=20.0 all of the values will adjust to suit the new length BUT the vector's length will then be 20"...
        • jolranJ Offline
          jolran
          YEY! That works!
          I dont know if it will matter if the vector gets shortened, just yet.
          Was thinking of grouping the result. Make an duplicate. Scale -1 in vector and do an intersect with.
          You probably figured out already what this plugin will do.
          Thank you TIG!
            Could we go back a few steps and explain what 'it' is you are trying to achieve - it may be much easier that you think...
            • jolranJ Offline
              jolran
              Yes, I hope soo πŸ˜„
              Ok. So the idea is to make a Hatchplugin.
              First step is to use sketchup tools and make a face. Wall, rectangle whatever. Select it and run the plugin
              with a simple promt.
              In general getting input from user about desired line_angle and distance between them.
              Make the lines and some sort of grouping before intersect_with method.
              Wich hopefully will give the result of hatched lines.
              So by using boundingbox One can use the plugin on unregular faces, not just squares.
              I wish then to copy lines across the diagonal in the boundingbox, making sure I get edges in the corners.
              Why boundingbox? For ex. If I have an edge that is 45 degrees com to X , copying that line from center in an array straight up in Z until it reaches the boundingbox will leave the corners uncovered.
              Maybe if I new how many copies to clear the boundingbox with the last copy of edge that may be an easier
              method. But that all depend on how the boundingbox is shaped?
              Same goes for copying along the diagonal.
              You may be right, there might be some easier method of doing this. But I'm no math expert and struggling here
              understanding what I just did.
              Help would be very welcomed, and mentioned if I get this to work πŸ˜„
                Well... here's how I'd do it...
                <span class="syntaxdefault">module&nbsp;TIG<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">hatchfaces</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;ents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;name</span><span class="syntaxkeyword">=</span><span class="syntaxstring">'Hatching#1'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">defs</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />&nbsp;&nbsp;&nbsp;&nbsp;spacing</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">2.0&nbsp;</span><span class="syntaxcomment">###&nbsp;2&nbsp;inches&nbsp;###<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;&nbsp;&nbsp;faces</span><span class="syntaxkeyword">=[];&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'hatchfaces'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">names</span><span class="syntaxkeyword">=[];&nbsp;</span><span class="syntaxdefault">defs</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">names&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">?}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">next</span><span class="syntaxkeyword">!&nbsp;while&nbsp;</span><span class="syntaxdefault">names</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">name<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;gents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">gp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;face</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;di</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">diagonal<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;pt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ve</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.clone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">rotation</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">45.degrees</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">di</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">2<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;tot</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;until&nbsp;tot</span><span class="syntaxkeyword">>=</span><span class="syntaxdefault">di<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ps</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_line</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">ps</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">!(</span><span class="syntaxdefault">ve</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">spacing</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ps</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_line</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">ps</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">!(</span><span class="syntaxdefault">ve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">spacing</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tot</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">tot</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">spacing<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end</span><span class="syntaxcomment">#until<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">intersect_with</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;and&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">and&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;and&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />&nbsp;&nbsp;end<br />end<br /></span><span class="syntaxcomment">###&nbsp;usage;&nbsp;select&nbsp;faces,&nbsp;TIG.hatchfaces<br />&nbsp;</span><span class="syntaxdefault"></span>
                • jolranJ Offline
                  jolran
                  WOW, you rewrote the whole script?!!! You are quite amazing. But, but.. Its your plugin, then??
                  Heh, I almost got mine to work except the "petite" distance between lines thingy..
                  Can I load the code in ruby code editor and launch? Cause nothing happends when I run your script.
                    Please use it [or ideas in it] as you will - for example it doesn't always set the hatching at 45 degrees to where you might want just relative to the first edge of each face...
                    There's no options for the angle or spacing - add a dialog for those?
                    It's not optimized as it often makes more/longer edges than it needs to make the hatching but it was a quick kludge to make it work - to see what it does disable the closing parts that intersect/erase edges etc and use it on one face...
                    It has ideas in it that should help you... πŸ€“
                    PS: You have to have one or more faces selected before running it...
                    • jolranJ Offline
                      jolran
                      You are so helpful. I can almost not believe it..
                      Thank you TIG!
                      I will continue with my script since I understand easier where variables are pointing to.
                      See where I have gone wrong in some areas and use your script as a guidence.
                      Thanks a million!
                        kyyu
                        @jolran said:
                        I'm getting it to work almost.
                        vector.length=20.0
                        The copied distance will always be desired length on the vectors line, but depending on the angle of diagonal the edges will not be same distance apart. So I guess I will have to do another compensation? Or is there some Quick fix like the last one(thank you TIG)
                        I'm guessing will have to do a comparison between Diagonal, user(desired angle, here 45 deg) and somehow
                        compensate the copy distance for that. Boy this is hard..
                        Here is a example of finding the normal vector of a grouped line, using a cross product. The cross product of two vectors prduces a third vector, at right angles to the original ones.
