    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      @shoeb_cars said:
      till recently i was using cleanup3 in SU7 but it was a bit slow so i stuck to ur first version which is mighty fast and doesnt ask too many questions. but i recently migrated to SU8 in which cleanup1 doesnt work so then i tried cleanup3... and i just bloody fell in love with it. it is fast and damn, is it clean. as always thom thom "U da MAAAN"
      I'm guessing you had "Erase Duplicate Faces" checked - which is very slow.
      • marleusM
        marleus
        Thanks ThomThom ๐Ÿ˜Ž
        I do a lot of 3ds-import and conversions and your ruby really
        speeds up my work and reduces file size ๐Ÿ˜
        I ove you one ๐Ÿ˜„
        Markus Sillander
        Vantaa, Finland
        I'm on FormFonts now
        http://www.formfonts.com
        • P
          publied
          very nice and very very useful. thanks theo
          hire me@ http://www.publied.it !
          • L
            LannorMov
            Thomthom, yo veo ese plugin como muy pesado ๐Ÿ˜Ž ยฟno te parece? o es que la mรกquina en la que hiciste el vรญdeo es de poca capacidad?
            Es solo una apreciaciรณn, no lo tomes a mal.
              ke?
              • L
                LannorMov
                @thomthom said:
                ke?
                Thomthom, I see this plugin is heavy is, or not? or is the machine where you made the video that is of capacity limited?
                It's just an appreciation, not take it personal.
                  The model I used was a very heavy model. Lots of geometry. I used it as an example to show how fast the plugin worked even on very large models. ๐Ÿ˜’
                  • L
                    LannorMov
                    ok, thanks, I installed it and it works great.
                    Thanks you mate
                      # 3.1.4 - 16.05.2011
                      #    * Added error detection for merge faces.
                      #    * Added validation for merge faces to avoid geometry loss.
                      #    * Added result feedback to Ruby Console for each standalone operation.
                      #    * Fixed namespace compatibility with TT_Lib 2.5.4
                      #    * Fixed merge similar material but - now compare alpha
                      #    * Changed "Lonely Edges" to "Stray Edges"
                      Requires TT_Lib 2.5.4
                      • L
                        LannorMov
                        What is this? I do not understand
                          Essahรบ
                          If you read the Cleanup download page it says that it also needs the extra 'Lib' files - there is even a link to the thread from where you can download that 'Lib' files folder...
                          Go back and look for it, get the zip-file, extract its folder and put that into Plugins... fixed! ๐Ÿ˜’
                            It's just a little notice about the update I released. Some minor fixes.
                            • GaieusG
                              Thanks, TT. Whatever "minor fixes" you made, this is one of my most valued and frequently used plugins. ๐Ÿ‘
                              (I'll need your home address to send those cookies!)
                              ๐Ÿ˜„
                              (This is my favourite "local" brand)
                                ๐Ÿ˜„
                                • Z
                                  Zacchia
                                  Thomas
                                  Thank you very much for this amazing plugin!!
                                  • dereiD
                                    derei
                                    Suggestion: make the cleaning operation stoppable. I just started the cleaning of a high-poly model and it was a very uninspired action ๐Ÿ’š ... it will take a very long time (it shows me something about one hour) and the only way I can stop it is to close Sketchup. And I didn't saved the model before ๐Ÿ˜„
                                    Also, before starting, it would be nice to make a time estimation and if the process is estimated to take more than...let's say 1 minute, to alert the user something like this: "The cleaning process can take about XX minutes, are you sure you want to proceed? You can cancel the process anytime by pressing ESC" ...or something like that. I think the alert should appear only if the cleaning time takes too long, other it might be annoying.
                                    Thanks for taking this into consideration.
                                    DESIGNER AND ARTIST DEREI.UK
                                    • EarthMoverE
                                      EarthMover
                                      Me as well. I can't thank you enough...so here's another. THANKS! ๐Ÿ˜„
                                      Content Creator at Skapeup
                                        Unfortunately this is not an easy thing to do. With the Ruby API it's virtually impossible without using timers to split up the work - which I have run some tests on and it will increase the total processing time any times. So if the process took 10 minutes with no abort feature, it's take 30-40 minutes with an abort feature, which I find much worse.
                                        Mind you, Erase Duplicate Faces is a feature in CleanUp that takes a loooooong time - I've warned so in its tooltip. It's also off by default. If you struggle with long processing times ensure this is off. I've run CleanUp on some very large models, without that feature checked, and it's completed within a few minutes.
                                        • dereiD
                                          derei
                                          Indeed, I ran with Erase Duplicate Faces, because that was what I needed. What about the duration warning? If the process is better to not be cancelled, at least the user to know what is going to do ๐Ÿ˜„.
                                          Finally the cleaning didn't last one hour as the progress bar displayed, but about 13-15 minutes. Why this big discrepancy between what it shows and the real time?
                                            It's troublesome to calculate this. The more geometry in a context (group/component) the longer SU takes to do any modification. For instance, if you add 1000 edges to a group, the time it takes to add each edge depends on how many there already are. The time is not linear. I suspect it's because SU auto-merges geometry and such.
                                            And for CleanUp, which does many cleaning operations, one operation might make the next one run must faster because it's reduces a lot of the geometry.
                                            The estimated time is a result of how must time it has spend up to the current iteration versus the total - and from there a guestimate is given. But as you notice, some times it's much faster because some iterations do nearly nothing if there is nothing to cleanup.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 48
                                            • 49
                                            • 18 / 49
