    HELPPPPPPPPPPPPPP
    renderpluginsextensions
    6 Posts 3 Posters 876 Views 3 Watching
      dizain
      Hello everyone,
      I need urgent help for a problem with v-ray and ask to speak to you before ChaosGoup.
      When I launch the rendering in V-ray hand and tells me to wait because it is processing the scene, but then does not open the window of the frame buffer and nothing happens. I have an urgent delivery and I can not solve the problem.
      HELPPPPPPPPPPPPPP.
      thanks
      • andybotA
        andybot
        perhaps you are running into memory issues? Which version of vray and which version of sketchup are you running?
          dizain
          Hello,
          SU 8 and last updated version of V-Ray 1.49.01.
          The problem is even with a small part of the model.
          • L
            ledisnomad
            Even with 1.49.01 I have had problems with image textures. You can test to see if this is the case in your Vray Material Editor: render a preview of each material that has an image for a map. If it has problems with one of the materials, that's your source. If it renders all of them, then you've at least ruled out that problem.
            What is the face count in your model? I don't suppose you could post the model (or at least a screen shot of the model)...
              dizain
              Hello,
              seems that there are materials that do not work. V-Ray material editor but I can not delete them. I deleted the textures in the folder πŸ˜„ \ Documents and Settings \ David \ Local Settings \ Temp \ VfSTextureCache, but without success.
              I opened a new document and the materials appear in the material as a $ $ Light Sprites Light Cache ... What are they?
              thanks
              David
              • L
                ledisnomad
                Well, at least it seems you've found the problem. You shouldn't have to delete anything, just remove the texture map from the material. Otherwise, you should be able to right-click on the material and remove it. Want to post a screen capture of one of the materials that doesn't work?
