    Better Renders
    extensions
    15 Posts 8 Posters 1.8k Views 8 Watching
      minguinhirigue
      Quite good render, As others said, you'd better add some detail.
      An example are the feet of your furniture. There is always in reality some really small distance (less than 1mm) between the foot of an object and the floor, this create a small sharp shadow. You can "trick" it with a sharp edge (3DS) or simply by moving the object just 0.2 mm or 0.5 mm above the floor.
      You sould also had some global illumination or some arbitrary light sources, much softer than the principal one, because in real world, the light never come from only one point.
      An other point are the junction between legs and deck, you could add somme detail there.
      I do not know well the bump, normal and displacement maps, but I've that they are quite powerful, take a look at it, specially for large surface with small detail like the floor.
        bjornkn
        @adamb said:
        Displacement map (typically grey-scale) actually modifies the mesh (moves the vertices about).
        Well thats not quite how it works.
        That depends on who you're asking πŸ˜‰
        Some engines can do microfacet/subpoly displacements, and some can not.
        The render engine in LightWave will only displace real vertices (or subD'd), while other renderers (like vRay?)can make a lot more detailed displacement than the mesh density, and thus be used for making 3D grass etc.
          Thanks for the clarification, Adam (I did not know Rich is so experienced in these terms BTW).
          However for us, "puny humans", there is probably not too much difference. Briefly; while bump and normal maps only affect shading (I mean just literally), displacement also affects how the mesh appears (at least). Now how this is achieved, may be a technical explanation. Good to know ("about") the finer details, too.
            I do my homework before answering. But Adam sees through my web of intrigue. 😲
            • jason_marantoJ Offline
              jason_maranto
              This Sketchup plugin works as a displacement map inside Sketchup -- it is not a render engine only feature: http://forums.sketchucation.com/viewtopic.php?p=275772#p275772
              My advice, download the free Substance Player here: http://www.allegorithmic.com/products/player
              this comes with several free Substances including a seamlessly tile-able wood floor generator that will create normal/bump/displacement maps (among others like diffuse and specular) based off of any wood image you give it. It's free and it's really easy to use -- try a few maps and see which results you like best...
              Best,
              Jason.
                I've heard of this tool before somewhere? But never tried it out. Thanks for reminding me Jason πŸ‘
                  Yes, DallasRT uses its main application to produce his mats (on the Thea forums). He shared a bunch of presets he made and that can be used for generating textures in the player. I have not used it much myself but it seems to be a nice toy actually.
                  • AdamBA Offline
                    AdamB
                    LightWave Subdivision surfaces are a different thing entirely. They are fundamentally a modelling primitive (with a nice limit surface), whereas Displacement shaders are about rendering your model.
                    [While I admire the skill in the author of SketchUp plugins that model surface details with "real" geometry, its fundamentally not a great way of doing things. Actually modelling each blade of grass is insane on storage size - you want to be able to express the effect but have the renderer do something smart internally.]
                      bjornkn
                      Yes, LWs subdivision surfaces makes subdivided polys, which the render engine handles as any other polys. The point is that while other renderers may displace vertices that are really "not there", LW (and some others?) will not. It will only displace vertices that are either in the model, or generated by the SubD engine on-the-fly. IOW it will not displace every pixel in the texture, but every vertex in the mesh. It is still very useful for many things though.
                      • HumpmetwiceH Offline
                        Humpmetwice
                        Sorry for not getting back sooner but got a little side tracked. Although there are a lot of helpful tips and tricks from everyone this all is a bit over my head right now but will still strive to do better renders.
                        Thanks Kurt