                        model = Sketchup.active_model
                        ent = model.entities
                        sel = model.selection
                        line = ent.add_line [3,3,0], [5,5,0]
                        group = ent.add_group line
                        v1 = line.vertices[0].position.transform(group.transformation)
                        v2 = line.vertices[1].position.transform(group.transformation)
                        v = v1.vector_to v2
                        # I used z vector as 2nd vector, but can try "face.normal" for general case
                        normal_vec = v.cross([0,0,1])  #cross product to get normal vector
                        pt = [0,0,0]
                        demo = ent.add_line  pt, pt.offset(normal_vec)  #drew demo line representing normal vector
                        demo.material = 'red'
                        n = normal_vec
                        n.length = 1
                        g1 = group.copy
                        g1.transform! n  # moved copied group using normal vector
                        • jolranJ Offline
                          jolran
                          Hi Kyyu!
                          Interresting. So you mean I use the 3rd vector for measuring? Or was it meant to be
                          a method to get an angle 45 deg of the vector?
                          Remember 45 deg is just an example for this particular hatching. The user must be able to
                          choose any angle for the lines across the face.
                          I will look into it more and see if I understand you code a little better.
                          Thank you Kyyu.
                            kyyu
                            @jolran said:
                            Hi Kyyu!
                            Thank you Kyyu.
                            The 3rd vector would be your translation vector. In your code you have it as:
                            vector=diag_vect
                            vector.length= user_length
                            It's perpendicular to what ever your final line is. Here, I just changed the line to a random new angle, not 45 deg. I set the length of the vector (distance of translation) to 1.
                            I found this picture that explains cross product pretty well.
                            • jolranJ Offline
                              jolran
                              Translation vector? The translation must be on the diagonal or the lines wont cover the whole face.
                              I already have the rotation of lines, copy/translation set up. Except that the "bug" is that
                              the translation distance doesent get 100% accurate if the face is very distorted.
                              Maybe that is what you are trying to fix, and I don't see it.
                              If thats the case sorry 😳 I'm a noob, you know.
                              The angles of lines on the picture are the identical. Although they don't appear to be.
                              • jolranJ Offline
                                jolran
                                Hate to bother again, but I've been going on all day and intersect_with is troublesome. 😞
                                Tried TIG's combo, and others but I think I'm making a fundamentional fault.
                                Doesent intersect_with work with nested groups?
                                tr3=Geom::Transformation.new()
                                face_group.entities.intersect_with(recursion,tr3,face_group,tr3,true,[hatch_lines_group])
                                  If you read through the way I did it... I make a hatching group then simply add a face and overly long hatching lines to it, intersect everything with each other, erase the faceless edges outside of the face perimeter and then erase the faces too. I never use subgroups - if you want to then just explode them...
                                  You are better off transforming points/vectors and drawing the edges that grouping things endlessly/needlessly it'll be slooooow πŸ˜‰
                                  • jolranJ Offline
                                    jolran
                                    Aha! Did not quite understand what was going on.
                                    Yes, yes I will TRY to do the same. That way I will learn the right way. Slow doesent sound good πŸ˜„
                                    My resulted line_groups apears pretty fast on screen for the moment though, and its possible to make
                                    a manual intersect with selected. But a lot cooler if it is manual.
                                      kyyu
                                      @jolran said:
                                      ...Except that the "bug" is that the translation distance doesent get 100% accurate if the face is very distorted.
                                      Yes, that is what I am showing how to fix.
                                        Where my script does a transformation.rotation on things simply using 45.degrees so it your user inputs an angle in a dialog as a 'float' - e.g. 12.5 use - angle=results[0] and spacing=results[1] (or whatever your dialog returns) and then in the transformation.rotation use angle.degrees instead...
                                        • jolranJ Offline
                                          jolran
                                          Great!! Will try that. But? That correction will just be a fix for the dialoginput, no?
                                          I havent gotten that far yet 😳
                                          Or maybe you mean your advice WILL fix missing geometry in the corners in certain angles)? Cause thats what bugging me, atm. I was only using Int's changing the angles and spacing.
                                          Maybe that face.normal rotation of yours doesent work in all angles? Unless som serious fix?
                                          Then using grouped edges might be more suitable, what do you think?
                                          I'm not questioning anything, just don't know wich way to go.
                                          Thank you TIG.
                                          • jolranJ Offline
                                            jolran
                                            BTW. The splats in my script was probably coming from the outliner open.
                                            So Hmm. The direction I'm taking now is using edge_group_copying(my original idea). I cannot modify TIG's version due to lack of understanding. Not sure it will work like it is. But I'm a screwbie with bad solutions, so TIG can probably just wack in something just like that to prove I'm wrong πŸ˜›
                                            But I will try to use the face normal to align my copies like in TIG's script, just to
                                            have something to work on.
                                            And use Kyuu's example for getting better accuracy with the distance between copies.
                                            Methods for each view/axis would prob. make the script unnecessary long.
                                            ABout adding groups. Sketchup doesent like it when your inside a group in model mode-
                                            select a face- then by code add a group?
                                            No suggestions I suppose? 😐
