    [Plugin] TextureTools
    106 Posts 34 Posters 112.7k Views 34 Watching
      @rv1974 said:
      Dear ruby makers!
      Please, If you put arrow keys (or any other ones) into the game make a temporary shortcut override!!!
      There are some really usefull scripts with vulgar occupation of keys that make the life much harder.
      Meanwhile only Thomthom implemented this feature.
      Sorry to say BUT I consider that you have it quite backwards!
      Scripts that use Arrow-keys for 'nudging' values are quite common - which suggests that you shouldn't assign them as your own shortcuts! It's not like we are reusing 'standard shortcut keys' here - we are just using logical key presses within an add-on tool.
      Just as you wouldn't sanely assign a shortcut key to a number [0-9], as they is used in the VCB in most native tools, or even 'x' or '*' or '/' as that is used in Move+Ctrl copy array etc, or say swap M from Move to Delete ! ...
      There are lots of keys, and modifier-key combinations for you to choose from when setting your custom shortcuts, without you having to use any of those that are needed by add-ons to be used logically...
      It was only because Thomthom wanted to use the Move, Rotate etc shortcut keys in his Vertex Tool, that he mimics how they are set up in a default installation for the native tools - so you can use M to Move an entity in the native tools or Move a Vertex within his tool. However, the hoops he has had to jump through in code to get it to work are not acceptable to many scripters. Indeed, if you've ever had his tool crash, leaving these shortcut keys remapped, then you know how annoying even his fix is, because then many of your shortcuts are left permanently reset to the wrong tools, even when you are out of his tool, leaving a manual remap of shortcuts the only option to revert to a default setup... TT's tools are also now compiled as rbs files so the methods are not readily transparent to other scripters...
      I wrote the original TextureRotate code from scratch in just two hours... as a 'proof of concept' - you'd have had to wait a lot longer for a 'massaged' version of the code to remap shortcuts etc... BUT if you want shortcut keys remapping temporarily then do it yourself - the code is open to your reuse! If you invent a simple, safe and foolproof temporary key remapping method then I suggest you publish it as then scripters might be more inclined to add the safety-net for those of you who persist in shortcutting to keys that are better left alone to tools that really need them πŸ˜•
        rv1974
        'If You Want a Job Done Right...'. Got the message
          rv1974
          Hi TIG!
          May I ask your for some new texture editing functionality (especially after 'extrude edges by offset' is out)?
            Matt666
            Hi TIG, and thank you for this great script!
            Just one thing, I've mentioned here an plugin idea, that could rotate a texture along the longest dimension of a surface. Do you think it's possible?
            Frenglish at its best !
            My scripts
              Matt
              Here's a one-liner that gives you the angles of a selected face's longest edge relative to the X_AXIS/Y_AXIS/Z_AXIS - the result in degrees [e.g. 90.0, 66.666, 0.0] you can then copy+pasted the sensible one into the TextureTool's Rotate dialog and the texture will realign with the long edge...
              f=Sketchup.active_model.selection[0];es=f.edges;ed=es[0];d=0;es.each{|e|(d=e.length;ed=e)if e.length>d};x=ed.line[1].angle_between(X_AXIS).radians;y=ed.line[1].angle_between(Y_AXIS).radians-90;z=ed.line[1].angle_between(Z_AXIS).radians;(x=x-90;y=y-90;z=z-90)if f.normal.z.abs==1;p x,y,z
              That assumes that the current texture has never been rotated...
              It's not perfect but it's a start... πŸ˜•
                Matt666
                Thank you for your answer TIG, I'll take a look!
                I was thinking more of a tool that would orient textures in current selection (groupe, component, or faces), or even the entire model... 😳
                My scripts
                  The three TextureTools Rotate/Scale/Shunt are written to allow passing of arguments, so they can be run from other tools without a dialog.
                  So, if you pass an angle in degrees to the 'rotate' tool then there's no dialog...
