    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.2k Views 172 Watching
    • N Offline
      neonro2003
      It works fine
      http://www.mypicx.com/06072011/Ivye/
        matidami14
        matidami14, take a look of this, maybe work for you.
        http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
        the files are in here:
        http://www.sketchando.net/descargas/ivy_leaf_enavas_ver6.0.rar
        Regards
        ok.. this is frustrating 😞
        i have check all the probabilities and nothing happens...
        i think it's my SU (sketchup 8 pro)
        any one can please tell me step by step (yes, i'm diot!) how to intall, run and render ivy?
        i really need this..
          jokewalker
          Noobie to posting and to Ruby so I'm not sure if I'm missing something basic. I'm having similar issues to others in 0.6.3beta. The only error I see is:
          "Error: #<ArgumentError: Cannot find material named ivy_stem>"
          I've checked my Textures folder (the properly saved one for SU7.1) and all the filenames are consistent. Is this an issue that needs to be solved in the console???
          Any insight will help...Thx
            Try making a new material called "ivy_stem" and rerunning it.........
              jokewalker
              TIG,
              That fixed it! I figured it was something simple. Now to play around with this thing and see what it's made of.
                There's certainly an error in the tool's code that's NOT making the material named 'ivy_stem'... BUT if you make it before using the tool it will work...
                Hopefully an update will fix this glitch...
                • romboutR Offline
                  rombout
                  how come for a lot of peeps the 0.6.3 versiion does work?
                  on the mac i doesnt do anything, no feedback no nothing?! 😲
                    I don't know.
                    The scripts form a complex web methods etc.
                    There are clearly issues like some variables defaulting to 'nil' when they should be 1 or 0, and now this 'ivy_stem' material not getting made...
                    It needs something of an overhaul... πŸ˜•
                    • OxerO Offline
                      Oxer
                      Hi Rombout,
                      Try this version, works for me on Mac OSX 10.6.7 and SU 8.
                      Keys on Mac:
                      Click where you want the Ivy to start grow.
                      Cmd+Click : Make the ivy grow towards the mouse position.
                      Alt+Click : Grow Ivy leafs.
                      SHIFT+Click : Finish Ivy.
                      Keyboard 'i' : Start over.
                      SU Ivy works on Mac
                      • romboutR Offline
                        rombout
                        Hi Rombout,
                        Keys on Mac:
                        [attachment=0:3k2xek9g]<!-- ia0 -->SketchupIvy.0.6.beta.zip<!-- ia0 -->[/attachment:3k2xek9g]
                        Hahaha you already gave it me! Thanks anyway this one does workl indeed.
                        Petty that the last revision doesn't work and doesn't give any feedback in the ruby console. Think we simply need to be patience
                          driven
                          @ Oxer and rombout,
                          if you swap the html file out of 0.6.3 it's better formated for the mac [and shouldn't ruin anything]
                          I only get one or 2 leaves with Oxers 0.6, and 0.6.3 has stopped working since I upgraded Safari to 5.0.6.
                          what Safari versions are you both using?
                            The latest version of Safari broke one of my commercial plugins dialogs on MAC!
                            Now fixed... BUT it's very unforgiving of even minor syntax foibles that used to work anyway - unlike it's precursors and IE [dare I say!]... πŸ€“
                            • romboutR Offline
                              rombout
                              @driven said:
                              @ Oxer and rombout,
                              oww...
                              i fixed it myself by adjusting the dimensions of the popup window in SU. i edited one of the *.rb files.
                              I also think it doesnt have something to do with safari i use firefox as a standard and a have edited it so that all files will be opened through FF
                                driven
                                SU uses 'Safari' webkit, so anything in a WebDiaolog needs to work on Safari,
                                for example if you remove your Safari Flash Plugin, Googles Photo Match won't work inside SU.
                                knowing which Safari version SU has use of can make debugging a bit easier.
                                cheers
                                • romboutR Offline
                                  rombout
                                  oke here you go
                                    As the basis of its webdialogs the Sketchup API uses 'IE' on a PC and on a MAC it uses 'Safari' ...
                                    Recent changes to Safari have made it less forgiving than it used to be, IE may well follow suit in its own time.
                                    Now it does things 'by the book' it can break methods which worked on earlier versions, or still work on PC - this happened to some of my code, where I was setting an 'innerHTML' value as an attribute rather than a property - it was working fine on all PCs and MACs for well over a year, then it was suddenly broken on a few MACs...
                                    We [TBD to be precise] finally tracked it down to the initial 'error' in my coding which had actually always worked until Safari got updated and became super-strict - insisting I code things properly [cheek! πŸ˜‰ ]
                                      matidami14
                                      it doesn't work.
                                      i dont know wat u do with the plugin but a nob, following this steps gets the results thet i get.
                                      may be u have a ivy version better or u change something on the file.
                                      i have SU 8 pro and IVY 1.6.3
                                      • EscapeArtistE Offline
                                        EscapeArtist
                                        I thought I posted this in this thread, but it seems to have disappeared. (?!) Anyway, used SUIvy and flipped it upside down, replaced some leaves with flowers and it makes a hanging flower for a window box. If I have time I'll see if I can improve it, but I'm still trying to get the growth right.
                                          pancho179
                                          Nice Plugin Pierreden!
                                          I see great potential in it, however I can't get it to work. 😐
                                          I see the red outlines perfectly, but when I shift+click in order to "render" the ivy it only constructs the first branch in lines, no faces, no more branches, no leaves, nothing at all.
                                          I donΒ΄t know if anyone has had this problem, I skimed through the 250 posts on this thread and didn't see anything similar.
                                          Hope someone can help.
                                            Open the Ruby Console and try again. See if it reports anything.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 36
                                            • 37
                                            • 16 / 37