                  So you can envisage a new tool that iterates all of the faces in a selection and finds the long side of each, calculates the rotation needed, and then uses the 'rotate' tool with the required angle passed to it so that the faces are processed en mass...
                  It only works on one selected face at a time... so the new tool's code needs to use
                  ` ss=model.selection
                  ssa=ss.to_a
                  ss.clear
                  iterate face in faces
                  ss.add(face)then later ### find angle_in_degrees etc...
                  TextureTools::Rotate.new(angle_in_degrees)
                  ss.clear
                  loop`
                  on close it could then use
                  ss.clear ss.add(ssa)
                  to restore the selection as it was...
                    Matt666
                    Ok that's great! Thank you TIG!
                    My scripts
                    • McGyverM Offline
                      McGyver
                      I must have missed this one before, but thanks again for another immensely useful and generous plugin!
                      Visit My ShareCG Freebie Gallery
                      • PixeroP Offline
                        Pixero
                        TIG, I have a request.
                        Would it be possible to add a "rotate, scale and match UVs" tool?
                        It would work this way:
                        First, you select all the faces you want to edit the texture on.
                        Second, you click on the tool and select one face you want to use as a reference.
                        Third, the script matches scale and rotation, AND if possible, offset of UVs from the reference faces UVs compared to the vertices of the faces in the initial selection. (Does this make sense?)
                          It's possible to 'batch process' textures on faces by passing arguments as explained elsewhere in the thread... The complication is gleaning the scale/rotation of the selected face's texture... I'll sleep on it [for a day or two...] πŸ˜‰
                          • PixeroP Offline
                            Pixero
                            I'm not sure I understand the word "gleaning"?
                            Would it be possible to compare the vertices position/distance from the "reference" face and the others and get the UVs from that? Just a thought...
                              Sorry, my slightly 'old' English slipped in there... by 'gleaning' I mean gathering up small bits from a larger amount... 'to glean' the wheat from the chaff when threshing corn, is to collect the small grains of wheat and leave the rest of the straw etc behind... SO by metaphor - we need to collect the important small bits of data from the larger amount that is available - by some yet unspecified process...
                              We would need to take the UV-mapping of one face and apply it to others - that's straightforward... however, using relative rotations etc gets more complex... πŸ˜•
                              I'm thinking about it...
                                Missed this πŸ˜•
                                Any chance you could add a scale feature?
                                  πŸ‘Ώ
                                  • I Offline
                                    IronCastles
                                    I have been happily using Texture Tools for a few weeks, but seem to have borked them with the addition of other plugins. I have been backtracking to disable / remove some of the unexplored/less useful items, but wonder...are there any known plugin conflicts to avoid with TT V. 1.5? I reeeeely like it.
                                      There shouldn't be any clashes with other tools - they are self-contained in there own Module and there are no added/changed built-in methods ??
                                      Can you post any messages from the Ruby Console [which needs to be open before you run anything] when you test its tools... or other tools that seem to 'clash'.
                                      Script 'clashes' are very rare and usually arise from rewritten shared methods or observer glitches - but I'd be surprised if it were the case here πŸ˜•
                                        golduck
                                        good
                                          jojoarmani
                                          Thanks Bro for creating such wonderful plugin...
                                            the.pjt
                                            hi dear TIG ...
                                            this plugin is grate .. it installs with no problem .. and it runs well when I install this codes in a blank plugin folder with SU's default rubies ... but ... when I try to run it whit my own plugins folder with many rubies installed , it doesn't run in the way ... no start up problems .. but when I click to a Icon in your toolbar anything happens ...
                                            help me ... I thing your plugin intersects with another plugins .. because when I turn them off the plugin works well again ...
                                            i'm not a developer but I sometimes read the developers section .. I have seen a topic that say developer should use unique classes and unique names ...
                                            so please change your code names .. if it's need ... I don't know about it .. you are a SU ruby genius .. and you know it better than me ...
                                            but .. there is a bug that happens when I load my outher plugins ( include VRAY , and lots of other rubies ) .. loading theme disables plugin's function
                                            • 4 / 6
